Can I use a WD1600 as slave drive and Maxtor 6Y200P0 as master? If I can what are setting on Wd1600.
  • 37 Answers
You just need to put a jumper on the pins on the side of the hard drive that is marked on the label to SLAVE, then connect it to the ribbon and power.
See document below for extra help:
http://www.seagate.com/ww/v/index.jsp?locale=en-US&name=ata_jumper_settings&vgnextoid=cbc974850ce0e010VgnVCM100000dd04090aRCRD
Posted on Apr 20, 2009
  • 89 Answers
I havent read it but here is the linkhttp://www.techspot.com/vb/topic126243.html
please rate my assistance
I wish to us a WD1600 (caviar) hard drive fopr extra storage in my pc the drive came from my old PC there are eight pins to choose from. Where do I place the jumper?
Well, if this hard drive is SATA and looks like this:
Then you don't need to worry about the jumpers at all, the hard drive is ready for use in your PC.
However, if it's IDE, which looks like this:
You will need to move the pins to the "Slave" setting, and on Western Digital drives it is one set of vertical pins going away from the 4 pin power input, the above picture is set for Slave mode, and can be used as a reference.
May 05, 2011 | Western Digital Caviar WD1600 (1600YD) 160...
Hi i have a western digital wd1600 160gb hard drive last year i used the hirens boot disc to completely wipe my hard drive and repartition the drive but now when i try to use my western digital tools for...
Have you tried setting the jumpers on the new drive to CS (cable select) If you use that setting, the position of the drive on the cable determines whether it is master or slave. For example, the plug at theend of the IDE cable is the master and the plug in the middle of the cable would be slave. Just a suggestion. If you are using SATA, this does not apply.
Jul 18, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Is not being regonised
unplugg and re plug the hard drive and make sure that the pin out is set to MASTER! not!! cable select or slave! then open bios on reboot and see if it shows up in there
Jan 14, 2010 | Western Digital Caviar WD1600 (1600YD) 160...
Obtained a used Maxtor 6Y200P0 (DiamondMax Plus9) hard drive which should have 200GB (as advertised), but only 34GB is available. Reformatted the drive, but still only has 34GB. Verified it is not a...
Hi:
You didn't say what kind of computer you are installing this drive in, or what operating system, but I can tell by your problem that you are trying to install it with a Windows xp, service pack 1 or older system disk. Often, the older windows disk will not let you see the entire contents of a large disk, and especially a problem if a smaller Hard drive is still present in the system.
A good solution to fix this problem is this:
Temporarily unplug your Seagate hard drive. Download the Maxtor installation software from their website, and then run the installation program. Once you got that, then power down the computer, and do your master slave set up again, and hopefully you will have better results
Nov 18, 2009 | Maxtor DiamondMax Plus 9 200 GB Hard Drive
IT LIGTHS UP BUT CAN'T GET MY COMPUTER TO RECORNIZE IT
TRY TO CHANGE MASTER SLAVE JUMP AND GIVE MORE INFORMATION TO HELP YOU
Jul 15, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
When i plug it into my computer, and i go to disk management is says that i have to intializes the disk. when i try to do so it says that it is not ready how do i solve this please?
Get hold of UBCD (Google it) and use the utilities on that - at the same time check that you have set the drive's Master/Slave/CS switch accoringly, and used the correct cable (should the highest possible for the type of drive bing installed. If you can see the drive in the BIOS go straight to UBCD and use that.
Jul 05, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Jumper settings wd1600
yes, you are correct.
Feb 20, 2009 | Maxtor Hard Drive
Can I use a WD3200AAJS as a slave drive. If so what is the jumper configuration.
Hello!
The drive you have is a SATA drive, and has no master/slave configuration as such.  There is a connector block on the back to configure other options such as spread spectrum clocking.  Normal configuration is a jumper between pins 1 and 2 (all the way on the right side, facing the back).  A picture of the other configuration options is shown below.
Hope this helps you out,
Ken
Jan 07, 2009 | Western Digital Caviar WD1600 (1600YD) 160...
Format harddrvies western digital wd1600
try using the dynamic drive overlay supplied with the drive? Your MB may not be able to handle it.
Aug 12, 2008 | Western Digital Caviar WD1600 (1600YD) 160...
Computers & Internet Logo
172 people viewed this question
David Payne
David Payne
