Question about Brother Office Equipment & Supplies
Not recognizing new toner cartridge
Hi there Just tried to replace my toner catridge on my brother 350 fax machine and it keeps showing on the screen 'no cartridge, open door and reinstall cartridge' I have done this several times stilll to no avail. This isnt the first time I have replaced the cartridge, but it is the first time I have had a problem. Any ideas
  • 43 Answers
Would that maybe be a 3500? Never heard of a 350.
Posted on Apr 20, 2009
BROTHER DCP7055 PRINTER SHOWS REPLACE TONER EROR
When replacing the toner cartridge, you MUST install a brand new, unused genuine Brother toner cartridge in order to reset the toner status. Swapping toner cartridges from one machine to another or installing a partially used toner cartridge may cause this problem. Brother machines control their image quality for the most suitable print quality by monitoring toner consumption. If you install a partially used toner cartridge, your Brother machine is unable to recognize toner consumption correctly which will cause this problem. Therefore, when you replace the toner cartridge, please use a brand new toner cartridge, not a partially used toner cartridge from another machine.
Jul 26, 2012 | Brother Office Equipment & Supplies
KUWIT OIL COMPANY IAM FACING PROBLEM IN FAX MACHINE BROTHER 2820 MESSAGE SHOWS 'TONER LIFE END' AFTER CHANGING TONER MESSAGE REMAIN SAME PLEASE GIVE ME SOLUTION. I HAVE AROUND 24 FAX MACHINES BROTHER...
you must have remove the white mylar sheet from the catridge when loading it...if yes! you got to find back the white mylar (plastic sheet) that slot in between the drum and charger roller placed it back ( the position must be accurate) then slot in back the catridge.The white mylar sheet is to reset the drum life counter
Jan 26, 2011 | Brother Office Equipment & Supplies
I replaced already new toner cartridge for my brother fax machine mfc-7220 but still the on screen message is appearing on the display "TONER LIFE END". Pls help me to solve this problem. Tnx and God bless...
I replaced already new toner cartridge for my brother fax machine mfc-2820 but still the on screen message is appearing on the display "TONER LIFE END".
Apr 12, 2010 | Panasonic KX-FL541 Plain Paper Laser Fax
Change drum
You need to go buy a Brother DR-350 drum unit cartridge. The drum unit is the thing that the toner cartridge (TN-350) clicks into. Pull out the drum/toner unit and separate the two halves. Place your TN-350 into the new DR-350 cartridge and put back in the printer.
Jan 18, 2010 | Brother IntelliFax-2820 Laser Fax
I have a Brother fax and copy machine and have just replaced toner with a brother TN 350 cartridge and still getting message that toner is low
You didn't include the model, but here are instructions for the Fax-2820; it should work for any of the models that use the TN-350 toner:
  1. With the power on, open the front cover.
  2. Press the Options key. The display will read "Change Drum?"
  3. Press Start.
  4. Press 1 0.
  5. The display reads "Accepted" for about 2 seconds, then change to "Cover Open."
  6. Close cover. The "Replace toner" message should be cleared.
Normally, inserting a new cartridge (with the power on) will reset the toner counter, and you won't have to do any of this.
Dec 21, 2009 | Brother IntelliFax-2820 Laser Fax
Said low toner cartridge. Replaced cartridge,
what is showing toner life end ? rajcanon007@yahoo.co.in
Sep 14, 2009 | Brother IntelliFax-2820 Laser Fax
Toner for fax machine 2920
If your machine is a Brother Intellifax 2920, it does take a TN-350 toner cartridge. Maybe you were wanting to replace the Drum Unit instead, DR-350. I'll bet this info is useful, yes?
Jul 03, 2009 | Brother FAX-2920 Plain Paper Laser
"Toner Low" keeps showing
Hi Meridy!
There could be a few reasons for the Toner Low msg you're getting.
  1. The toner wasn't evenly distributed when the cartridge was changed (shake gently from side to side before installing)
  2. The cartridge wasn't properly installed (ensure that the lock lever "clicked" into place
  3. The corona wire wasn't cleaned when changing the cartridge or the the blue tab wasn't put back in place (this is less likely the issue but still a possibility)
  4. The new toner cartridge was old and is now defective
I hope this helps with your problem. All the best!
Greg
Jun 17, 2009 | Brother IntelliFax-2820 Laser Fax
TONER LIFE END APPEARS ON LCD
try opening front door, press "options" then "start" then "1" and "0". if screen shows accepted, you're good to go. close front cover.
hth,
razors
Feb 06, 2009 | Brother IntelliFax-2820 Laser Fax
103 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
