Question about Lexmark MFP-X3470 All-In-One InkJet Printer
Cover open error
The message line readscover open even though it is shut. This keeps the printer frozen. Help
  • 4 more comments
  • nitabug Nov 01, 2007
    I have the same problem and it won't even let me turn it off. Where is the sensor discussed located?
    Thank you, Anita
  • Chaingang Nov 12, 2007
    "Cover open" is showing even when the cover is closed. The copier will not turn off when you attempt to turn it off. Tried unplugging it to reset it to no avail. Still shows "Cover open" when the cover is closed.
  • Cohanna Nov 29, 2007
    Is it possible to get more detail that simply check sensing switch?? Where is this switch located?
  • Jo Johannesen
    Jo Johannesen Mar 06, 2008
    Mine says the cover is opened too when it is not. Where is the sensor switch that I keep reading about?
  • Anonymous Mar 14, 2008
    cover open has frozen printer with cover closed
  • Anonymous May 12, 2008
    I GET THE "COVER OPEN" WHEN IT IS CLOSED. I L MOVED THE PRINTER AROUND AND FOUND A LITTLE WHITE "PEG" LOOSE INSIDE. I SUPPOSE THIS THE "SENSOR HAND" THAT TELLS THE PRINTER WHEN THE LID IS CLOSED. IT LOOKS LIKE IT NEEDS TO BE SNAPPED BACK BUT CAN YOU PLEASE TELL ME IT ACTUALLY GOES?
  • 163 Answers
Plesase check the cover sensing switch or sensor
Posted on Sep 22, 2007
Screen reads paper jam even though there never was a paper jammed. I tried turning the printer off and on but the same message still appears. Also the cancel ! keeps flashing even though I cancelled the...
Hello Sande.
Try cancelling the printer job via the control panel in Windows.
Also open covers, including the top flatbed half, to view the paper path.
There may still be a stray piece stuck in there somewhere.
Does this help?
Clive.
Nov 18, 2017 | HP Officejet Pro 8500 Wireless All-In-One...
Hi, my printer keeps saying cover open even though it is not have opened printer up but do not know which way back to put the white piece thanks
Remove the sheets of paper. Open the printer cover and remove the cartridges as well. Close the cover. Then unplug and replug the printer into the power outlet to reset itself. When the printer turns on, reinsert the cartridges when prompted. Load some paper. Check for any error. Try to print.
Apr 11, 2011 | Lexmark X3480 All-In-One Printer
I changed the ink in my Lexmark 3400 printer and I keep getting an error message "cover open" and it's not open. I tried everything....unloading the software then reloading the software, shutting it off...
The printer displays a 'Cover open, please close cover' error message, even though the cover is closed.
This can happen if the lever on the cover open sensor is knocked off the switch assembly.
Nov 30, 2009 | Office Equipment & Supplies
Lexmark x3470 printer says "cover open" and it will not do anything. Curtis
Try these as I found them from Lexmark's website
Solution What you will see
Possible cause of the error
What to do
Take the following steps to try to determine if there is a hardware fault:
Steps Actions 1 Remove and replace the cartridges from the printer. 2 Disconnect the power cable and the USB cable. 3 Check that the power cable is plugged directly into a wall socket. 4 Reconnect the power cable. 5 Close the printer cover. 6 If the error persists, please contact Lexmark Technical Support for further instructions.
Nov 18, 2009 | Lexmark X3470 All-In-One InkJet Printer
Back cover open message
I had the same error message. I also tried every compartment... Here's ultimately what my problem/solution was...
I turned the printer around and fully opened the back cover. I found that one of my kids had somehow fed a small piece of paper/cardboard into the printer. When I opened the back cover all the way I could see that obstruction (which I hadn't seen before). Pulled it out, and the error message went away. Works fine now.
Sep 02, 2008 | Brother MFC-7820N Printer
HP Deskjet 5150 - top cover open
I had the same problem, and the cause turned out to be the cover switch not being fully pushed in. On the underside right edge of the top cover, there's a little triangular protrusion that pushes down a black rectangular button (the cover switch) when the cover is closed. The problem occurs because the flimsy top cover is made of plastic and flexes slightly when you close it. This means that sometimes, the right edge of the cover won't seat properly even though it appears as if the cover is closed all the way. When this happens, the triangular protrusion isn't fully pressing the switch down.
To test if this is this is happening, send a print job to the printer and wait for the "top cover is open" error message to appear. Next, open the top cover door and locate the cover switch. It's a little black button in a rectangular hole at the right edge of the doorway near the ink cartridges. Take a pen or a car key and use it to push the cover switch down. You can also use your fingertip to do this if it's skinny enough. If you keep the cover switch pressed down, the power button should start blinking to indicate a print job is coming through. If the print job actually starts printing, then you know the problem was the cover switch.
In my case, all I had to do the fix the problem was close the cover and make sure it was fully seated by firmly pressing down the right edge of the cover until I heard a plasticky "click" noise. After that, the problem went away.
Hope this helps.
Jul 23, 2008 | HP DeskJet 5150 InkJet Printer
Cover open error
There is a latch that preses a small switch when you close the cover (look for this) to indicate that it it close if it is broken you can tweek it using a toothpick or anything that may press the switch temporarily this may alow it to work as long as the switch stays down.
May 28, 2008 | Lexmark X3480 All-In-One Printer
Printer cover open error message
I had that problem too.
Unplug the printer.
Hold the printer cover open while you plug in the printer.
Then wait for the printer to power on while still holding the cover open.
Then close the cover.
The buttons should work and th error message should be gone.
It worked for me.
Nov 01, 2007 | Lexmark X2250 All-In-One InkJet Printer
Printer Error Message after changing the cartridges
I'm not even pulling up any info on that error msg.
Where are you reading the error msg from, within Windows? Or from the printer itself?
Oct 23, 2007 | HP PSC 2355 All-In-One InkJet Printer
Open Questions:
Lexmark MFP-X3470 All-In-One InkJet Printer Logo
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
