PDR-509 Audio-CD recorder doesn't recognize any type of CD
I have this since 2000 and it used to work great. Used to use it a lot too! Around 2003, I wasn't using it as much, and was moving. So I had it professionally cleaned before warranty was over. After that, I noticed CD would sometimes skip when playing. Didn't notice problems when recording though. But almost stopped using it completely.
Last time I used it was around 2005 and last recording was before that. Still, it worked!
Now I tried to use it and whatever I put in it (Audio CD-R or commercial music CD), the system scans it for a long time, and front panel switches between "CD", "CD-R", "Data" and "CD-RW" before finally displaying "CHECK DISK" and not doing anything!
So it won't play, won't record, won't do anything!
Nothing major happened to the unit to explain why it suddenly stopped working.
I wish I could make it work without bringing it to a repair shop because I don't have the money. If I absolutely need to, I'd like to know how much it would cost (approx. of course, a small part would cost less than the whole electronic board).
  • 2961 Answers
SOURCE: Sony DW-Q30A Problem
the dvd writer needs to be replaced,the laser is faulty or miisaligned, the cost of a repair is no longer viable because a new one would cost about $60 (£32.00)
Posted on May 30, 2007
SOURCE: Recording Errors
easy fella
sounds funny but ive got the exact same problem with the same machine but by the sounds of it philips aint that good for recording from a cd form from that model anyway!!
theres an old skool mix that i wana put out, but it will only play back on the recorder not on another source, ive managed to open the file up with nero show time on the pc thou and it will also play but just cant manage to convert to mp3 as the file is a wpl or something...
well annoying if you ask me
hpe thats helped a bit
Posted on Feb 04, 2008
  • 440 Answers
meens fan problem ok thx nick use lens cleaning cd also ok
Posted on Feb 11, 2008
  • 1447 Answers
SOURCE: need a manual or need to know how to work the recorder
Check this this might help:
Posted on Apr 29, 2008
  • 85 Answers
SOURCE: "NO READ" on Panasonic DMR-EZ27 DVD Recorder
good day 2 you,, ,, i have some little advice on you,,
just open the top cover of your player and check the RIBBON WIRE of the LENS/EYE part then clean theGOLD FINGER/LINES
and get some clean cotton buds and a lighter fluid 2 clean the lens,,,,,ok,,
PS. dont use cd cleaner fluids,,, that wont clean, , , , , ,just lighter fluid ok!!!
Posted on Sep 22, 2008
I have a Pioneer PDR 609 CD recorder. I put a disc in and it says Pro disc din unlock.
This is nearly always due to cable problems. I think the cheaper optical cables can get 'kinked' quite easily, which would stop the signal coming through properly. So, first check your settings to make sure the correct cable type has been selected. If that's OK, try replacing the cable with a good quality one.
Jan 02, 2014 | Pioneer Computers & Internet
Have pioneer pdr-509 will set up for recording, but recording levels are very low with level knob cranked up. no recording levels lights.
A lot of that depends on your external device. What is it? Please don't say it's a turntable.
When you say it won't set up, what DOES it do?
Register and download the manual for free
Mar 03, 2011 | Pioneer Audio Players & Recorders
Yes. Iif you get an audio CD recorder like a Pioneer PDR-509, HHB-30, for example, you can record from any number of sources onto a CD in as many sessions as you like until you finalize it.
Jan 10, 2011 | Audio Players & Recorders
How can you CD record from phono
One way would be to get a CD audio recorder. Google 'cd recorder'. There are many out there. I've had a Pioneer PDR-509 since 2001 and am very happy with it.
Consumer machines require CD-R Audio media which are slightly more expensive than standard CD-R's.
A turntable capable of self -pre-amplifying it's output to a usable Line Level; or a standard TT routed through a receiver with a Phono Preamp will create the audio signal that the recorder would record.
Feb 15, 2010 | Audio Players & Recorders
HHB burn it...I record on coaxial from Tascam DAT. 1st five tracks are great but the 6th track sounds horrible like there is a scratchy sounding distorted delay. It does this every once in the while . What...
I had this happen a lot on my Pioneer PDR-509, which is pretty much the same machine, when using marginal mongrel-brand CDR's. It's annoying but I have seen nothing to explain or detect it in real time so something can be re-recorded.
Nov 17, 2009 | HHB BurnIt CDR830 CD Recorder
How do i hook up my tascam 414 portastudio to my PC??
Assuming you want to keep your recordings at the highest possible quality, wouldn't it also work if you had an outboard component CD recorder? That way you retain the highest resolution at the first analog-digital step and once it's on CD you can rip to your heart's content or run it through the mixer again.
I have a Pioneer Elite PDR-509 that I have used for years. There are several 'professional' decks made by Tascam, Marantz, HHB and others that add the ability to use vanilla CDR's and CDR/W's instead of CDR-Audio and CDR-A-R/W media as mine uses and some can defeat the SCMS codes so you can do digital-digital multiple generation copies. Home audio CD Recorders will only digitally copy a first-generation digital original, unless the source was was made on a PC. Then it's always considered first-generation. The cost of the media isn't that much different these days. A standalone CD Recorder would also let you digitize those LP's and tapes you have hanging around or record Live through your mixer to CD. How about that!!!
There are plenty of them on eBay cheap and I'm still looking for the right one in case mine should ever decide to die. I see 7 pro models right now on eBay. I'd look for one that has Coaxial Digital inputs and outputs as well as Optical ones.
As for hooking up your Tascam, that would depend a lot on what sound processing software and soundcard you have - not my strong suit as I still do everything in the analog domain prior to cutting the CD and then ripping it to MP3 for portability and fast access. The physical hookup would be Line Out to Line In. After that it's all software.
Apr 30, 2009 | Tascam Starter Pack for 4-Track Cassette...
Wont record on blank pc disks!
I had the same problem and found that I was using the wrong type of CDs. If you look on the CD you have to use the CD that says Compact disc digital audio Recordable or Compact disc digital audio Rewrittable. After I used the Digital ones I could record on it. I then tried the CD on the PC and it worked. You can look on the top of the unit and see the information if you still have it. Hope this helps you.
Feb 23, 2009 | Pioneer PD-RW839 4-Disc CD Recorder
Tray B of my RCA CD Burner does not recognize any CDs
Are you using the correct disc type??
The manual states that only discs that are labeled:
"Compact Digital Audio Disc Recordable" (Audio CDR)
"Compact Digital Audio Disc Rewritable" (Audio CD-RW) can be used.
The popular discs labeled "Compact Recordable" and Compact Disc "Rewritable" are for use in computers, and can NOT be used on the recorder.
Page 16 of the manual shows the graphic of the logos detailed above. The manual can be downloaded for free below:
Feb 23, 2009 | RCA CDRW120 2-Disc CD Recorder
Pioneer PDR-W839 Disc Changer Jammed
look for a small pinhole and insert a pin while powered up to reset the device
May 26, 2007 | Pioneer PD-RW839 4-Disc CD Recorder
160 people viewed this question
