Question about Toshiba E-Studio 3511 Color Copier
Keeps asking for black toner even after changing toner
Printer keeps askinf for black toner even after the toner has been changed??
  • Anonymous Mar 27, 2014
    I've installed a new toner but the machine keeps ask to install new toner. Is there a code to initialise the toner
    President:
  • Toshiba Master
  • 990 Answers
Hello sir; on the black developer unit have senser call toner end senser that one defective have to replace it.
Posted on Apr 20, 2009
My ricoh mpc 2500 keep saying add black toner whereas there is toner in the toner bottle
If asking for black toner did you change rt toner pump should been one behind the black dev unit. Sometimes when you change it might have to open and close front door. A couple of times make sure you leave it open long enough that it think you change bottle
Feb 19, 2015 | Ricoh Office Equipment & Supplies
There is no toner when there is in the toner cartridge
replace the image unit for that color and replace the toner cartridge with oem cartridge
Jan 30, 2014 | Konica Minolta magicolor 2430 DL Laser...
Dell 3100n keeps saying "Change Black Toner" even
Before installing a new toner, put a disposable towel over the ink toner exit, and shake your toner lightly back and forth and up and down. Make sure your toner cartridge is in the open position before replacing it in your printer.
If you are using a refillable ink cartridge, make sure you are resetting the cartridge using the method described by the refillable manufacturer.
If this does not answer your question please request more information before voting on my answer. I will try to find more information about your toner cartridge that will help you futher.
Nov 16, 2010 | Dell 3100cn Laser Printer
I have a samsung clx-3160fn printer I replacEd blk toner and it keeps sayn invalid toner .... I even refilled old toner and same error... Invalid toner
I have the same problem in a CLP-300. I have tested 3 diferent aftermarket chips from different manufacturers and always the same message: "invalid black toner" and the black toner light keeps red
Sep 21, 2010 | Samsung CLX 3160fn All-In-One Printer
I have change the black toner but it is still asking me to change the black toner
Have u placed the cartridge properly. check the connections on cartridge for cleanliness.
Jun 27, 2010 | Xerox DocuPrint C525A Laser Printer
If i have run out of cyan coloured toner, can i print only black somehow? the printer doesn't want to print at all (even on mono colour selection), and keeps asking to replace toner cartridge
There are few printers if any one toner ink is finished it does not print any more. So you must replace the toner or refill it then it will work.
Jun 12, 2010 | Brother MFC-9420CN All-In-One Laser...
Line problem
if you heaving line on every page and the same area so i advice you to change your toner or change your toner drum OR tefflon ask any local repairing center to change your toner drum OR tefflon
This will help. Thanks please keep updated. please do rate the solution positively .Thank you for using Fixya
Regards
manish
Mar 25, 2010 | Canon Selphy CP510 Thermal Photo Printer
Color toners are empty
Press Green Tick, Right, -> System Setup -> Right, Right, -> Print Quality, Right -> Replace Supplies. Change from stop at out, to override at out. It'll let you print, and you'll get loads more out of your toner before the pages start to fade.
Dan :-)
Sep 30, 2008 | HP Color LaserJet 2600n Printer
BLACK SMUDGING
Hmm... This sounds like it is a toner problem. If your roller is getting too much toner then it just globs it onto the paper even though the drum is not asking for it. Are you using a new toner cartridge or a re-filled one? Is it from Brother or a 3rd party? I suggest you remove the toner cartridge and check inside the printer. Clean any spilled toner. Check the toner cartridge for leaks .. give it a good shake and see if it is leaking. If you have another toner cartridge, you can replace it to test. You may need to pint a few pages to see a change. Another test could be to print a few (2-5) "BLANK" pages. The printer should not be depositing any toner. If no smudge or the smudge stays the same, then the toner cartridge is the likely problem. If the smudge is there, but gets smaller, then clean your printer.
Jan 10, 2008 | Brother HL 2700CN Laser Printer
Toshiba E-Studio 3511 Color Copier Logo
160 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
