Question about Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
Internal antenna do not pick up local channels withought cable.seems like the antenna would pick them up right?
  • 1,139 Answers
It sounds like the TV justs has a insufficient internal antenna system. If you can put an external antenna on this sytem do so just to test it.
Posted on Sep 21, 2007
I just purchased an indoor antenna for to view local stations. Can i use an indoor antenna for my olevia 232-t11 lcd-hdtv? If I can, what steps do I need to follow?
Yes you can use an indoor antenna. Just make sure it is an HD antenna to get the digital channels clearly. You will have to do a scan to pick up local channels. In the TV menu, it will ask you if you want to scan for "cable" channels or "antenna" channels. You want to choose antenna.
Feb 11, 2013 | Olevia LT42HVi 42 in. LCD Television
Will not pick up a local channel
I have the same problem. Changing the antenna connection may help as will changing antennas/antenna position. Try to do a channel search in good weather.
Jan 04, 2013 | Televison & Video
I am moving tomorrow and won't be able to afford cable or satellite for awhile. I have a newer model Sanyo tv. Will I need a converter box or can I hook an antenna directly into the tv to pick u
If your TV has the screw-on coaxial cable connection on the back, then you will not need a converter box. You can attach an internal or external antenna and have your TV scan for digital channels. The converter boxes are mostly for old CRT TVs with analog tuners or newer home theater "monitor" TVs which are being produced without built in tuners.
Dec 21, 2012 | Sanyo DP32746 32 in. LCD Television
HDTV not picking up local channels
Look to see in menu if set is set to Air or Catv (cable) if on cable anything is possible 2-13 but above that no or almost no reception.
Oct 25, 2012 | Tatung V23CLTT 22.92 in. LCD Television
I have a RCA LCD TV model no. RLC3708A and when hooking it up when I took it out of box, I got to
I think you are confusing the channel on the tv and the channel of the cable company that is not something that you can pick up with the scan tv, scan tv is good for picking up local channel meaning air channel that we get with a antenna only not the cable chanel
Jun 24, 2012 | RCA Televison & Video
I can't get all the antenna channels
I do not know if your in the USA or a international country or what have you. But part of the reason why older tv's still get a RF signal is because of there older tuner inside. Now I know the USA went digital last year and in saying that this could be you problem but lets not put the horse in frount of the wagon here. You might want a try a better antenna first to see if the inporves things. But most tv's use UHF/VHF/IRC/HRC and the older ones just use UHF/VHF and only can pick up channnels with those tech. But your newer ones block out low frequencies UHF/VHF is its harder to get a signal. I would say try a better antenna or you might bne in a digtial area where you need a little converter box.
please be considerate and rate with the thumbs to your top right before you close the window, alos if you will leave me some feedback.
Apr 13, 2010 | Samsung HP-S4253 Television
Just got an antenna to pick up local HDTV channels. I scan the channels and none are found. does it matter if I connect to "Ant1" or "Ant2"? neither seem to work. Thanks.
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
Feb 06, 2010 | Toshiba 56HM66 56" Projection HDTV
DH Channels
I cant get all my channels on my tv. I do my channel scan but all i get is 13 channels
Mar 20, 2008 | Hitachi 57F510 57" Rear Projection...
NO CATV working on Curtis RT700
Yes if the unit is capable of picking up cable, there is a channel setup menu in the main menu. You half to switch it over to the cable mode. it should be in the owners manual. Good Luck
Jun 28, 2007 | Curtis RT700 7 in. Portable Television
Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV Logo
379 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
