Question about HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop
Compaq Presario SR2013WM Problem
When I started the computer the monitor wouldn't show anything. The lights come on and the fan runs on the hard drive, but nothing showing on the monitor. I tried to hook the hard drive up to my big screen to see if it might be the monitor. The initial start up was visible, Compaq, Windows XP message and than it went blank and the screen read signal? I'm not sure if this is an issue with the monitor or the hard drive. Please Help!
  • mrninja
    mrninja May 11, 2010
    can you get to the BIOS? the bios is on the cmos chip not the hard drive, that may help you narrow it down
ITTech06 THANK YOU SO MUCH... Had the same issue than luv2luvme78. Tried your solution and it worked... U're awesome... Many Thanx. Thought I'll have to trash my pc which has bunch of info I still needed.
Posted on Oct 16, 2011
  • 36 Answers
Unplug power cable from of the PC. Then hold power button in for 30 seconds, this will drain the capacitors, then plug back in the power cable see if this helps, if not could power supply, or video card.
Posted on Jul 24, 2009
Computer will not boot. The CPU fan runs wide open and nothing will post.
most likely a video card problem / motherboard problem or memory problem
i would suggest start with the easiest and the cost effective one.
take out ram, power on, power off, install ram.
reboot.
Dec 31, 2010 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
My compaq computer wont turn on for more than a second. It boots and the cpu fan starts but than the monitor doesnt show anything even though its on, the fan turns off and the computer stops booting. I...
1) Is this a laptop or a desktop?
2) What OS are you running?
3) When was the last time that it booted successfully? Did anything change then? Did you upgrade the OS? Did you upgrade the software (firmware) on the processor (Intel or AMD)?
4) Do you see anything on the screen? Compaq logo? Boot options?
Feb 01, 2018 | HP Compaq Presario SR1500NX (PX786AA) PC...
My monitor has kicked into sleep mode and won't "wake up".
Unplug all the Cables from Compaq Presario 5103 CL and leave the Keyboard, mouse and monitor cable pluged in.
Now make sure the power cable of the monitor should be pluged in and the power cable of the tower should be pluged in.
Now to check if the montor is fine just unplug the video cable only which will show no input signal on the screen. If it shows this signal the monitor is fine. Plug back in the video cable.
If the monitor is going to sleep mode it might be possible that the old computer ( Compaq Presario 5103 CL ) is in stand by mode. hit any key on the keyboard and it should come back .
If it is not in the stand by mode then do one thing. Check the same monitor with the new computer. If it is working. Perfect ..!
Do one thing now ..!
Unplug all the cables from your old system and then press the power button for 30 sec and let it go. Now plug the keyboard, mouse and the monitor try again.
If it works Perfect. If not ..!
Then you need to open the tower and check on the processor FAN is it running..? If its not running you will not get the display as the fan is responsible for the display on the screen. Otherwise...!
Check the Tower possibly the Tower is not getting the power.
Try these steps and let me know If it works
May 04, 2010 | Compaq Presario 5000 PC Desktop
Black Screen Compaq Presario
Do you see the BIOS splash screen or anything?
Try booting into safe mode by pressing F* as soon as you power on the computer. If the monitor works, then it is a bad driver. Roll back to a previous restore point, boot to last known good coonfiguration. Last Known good configuration is available from the same as the safe mode screen.
If this is helpful, please comment and rate. Have any other questions, please let me know.
Oz
Feb 12, 2010 | HP Compaq Presario SR2010NX PC Desktop
Green light comes on and the fan but monitor will not
Hello.
Could be the monitor or your Presario's VGA card. Swap the monitor with another system to see where the problem lies. If another monitor works on your system , it's your monitor. If another monitor doesn't work, then the problem is the VGA card.
Hope this helps.
Nov 10, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
HP Compaq Presario SR2013WM ...Power Problems ?
Unless the power button sticks or does not pop back out, i doubt the issue is in the switch, but it can be tested by replacing it with a momentary switch from Radio Shack (not an exact fit, but good for testing)
This sounds like a power supply issue. That would be the first thing to check. If it is NOT connected to anything except the power cord , it shouldn't run unless switched on.
Could also be the motherboard, but before you start dismantling the computer , check the obvious. Open the case (usually to screws on the back) inspect all the cables, reseat your ram chips and addin cards.
Not to scare you ar anything, some of these presarios have bad capacitors on the mother board. coupled with the fact that they are difficult to clean (inside) and airflow is not maximized in the case, they tend to cause the capacitors to swell and leak, losing voltage.
When you are inspecting the insides of your case, take note of any capacitors (little cans with crosses on the top) on the main board inside around the CPU fan that are swollen or leaking.
If you find these in bad condition , i would replace the motherboard.
Apr 04, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
Power/Monitor
looks like the power button needs to be replaced.. must be pushed it
Mar 28, 2009 | HP Compaq Presario SR2013WM (RE468AA#ABA)...
My Compaq Presario Will not even show curser after start up
reboot and keep pressing F5 go to safe mode if u can see the screen , u need a video driver ,or try reformatting and re installing windows,
Nov 12, 2008 | Compaq Presario 5000 PC Desktop
Compaq presario 5000 startup problem
Firstly the keyboard does blink, but do you hear 2 beeps one then another a few seconds later, if not memory or graphics fault. Are you able to start in safe mode(press F8 when pc is booting up)when menu comes up highlight 'Start windows with last known good configuration' then press enter and it should re boot. The graphics card(if it's not onboard)may need to be removed and re seated, also the memory. Also check hard disk drive ide and power cable.
Jan 15, 2007 | Compaq Presario 5000 PC Desktop
HP Compaq Presario SR2013WM (RE468AA#ABA) PC Desktop Logo
353 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
