Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
KitchenAid Superba i need to replace the water filter how can i do it? which is the part number? where can i order it? i have a red light but after reset it went green do i still have to replace? rgds jaime
  • 35 Answers
You indicator light on your fridge is set on a timer. If you never took a single glass of water it would go on after six months or so. It is just an aide to remind you. To replace it, firmly turn counterclockwise about a quarter turn with a little pressure pulling down or out depending on the location of the filter. You need not turn off water. Replace with new one.
Posted on Dec 09, 2007
  • Gary Montgomery
    Gary Montgomery Apr 07, 2015
    how do you reset the timer? it stayed on after i replaced the filter
SOURCE:
What type if filter do I for kitchenaid superba ksrb25fhss01?
The refrigerator water filter for the kitchenaid superba ksrb25fhss01 is part number 4396508. If you order it from Sears Parts Direct, it's $45. See: http://www.searspartsdirect.com/partsdirect/part-model/Kitchenaid-Parts/Refrigerator-Parts/Model-KSRB25FHSS01/0593/0165000/O2029608/00002 . It's available from other sources for less (including Amazon: http://www.amazon.com/Whirlpool-4396508-KitchenAid-Maytag-Refrigerator/dp/B0009793KC .)
I hope this helps.
Jun 24, 2012 | KitchenAid Refrigerators
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
How do you replace the water filter on a Kitchenaid Superba refrigerator. I can find the filter.
under the freezer door there is a nob like thing. turn it and pull on it. instead of replacing it, rinse it out under runing tap water and put it back were you removed it from and push the fridge light botton 5X in a row
Oct 19, 2009 | KitchenAid Superba Architect KSCS25INSS...
Superba kitchen aide refrig red light for water filter wont go of
You just need to replace the light switch on the filter control panel. I hope this helps you out.
Sep 10, 2009 | KitchenAid Superba Architect KSCS25INSS...
Red light blinking after replacing filter
Not positvie for that model but there should be a little reset button, or try just unplugging the unit and waiting 60 secs before plugging it back in. Hope that helps
Sep 05, 2009 | KitchenAid Superba Architect KSCS25INSS...
Icemaker is not making ice.
check water valve /filter it maybe the ice maker
Apr 02, 2009 | KitchenAid Superba KSRS27CN Side by Side...
Fridge Filter
the filter islocated behind the toe grille, ordering instructions areprinted on the filter itself, and resetting the light is a matter of holdingin the button for 3-5 secs, its filtering your water and ice
Jan 26, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water filter alarm light
without the specifc model number i beleive you hold down the button under the filter light to clear it i think its a hidden button right under the light but if not send me the model num and ill look it up
Jan 09, 2008 | KitchenAid Superba 21.6 cu. ft. Top...
Water filter warning light
Push the light - it will flash red after a few seconds -then turn green.
The answer above on this page was correct
Mar 04, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
348 people viewed this question
Top KitchenAid Refrigerators Experts
vince
geob91
Dakshinamurthy...
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
