Question about Paradyne (6211-A2-200) Router
What is the default user name and password for this paradyne modem?
  • debbikowalsk Apr 20, 2009
    now that i'm into the settings area, I am trying to configure the settings to work with AT&T DSL service. I confirmed that my DSL service is active, and I'm getting all green lights on my modem; however, AT&T has told me that I need to configure for PPoE and they gave me the User ID and password. I still can't get it to work. Can someone show me a screen shot of the AT&T modem configuration so I can try to mimic the Paradyne modem to work with AT&T?
    President:
  • 623 Answers
By default both the username and password are admin.
Good luck and if you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Apr 20, 2009
  •  C. Dante
    C. Dante Apr 20, 2009
    Hi Debbie,
    in order to find a screen shot, I would need the router model you are using. After some research I found a webpage with some Paradyne manuals - can't say though if yours is in the list. Have a look here - maybe you're lucky.
    In general: On the WAN setup, you should find a menu to choose between values like DHCP, PPPoE, L2TP, Static. This is where you have to choose PPPoE. Enter your username and password as given by your ISP (AT&T). Look at this page, and, although your router interface might look different, see that the only values they enter here are
    a. AT&T PPPoE username
    b. AT&T PPPoE password
    c. Then (not in the pictures) Select Auto PVC - switch
    to
    5.
    See also what this guy did (link).
    Be sure to hit the apply button after making changing on each web page!
    If this is not working for you, tell me your router model and I will try to find that information.
How i can get myusername and password
Most Actiontec Modems and Routers DO NOT have a default login. The exceptions are the Actiontec Modems and Routers made and branded for a specific Internet Service Providers (ISP). Some ISP's require a default user name and password. These Modems and Routers have a sticker on the bottom of the device with the default User name and Password printed on them.
Aug 24, 2015 | Actiontec Computers & Internet
Well,when i type in the adress bar 192.168.1.1 it ask the login and the password but i dont know the login or password my cable modem is a motorola sb5101i SURFboard Thanks
HI i beleive you are looking for a user name and password for the motorola sb5101i
here are the username and password for the modem which are default
USER NAME:-ADMIN
PASSWORD:-leave it blank>>press login(this should work)
DEFAULT IP FOR YOUR MODEM:-192.168.100.1
IF THIS doesnt work try to turn off the modem and turn it on back...this might work
or else you can try to reset the modem,once this is done you might have to reconfigure the modem...contact your internet service provider to set it up
Apr 25, 2011 | Arris SB5100 SURFboard DOCSIS 2.0 Cable...
What is the default password of motorola wimax CPEo 35450
Default user name and password of your modem is :
User Name : admin
Password : admin
Regards
Ashly
Feb 26, 2010 | Arris SURFboard SB4100 Modem
What is the default ip of the paradyne modem6381
The default ip is :192.168.1.1
The default User-name and Password is : Admin
Some model came with default ip 192.168.0.1
Subnet to use is 255.255.255.0
Ok make sure you are using an ip address with the same range.
That is you can set your ip 192.168.1.x where is 2 to 252
ok try this
Jan 22, 2010 | Paradyne 6381 ADSL2+/ReachDSL Router...
What is the ip address of paradyne 6381 a3 300 router
To configure your router, open your web browser. Type the default IP address (http://192.168.1.1) into the Location field of your browser and press the Enter key. A Login screen will appear. Use the below to log into your router.
The default IP address is 192.168.1.1
The default user name is Admin
The default password is Admin
Both are case-sensitive.
Jan 08, 2010 | Paradyne ADSL/R 6381 Router (6381-a2-200)
Some time ago, I changed my password on my 6211-I1-200 Paradyne ADSL modem. Is there a way to change it back to the default?
You will need to check out the user manual and follow the procedure for a hard reset (ie back to default). If fact I'll save you the google ...
http://www.zhone.com/support/manuals/docs/62/6211-A2-GB21-20.pdf
Sep 27, 2009 | Computers & Internet
I want to set password so other people cannot get on to my router another words i want secure connection.
You will need the manual for your modem/router to log into the device. Usually in your web browser's address bar you will type something like this: "http://192.168.0.1". A login display will appear Type in the user name and password from your device's manual. On the "Wireless" page you can select your network name in the SSID box and set security with a WEP key. The key can be in HEX (0 to 9 & a to F), or ASCI (plain text). The KEY should be at least 10 characters. Make sure you save or apply the changes before you exit the modem/router setup program. Keep the KEY simple, and write it down. Once you set it up, you will have to select your internet connection from "Available Network Connections" and type in the KEY twice to get on the net. You should only have to do this once. The next time, your network will be your computer's default connection.
Jun 08, 2009 | Paradyne WIRELESS ROUTER 4PRT ADSL/R...
Default login information on a 6381-a3-200
first write 192.168.1.1 on address bar a login window will apear write user name and password admin
Jul 25, 2008 | Zhone Paradyne 6388-A1-200 Router
6381-A3-302,6211-I1-300 Paradyne ADSL 2+/Bridge Router
i have paradyne paradyne 6381 a3 302 lost the driver cd. My new windows xp don't pick it automaticly. plz give me a slution.
Nov 22, 2007 | Paradyne 6381 ADSL2+/ReachDSL Router...
Paradyne (6211-A2-200) Router Logo
1,368 people viewed this question
Top Paradyne Computers & Internet Experts
Michael Galve
Michael Galve
Are you a Paradyne Computer and Internet Expert? Answer questions, earn points and help others
