FixYa.com
Tags:
GE 31GT660 TV
GE 31gt660 tv - squeals when power cord plugged in
By Phoebe - usenet poster
GE TV model 31gt660, 5-6 years old.
The tv does not do anything other than squeal/whistle/hiss, or
whatever you want to call it, when you plug it in. Does not turn on.
took the back off of it and sound seemed to be coming from a
transformer, though its hard to tell.  Has anyone seen this problem
before, or have any ideas on what it is and how it can be fixed?
I got this TV from a friends uncle, apparently it just started having
this problem one day just out of the blue.  He didnt tell me that
anything abnormal happened to the TV to cause this.  thanks a bunch.
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on Oct 25, 2007
Not Rated (0)
Guest
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
horizontal output transistor is defective,also change out damper diode(cc4402). very common repair. use buh517 transistor. they last longer. i just repaired my own personal set. same problem.
Was this solution helpful? Show your Appreciation by rating it:
Solution #2
posted on Aug 07, 2005
Not Rated (0)
Putty
Putty - usenet poster
Rating: 0%, 0 votes
Squeal is indicating an excessive load on the power supply, check the horiz
output and flyback transformer.
Can you Help with these Standard Televisions problems?
HITACHI IN NEED OF REPAIR
HI, I HAVE A 1998 HITACHI,... Answer This...
GE 31GT660 TV
Inputs
How do I get the tv to listen... Answer This...
GE 31GT660 TV
power shut down
when i turn on set it plays for... Answer This...
GE 31GT660 TV
power shutdown
set shuts down by itself and... Answer This...
GE 31GT660 TV
Using DVD player with GE...
Got a 31gt660 from friend and... Answer This...
Repair Service
Find Standard TV Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
