Question about ASUS A8S-X Motherboard
Boot Problem Hi..I have a problem. To begin with, after I added the hard drive, dvd etc, and turned on the unit..it showed me an (Intel uCode Loading Error) and to press F1 to continue. Which I did , and was able to format my Sata HD and load in my Win XP oper. system.The unit would always boot up with the same message but I could access Windows only after I pressed the F1 key...Then I started having problems with IE exployer and so I decided to start out fresh again and format the drive, which i did. After that............ (If i just turn the machine on it goes to the ASUS Screen saying for setup press DELETE, for post press TAB when I try either..Nothing happens???). (If i turn on the machine while it's posting up and press TAB or DELETE it'll start to POST up and then stop after Identifying Master/Slave etc. and then hangup.I then decided to try and flash the BIOS to the latest version (rev 1009) ASUS had..I did and with the same results.I loaded in the original BIOS from the CD (rev 1004) still no change .I even cleared the CMOS with no affect, except to reset the clock. Any Ideas?? Thanks for any help.
  • roviper Sep 23, 2007
    Thanks for adding a possible solution but here's the deal...
    The CMOS battery is brand new nothing is bulging and my bios chip is good..I'm fairly sure. This is what I did since the last post..
    #1. I remove the sata pwr cable from the hard drive and booted the machine....What I get is the post minus the sata drive ie. sees the 2 DVDs memory cpu and it's looking for the boot drive no Intel uCode error(upgraded to the latest bios revision & cleared the Cmos)
    # 2 If I re-connect the sata cable and turn on the machine it postup and sees the 2 DVDs memory cpu and the Maxtor 300 sata drive but then it hangs and won't go any further.
    I've gone into the Bios with the hope of tweaking the hard drive parameters but the AMI MOBO bios has no provisions for me to do this... Ya know whats funny...Before I formatted the hard drive everything was fine except for the uCode error.
    Now it's a nightmare..
    Help me Jesus...........
    Scholar:
  • 59 Answers
I might try a different hard drive, preferably one that isn't sata.  Just to help limit down the possibilities.
Posted on Oct 16, 2007
    Sergeant:
    Champion:
  • 293 Answers
Try using a spare memory. Is the cmos battery ok? Your bios chip may be defective. Are their any buldging caps on the mobo?
Posted on Sep 21, 2007
Intel D102GGc2 shows disk read error when detached sata dvd writer and xp boot when attached the same
Hi. if you're getting the same 'disk read error' when the DVD drive is attached and detached, then the error relates to the hard disk, that you're supposedly trying to install XP onto.
Ultimately you want the board to boot the DVD drive first. A quick change to the 'Boot priority' in the BIOS should sort it.
Apr 27, 2014 | Intel Computers & Internet
Boot failed
Is the optical drive a DVD drive?
Have you set the machine to boot from the optical drive?
Frequently the HP boot sequence is accessed by touching the Escape key on boot.
Dec 12, 2013 | HP ProLiant DL120 G6 Rack Server System...
HOW to install windows xp on intel dh61ho motherboad
Hello here is the homepage:
http://downloadcenter.intel.com/SearchResult.aspx?lang=eng&ProductFamily=Desktop+Boards&ProductLine=Intel%C2%AE+6+Series+Chipset+Boards&ProductProduct=Intel%C2%AE+Desktop+Board+DH61HO
In general, what you'll need to do is:
  • Turn off your computer.
  • Power on again
  • When you see the splash screen or BIOS menu (and before Windows starts to load), hit the Delete key.
This will typically either get you into a boot device menu or the BIOS settings where you should be able to select the device you want to boot from to adjust the boot order. In other words, your computer may normally try to boot first from the hard drive drive.But now you have to select to boot from the dvd drive. Save the changes, and then boot your computer again, this time without hitting any button and lay the windows disk in the dvd drive. If all goes according to plan, you should soon see a "Windows loading" message on your screen and press any key to install windows.You can follow the on-screen instructions to install Windows on your computer.
You also need to make a full format of the harddrive, and reboot again.
Look also in the manual how to setup the bios.
Here is some youtube video that shows how:
http://www.youtube.com/results?search_query=how+to+install+windows+xp&oq=HOW+to+install+windows+xp&gs_l=youtube.1.0.0l10.1637.1637.0.3243.1.1.0.0.0.0.122.122.0j1.1.0...0.0...1ac.2.LqJatFrFwa4
When the installation is done, you have to install all the driver for the mainboard.Graphic,sound,chipset etc.
Good luck
Jan 28, 2013 | Intel Desktop Board DH61HO - Classic...
Check cable connection..! PXE-E63: Error while initializing the NIC PXE-MOF: Exiting Intel PXE ROM No bootable device -- insert boot disk and press any key
Hard drive is not detected. Change the Boot sequence in BIOS
1. To access the BIOS you must tap F2 or delete key upon turning the computer on
2. Try to look for the Hard drive if it is detected by BIOS if not got to step 6
3. Look for Boot Sequence or anything that is associated Boot
4. The Order boot of must be 1st: DVD Drive, 2nd: Hard drive, 3rd: Network etc.
5. Save the changes and Restart
6. If you still get the same message I suggest that you take out the hard drive and put it back in until it is detected in BIOS
7. If Step 6 did not work I think you need to replace the Hard drive
Thanks for Choosing
Jun 16, 2011 | Acer Computers & Internet
How do i reboot or recover my nb505 toshiba netbook
Reinstall Windows from a Disk
1 Turn on your Toshiba . Insert your recovery disk or the original Windows operating system DVD
into the 's CD/DVD drive. Turn off the computer.
