Question about Zonet ZSR1104WE Wireless Router
Hello there..!!! I would like you guys help me.. I've been trying to setup my router, but any admin and pass it is working... *admin 1234 *admin 000 *administrator password *etc etc.. Please none working..i need your help !!!! Thank you...
    President:
  • 623 Answers
Did you change the password by yourself? By default both the username and password are admin.
Good luck and if this doesn't work for you or you have any more questions, just come back here and leave a comment - I'm happy to help.
Posted on Apr 20, 2009
I had a computer person set up our router before, but we have moved and now I want to set it up myself a different way. I want to have access to wireless internet. Initially I was able to put in the IP...
You probably disabled http and https admin. Locate the reset button on the back and hold it for 10 seconds. Reset maybe located in a pin hole on the back, use a pin or paper clip to press it. Refer to the setup doc for default user/pass. Typically admin/admin.
Comment back if you need further assistance.
Aug 31, 2011 | CP International WBR-3406TX Wireless...
Forgot passward
Hello.
You can always reset the router and use default authentication. (user: admin; pass:admin or user: root; pass : root or user: admin; pass: (blank), etc)
To reset the router it must have a small button that needs to be pressed for 10 seconds or so.
All the best !
Aug 06, 2011 | Computers & Internet
I cant log into my planet wireless router wrt-416 (192.168.1.1) i reset my router because i cant remember the username and password it was configured. please can you assist me how to resolve this problem
Hello !
Usually on routers, on the back of the device you should have a "default login". If you do not, USUALLY, the user is either "root" or "admin" and pass "". (blank pass).
Update : I checked out your model and it says the default credentials are:
User : admin
Pass : admin
Hope that helps !
All the best.
Aug 03, 2011 | Computers & Internet
Passwod
Hi!
Default username/password are:
Username: none (leave blank)
Password: admin (all small letters!)
If you've changed the default password, you'll have to reset the device, using the reset button on it's back.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Best regards,
Pelu.
Apr 21, 2011 | NetGear DG834G Router
Need to secure my router
Try the following procedure on a computer that's directly connected to one of the router ports with an ethernet cable. This procedure will not work if you're connected wirelessly. Open a web browser, such as Internet Explorer, and type in http:192.168.1.1. A window should pop up asking for a user name and a password. Don't enter a user name and type admin for the password. Hit ok. The router setup screen should come up. Click on the Wireless tab and then the Wireless Security sub-tab. You can set up encryption on your wireless network using this screen. First select the security mode you want to use. I believe WPA gives better security but I've had some trouble using it on older computers. I use WEP. I've been able to get this encryption scheme to work with all of my computers. Next select the type of encryption. I like 128 bit 26 hex digits. Next enter a pass phrase and hit generate. The pass phrase is like a password. It should now generate four 26 character keys made up of various letters and numbers. Write down the first key and make sure you've checked the 1 box for default transmit key. Save your setting and exit. You wireless network is now secure. If you try to connect to it using a wireless device you will be prompted for a security key. Depending on the operating system you're running, you may just be able to enter the pass phrase or you may need to enter the 26 character key you wrote down. You should only have to do this once for each of your wireless computers. After the first time the computer connects to the secured network it should automatically remember the security code. I hope this advice helps you out.
Apr 19, 2011 | Linksys Wireless-G WRT54G Router
Hello, my password and username for the Router
how the button in again for 5 - 10 sec's until all the led lights start blinking.
the default login/pass
should be
admin/admin or admin/blank
Mar 09, 2011 | D-Link DIR-615 Wireless Router
Linksys wrt150n
username is blank and password is admin.
However I have seen some routers not follow that. Those will sometimes have a username of admin with a blank password. Try the first one first.
Mar 09, 2010 | Linksys Wireless-N WRT150N Router
Default factory pass fails while cannot be reset
There should be a reset button on the back of the router. Once you locate it press it in and hold it down for a few minutes to reset the router to factory default. Then try logging into it.
Nov 22, 2009 | D-Link DVG-G1402S Wireless Router...
Secured on network
CHECK YOU LAN SETINGS,IT SHOULD HAVE AN STATIC IP TO SUCCESFULLY CONNECT TO YOUR ROUTER AND CONFIGURE IT.THE DEFAULT IP OF THE ROUTER IS 192.168.0.1.
Sep 11, 2009 | D-Link AirPlus DI-524 Wireless Router
Setup problem
The admin user name and blank password, is a default setting of the dlink, perhaps somebody would have changed the default setting on it, Hence Please press the reset button and reset the device to factory defaults, you may need to press the reset button for 30 secs and once the reset is done, Unplug the power for 120 secs and then turn it back on. And now you can try the same, I strongly feel that it should work now, Furthermore the settings saved on the router would be set to factory defaults hence, you may need to configure the router/Modem for internet connectivity.
Kindly let me know the Kind of internet service that you are using for 'Help with modem/router configuration'
Happy Troubleshooting!!
Mar 15, 2008 | D-Link DI 514 Wireless Router (DI-514)
Zonet ZSR1104WE Wireless Router Logo
149 people viewed this question
Top Zonet Computers & Internet Experts
Prashant M
Prashant M
KG John Justin
KG John Justin
Are you a Zonet Computer and Internet Expert? Answer questions, earn points and help others
