Question about Refrigerators
Water is coming out of the top of the refrigator
I cut the water  supply off  to try and stop it but every few days it still drains water down from the top of the refrigerator.  It is coming from the middle, in the back out of some thing that looks like a vent.
    Problem Solver:
  • 9 Answers
Take the vent off and dry water up underneath
Posted on Apr 20, 2009
I have a Kenmore freezer top refrigerator with: Model #: 106.78202891, Serial #: EJ0320474. The problem is that the drain in the back of the freezer is freezing up and water is frozen on the bottom of...
this is a common problem that we see on a daily basis in my appliance business... over time food particles/open pkgs. etc trash will get into drain and clog it... what has happened is the drain hole located in the back bottom of freezer is stopped up and everytime the unit goes into defrost the water from the heater defrosting your coils is suppose to go down the hole since it is stopped up it is backing up into freezer and some spilling over into refrig. the whats left in freezer will freeze and continue to grow in size larger and larger...your going to have to remove panel to back of freezer inside .which is going to require removing all food and shelving/ice maker etc... unplug unit and start with a hair dryer thawing unit out. you will eventually see the hole and there will be ice in it..the water is suppose to drain all the way down to compressor area if you remove back panel on bottom you will find end of hose usually hard plastic.you want to thaw until you can run a glass of water down and see it run completely through or you will be doing it again in a few days if not it takes a good hour and a few towels but its possible. good luck
Jan 05, 2011 | Refrigerators
The water tube in my GE (side by side refrig) ice maker keeps freezing. When the ice tray does not get the water, it calls for more. the water ends up spraying all over the inside and freezing because...
Your drain tube must be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little air pressure will usually clear it out. Flush it out with hot water and clorox may help. Make sure it drains quick enough. The drain should be located below the evaporator coils on the lower back of the freezer
Jul 15, 2008 | Refrigerators
I have a 6-7 year old Magic chef top freezer, refrig which is collecting water each day at the inside bottom of the box, refrigerator section. I notice that a slight drip of water comes thru the middle...
The defrost drain is located just under the cooling coils in the back of the freezer. You will need to unload the food and remove the shelves from the freezer. Take the back panel off from inside the freezer and you will see a hole just below the coils. Flush it with hot water using a turkey baster or small hose. See the link below for more details.
Defrost Drain
Jul 21, 2010 | Magic Chef CTB1821AR Top Freezer...
Describe your SEARS 12 CU FT REFRIGERATER Problem IT LEAKS WATER ON THE FLOOR AND HOLDS WATER IN THE BOTTOM OF THE REFRIG. NOT ALL OF THE TIME
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer. If this repeatedly happens with yours, you may can prevent it by taking a bare copper wire and wrap it around a fin near the heater and put the other end a few inches down the drain. The heat convection may prevent it from freezing.
Apr 23, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Whirlpool refrig - i'm finding water under the vegetable bins and on the top shelf in the mornings. Freezer has no problem and is defrosting fine. I can't figure out where the water is coming from. No...
there is a drain in the freezer so when the fridge defrosts the water drains down to the pan in the bottom of fridge,your drain is blocked,you need to take off the inside freezer back wall,melt out the ice with a hair dryer and then unblock the drain,i use a steamer to do this,they cost around 50 bucks,the drain line is plastic so you don't want to go sticking anything down the line that can damage it,slime builds up in the line or food particles go down the drain and then ice builds up in the line,the steamer cuts through this and sanitizes the line,if the drain goes strait you can install a heater probe,it's just a piece of metal that you rap around the heater and stick the other end down the drain hole so it won't freeze up again,when you think the line is clear,pour hot water down the drain to make sure it's clear,be careful when melting out the ice with hair dryer,to much heat can damage the styrofoam,make sure the air vents are melted out,they are the holes in the styrofoam,you might have to melt it out from inside the refridgerator section heating the area up on the ceiling,also make sure the control is shut off to the freezer,you don't want the fan to be blowing,good luck
Jan 28, 2010 | Whirlpool 21.0 cu. ft. Top Freezer...
Water is leaking from the top of my whirlpool refrigerator, what is the cause of this and how do I repair it ?
You have a icemaker? turn off its water supply, does the water stop leaking then?? Else is condensation from no frost mode which gets bad if your freeser/refrig door leaks air. shut door on sheet of paper drag paper up and down seals top and bottom if resistance is vacant in any seal area FIX IT. You can slightly REFORM a warped door be gentle! CLEAN SEAL AREAS FIRST
Nov 22, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
The water is overflowing from the freezer onto refrig shelf
Yes, let the unit thaw out, and replace that thin wire. it's called a drain heater, it simply keeps the water from freezing before it gets out the drain.
Sep 26, 2009 | GE Profile Arctica Stainless Steel Top...
I have a GE TBX25PAXCRWW top mount freezer model. It is leaking water from the light switch. I would assume it is a blocked evap line. Do I access it from the insde of the freezer or outside.
Your problem is a clogged defrost drain . This is accessed from inside the freezer section and by removeing the rear freezer panel . Use a hairdryer to defrost the pan , under the coils . Also , the drain line for your model , is located behind the refrig . So , you only have a short area between the drain hole and drain line , to clear . I would suggest blowing thru the drain hose behind the refrig also , to make sure it is clear .
Jul 02, 2009 | GE J Series 18.2 cu. ft. Top Freezer...
Horrible oder
You are going to have to take the back cover off and investigate. Check the defrost drain pan first. If anything from the freezer, like raw meat juice, went down the defrost drain, it would end up in the defrost drain pan, usually located very near, possibly on both sides of, the fan motor at the bottom of the refrigerator. The next thing to look for is a dead mouse. They like the warmth from the refrig., and can get killed from a fan blade, electrocution, or if they ingested poison, that makes them thirsty and the warmth plus the availability of the water from the defrost drain makes an ideal place for the to curl up and die. (A dead mouse usually dehydrates and stops smelling after a few days.) All that sounds like lots of fun, right? Happy hunting and good luck.
Jan 13, 2009 | Kenmore Refrigerators
The refrig is Model ET8HKXM003 and Serial # E54044751 Manufactured 10/05. It is type 18TFA. The Temp is currently set on 3 (normal). The freezer appears to be leaking down into the refrig as I find...
the drain tube on the machine has frozen in the freezer section
remove the back panel and with a hair dryer thaw the drain tube
you will see an alluminum sheild with a 1/2 inch hole in the bottom of the shield this is where you want to direct the heat
it may take 20-30- mins to unfreeze it to make sure it is unfrozen pour som water into the valley of the sheild if it runs into the drain pan it is unthawed if it pools up keep unthawing
Apr 16, 2008 | Refrigerators
Refrigerators Logo
43 people viewed this question
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