2 Turn on the Toshiba . In the first few seconds while it is starting up, press and hold the F12 key on your keyboard to access the Boot Menu. (Note: Some Toshiba models may tell you to press "C" to boot
from the CD-ROM). The screen will display boot for this boot up session only.
3 Use the arrow keys to navigate. Select the CD-ROM/DVD drive to highlight it. Press "Enter." Be aware that this setting is for this session only; it is not a permanent change.
4 Allow the computer to start up. Follow the onscreen instructions for reinstalling the operating system from the disk.
Reinstall from a Recovery Partition
1 Boot up the Toshiba . In the first few seconds while it is starting up, press and hold the F8 key. This will begin the "Advanced Boot Options" menu.
2 Use the arrow keys on your keyboard to navigate the menu. Move the keys to select "Repair Your Computer." Press "Enter."
3 Select your language and keyboard; click "Next."
4 Select your Windows user name from the drop-down menu. Enter your password if required. Click "OK." This will begin the "System Recovery Options" menu.
5 Select the Toshiba Recovery Wizard and follow the onscreen instructions. The Toshiba Recovery Wizard will delete all existing data on the hard drive and reinstall Windows.
Hope this helps!
Mar 28, 2011 | Toshiba NB505N508BL 10.1" Intel Atom...
Intel cpu ucode loading error
does your cpu?boot up?try to go at the cmos!!then load bios defaults?
Jul 14, 2009 | ASUS P5VD2-MX SE Motherboard
Will not boot...both CD drives show to be disabled in BIOS and I cannot get them enabled? All was OK till I tried to install a new Seagate Hard Drive. (Old one was beginning to make noise.   I...
Change the "master", "slave" jumpers in the back of the hard drive to the same config as the old one was, that's your problem. If you still have a problem, just run the drive on a seperate cable to the motherboard, then set the dvd drive to the opposite of whatit's set at now from the jumpers in the rear of the drive. Take out the battery frrom the board and let the cmos reset before powering back on.that's where the settings are stored.
Mar 17, 2009 | Intel D865GBF Motherboard
You need to update the BIOS.
Go here to get the update, enter...
Product: motherboard
Series: Socket 775
Model: P5VD2-VM SE
Operating System
ASUS Download Link
Oct 16, 2008 | EliteGroup L7VMM2 Motherboard
Intel uCODE loading error
problem for all ASUS PC Desktops Intel uCODE loading error button1-share.gif
May 18, 2008 | ASUS Computers & Internet
Open Questions:
We provide best team support to all Toshiba users active for 24*7 hrs. Call us +1888784-9316 With 24x7 major subsidiaries and affiliates worldwide, Toshiba Corporation is known as a world class innovator and global high technology product leader worldwide. Toshibha launched laptop computers from its kitty way back in 1985 and by Financial Year 2010 they have managed cumulative shipment of more than 100 million Laptops. Toshiba has been known to set benchmarks when it comes to quality and features that results in exceptionally high performance. In spite of the exceptional features you may experience issues related to data recovery, backup and security and may be deprived of any support by the Toshiba Support. In the event of an OS Crash there is always a chance that you may Toshiba Support your critical data. Virus attack or accidental data deletion are also some of the other reasons that could cause mess. An updated backup will warrant that you do not lose your critical data forever. DataAlign comes to you rescue in these situations. DataAlign offers comprehensive technical assistance for your computer's data backup, recovery and security. DataAlign lets you schedule backups to execute daily, weekly or monthly. Our award winning cloud backup Toshiba Customer Service lets you schedule your backups continuously throughout the day. Data Align gives you affordable services that saves you both time and money and that lets you take control of other important things in life like growing your business or spending time with near ones. TOSHIBA is known for its diversified product range and services worldwide. Still, there are several issues that a TOSHIBA user can face on the TOSHIBA computer. Problems faced by TOSHIBA customers BIOS update Toshiba Backup Slow Performance Windows 10 upgrade Data Backup and Transfer Office and outlook setup Wifi and Internet Issues Audio & Video Issues Startup and Boot problems Windows updates Computer Tune-up Issues Virus Removal Issues Our highly talented and expert IT Team can help you fix most of the issues that you face with Toshiba Virus . And the best thing is that we can help you get your data backed up on our secure cloud storage. Why Our Toshiba Help Desk Number Technical Support Team Are Best? With several years of experience in our kitty working with a wide variety of customer group, we have gained an edge when it comes to providing technical support for TOSHIBA Computers. To add to it, our expert technicians trained specifically on TOSHIBA computers are always ready to help you best possible solution for any issue that you may face with your TOSHIBA product. 24X7 availability and assistance for your TOSHIBA computer. We have a dedicated & experienced support team to handle issues for your TOSHIBA computer We ensure little to no downtime with maximum uptime and highest productivity for your TOSHIBA Computer. We ensure Data backup and retrieval assistance We ensure end to end ownership & solution for issues you face with your TOSHIBA computer. Quick and efficient support over the remote. You can sit back & relax while one of our techs fix the issue for you. All these issues and many more, concerning Toshiba users are directly and efficiently resolved by our technically knowledgeable team who can be Reached 24/7 on our Toshiba Contact +1 888 784-9316.
Apr 27, 2018 | Toshiba Computers & Internet
See all ASUS A8S-X Motherboard Questions
ASUS A8S-X Motherboard Logo
460 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
