Question about Technics SUV500 2-Channel Amplifier
I have purchased a su-v460 amp and had it working for about half hour then the current drive went out then wouldn't go back on then heard a popping sound and then smoke so turned of straight away! if can help would be very happy .
5 Suggested Answers
robotek
  • 1512 Answers
SOURCE: SU-V460 cuts out at high volumes
Hi samipoyo
You need to check the amp for dry solder joints about the output stages. These amps are notorious for soldering going bad. I would set about re-soldering the entire output stage.
I am more than happy to answer any other questions you may have about it, just give me a hoy :) If you are still unsure, or have problems, then before you give a rating for this advice, please get back to me and we can try some more things.
Thanks for using FixYa, If you consider the advice I have given you as sound, a FixYa rating is a great reward for my efforts to help you. Cheers.
regards
robotek
Posted on Jun 17, 2008
SOURCE: Technics SU-V460 Amp Problems
Problem with older equipment is that mechanical switches corrode. Try some tuner cleaner on switches. One side cutting out may require the speaker leads (inside the cone of speaker) to be re tinned. Old speakers and lossa mileage cause solder to break up into powder. Re tinning the flexible link (looks much like a wick) allows that electricity to get into the speaker coil. If all else fails those old TV repair shops actually do have real techs that can fix it. Not like the current Geek Squad type of replace replace reboot replace type of tech. Good luck. Ed
Posted on Jan 05, 2009
  • 280 Answers
SOURCE: when i turn up the amp the 'current drive' cuts
Check all your wiring for short circuits, check your speaker coils are not shorted either - if you cant do this try any other pair of speakers on the system.
check the main capacitors in the power supply, check the internal fuses, and change the wall plug fuse - check all the large capacitors for closed/short circuit or cracked solder joints, resolder anything suspicious looking. the fuse could be **nearly** blown, and bend apart when it gets warm, change it to be sure... hope this helps.
Posted on Jan 25, 2010
Grubhead
  • 5391 Answers
SOURCE: I have a Technics SU-V460 Integrated Amplifier that won't stay on....the power button doesn't stay pushed in. When I hold it in, it works but the button makes a crackle sound.
It sounds like the switch might be broken. It might need to be replaced.
Posted on Dec 09, 2012
Technics su a900
I have the same TECHNICS SU A900 MKII as you are talking about and it always runs warm I think using 4R speakers instead of 8R speakers should solve the problem and actually I am thinking of switching to 4R as well.
Oct 13, 2013 | Audio Players & Recorders
Sharp Aquos 37" LCD TV sound quit
You could open up the TV and look for signs of burnt components then try to replace the components or try to find a replacement for the entire affected board on ebay or something. If you can find out what the problem is maybe the service person will lower there price. $600 does seem very steap, it should be something closer to $60 an hour with maybe the first $60 as an estimate.
Feb 26, 2008 | Sharp Aquos LC-37GD6U 37 in. LCD HDTV
Technics su-v460 amp wont turn on. no power light
Check an look around for fuses. Broken Power switch? Mains Transformer failure?
Sep 30, 2013 | Audio Players & Recorders
How to program #49556 te158wta my add: gd659@cgocable.ca
Woods 49556 / TD1300 manual
http://waterheatertimer.org/pdf/Woods-49556-TD1300.pdf
http://waterheatertimer.org/Woods-timers-and-manuals.html
How to program timer.
Plug timer in until rechargeable battery is charged and display shows.
Unplug timer to program
Set current time.
Hold in reset button for two seconds to clear memory
Press and hold TIME button to select 24 hours so there is no problem. Release Time button.
Press and hold SET button.
MO is flashing, and represents MOnday. TU for TUesday. WE TH FI SA SU
Continue holding down SET button, and press ? ? until current day displays.
Release SET button.
Press and hold SET button again, and Hours will flash
Continue holding down SET button, and press ? ? until current hour displays.
Release SET button.
Press and hold SET button again, and Minutes will flash
Continue holding down SET button, and press ? ? until current minute displays.
Release SET button.
Press SET button again and current time and day will display.
Programing overview:
Set up to 20 on-off programs.
You can select individual days, or groups of days, or all days of the week
For example MO-SU is all days of the week
For each ON time, you also must set OFF time.
So program1 ON is set, then program1 OFF is set
Each ON is set for day, hour and minute
Each OFF is set for day, hour and minute (select same days for OFF and that you chose for ON)
For example if you want timer to turn ON all days MO-SU, make sure OFF time is also set for all days MO-SU.
Program the timer:
Set ON
Press arrow? until display shows PROG 1 ON
This is program1 ON.
Press SET button, but do not press and hold set button as you did when setting current time.
The days for program1 ON will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 ON.
Press SET button again, and program1 ON hour will start flashing
Press ? ? to select hour that you want for program1 ON.
Press SET button again, and program1 ON minute will start flashing
Press ? ? to select minute that you want for program1 ON.
program1 ON is set, next you must set program1 OFF
OFF
Press arrow? until display shows PROG 1 OFF
This is program1 OFF.
The days for program1 OFF will be flashing on display.
Press ? ? to select day, or groups of days that you want for program1 OFF.
Press SET button again, and program1 OFF hour will start flashing
Press ? ? to select hour that you want for program1 OFF.
Press SET button again, and program1 OFF minute will start flashing
Press ? ? to select minute that you want for program1 OFF.
program1 ON and OFF are set, next you will set program2 ON by repeating steps above.
If you do not want to set more programs, that is fine.
Timer lets you set up to 20 programs.
Finish programming: when program ON-OFFs are set, press TIME button and current time displays.
Last step:
Push manual override button until AUTO is displayed. This will let timer turn lights on and off.
Plug lamp into timer.
Lamp must be turned ON.
Plug timer into wall.
Dec 04, 2010 | Woods Hardware & Accessories
It went pop screen went black no power serge
If you heard a popping sound chances are your lamp went out on you.You can purchase a quality replacement lamp at discount-merchant.com
Apr 15, 2010 | Hitachi 50GX30B 50". Rear Projection...
Heard a loud pop and picture went out. Still have sound
Ur tv have burns capacitors,look for pop ups caps.
Oct 22, 2009 | LG 42PC1DA 42 in. Plasma HDTV
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Hi samipoyo
regards
robotek
Apr 30, 2008 | Technics SUV500 2-Channel Amplifier
Hi There, you need to eliminate all the connection and surplus items around the SUV-460 amplifier to determine if its the amp or not..
That is disconnect every thing then connect just the speakers and an input to the amp like a CD player or radio input. Then see if the amplifier plays OK thru the speakers on both channels and the balance control works fine....If it doesnt then the fault is inside the SUV-460 but if it all works fine than start reconnecting theemixer panel carefully and recheck all your cables and connections. Its a process of elimination to determine if its a "Box" fault or a cable fault...
Cheers From YUBEUT
Nov 14, 2007 | Technics SUV500 2-Channel Amplifier
Technics SUV500 2-Channel Amplifier Logo
251 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
