Question about HP DC170B Keyboard
Locked keyboard buttons
My keyboard is locked and when typing i have to press the fn button for normal letters to be typed how do i unlock it
  • 2,229 Answers
You need to find the special function key that, when used with the Fn key, locks the Fn function on. On my keyboard it's the F11 key.
Press the Fn key and that key and your keyboard will return to normal.
Posted on May 21, 2009
2 Suggested Answers
  • 38 Answers
SOURCE: locked keyboard buttons
If the wrong characters appear when you are typing or you are trying to use a keyboard that is different than the one that came with the computer, use the following steps to synchronize Windows to the type of keyboard you have:
  1. Click Start c01311982.gif , and type region into the Start Search field.
  2. Select the Keyboards and Languages tab.
  3. Click Change Keyboards .
    A Text Services and Input Languages window opens.
    Figure 3: Change Keyboard button
  4. Click Add .
    Figure 4: Add button
  5. Select the keyboard(s) you want to use and click OK .
    Figure 5: Add input language: US Dvorak keyboard selected.
    The new keyboard is added to the list of available keyboards and a keyboard icon appears on the system tray, allowing you to switch between the keyboard that you want to use with the mouse.
    Figure 6: Keyboard tray icon
  6. From the Text Services and Input Languages window, select the new keyboard in the list and click Move up until it is first in the list. This makes it the default keyboard.
    Figure 7: Move up button
  7. Click OK . You can now use the new keyboard. If you find that the new keyboard works well and you do not want to use the other keyboard, repeat these steps and Remove the keyboard that you do not want from the General tab of the Text Services and Input Languages window.
Posted on Aug 03, 2009
How i can enble function key
HP laptops have the ability to lock the blue special function keys on, making numerical data entry easier on laptop models that do not have the room for dedicated numerical keypads. Because the key combination to lock the function keys is so simple, however, it is easy for those who wouldn't normally use this ability to do so accidentally. When the function keys are locked, pressing certain keys will result in numbers being typed rather than letters. Unlock the function keys to alleviate this issue.
Press the "Fn" and "Num Lk" keys on the keyboard simultaneously. The "Number Lock" indicator light should turn off, indicating that the letter keys will once again type letters when pressed. This combination should work on the majority of recent HP laptops. If it does not, try one of the alternate key combinations in this article's remaining steps. Press the "Fn" and "F11" keys simultaneously, then attempt to type a letter. If the combination does not work, continue to the next step. Press the "Fn" and "Scroll Lock" keys simultaneously, then attempt to type a letter. Continue to the next step if this does not work. Press the "Fn," "Scroll Lock" and "F11" keys simultaneously.
Jan 16, 2013 | HP 4440s Probook
Laptop types numbers instead of letters
Hi!
You have enabled NUM LOCK. Press button "fn" and find another button with blue tag "Num Lock". Pres both buttons at once.
Hope it helps
Jul 10, 2011 | Dell Inspiron Mini 10 Notebook
When i type the letters on my keyboard, the numbers show up instead. i don't know how to revert the system or functions back to normal. i must've accidentally pressed a button to change the characters when...
Sounds like the keyboard is in NUM LOCK mode
They keys map like this:
7 8 9 = 7 8 9
u i o = 4 5 6
j k l = 1 2 3
0 . = m .
Look for the NUM LOCK key on your keyboard.
Typically, you press the FN key (lower left corner) and the NUM LOCK key (typically towards the upper right) together to put the keyboard back into regular mode.
Apr 21, 2011 | Twinhead DURABOOK N15RB Notebook
I own an HP 510 laptop, when i type the function symbol on the right side of the keyboard is displayed for eg if I want an L 3 is typed, O is 6 etc. To eliminate this I must press the FN key to get the...
You have the Num Lock on.
To turn it off just hit the Num Lock key or press Fn and hit the Num Lock key to return the keyboard to normal.
Regards.
Jun 28, 2010 | HP 510 Notebook
My dell laptop types numbers instead of letters on some keys without pressing fn key
HI,
If you Are writing numbers instead of letters when you press the keyboard of your laptop and you must hold down the Function key (Fn) to write normally.
This is due to the fact that the digital lock is activated. To solve this, simply press the Fn+Numlk or depending of the model, press the button or Fn + Shift +Numlk
Hope This Helps
THANK YOU
Feb 27, 2010 | Dell Vostro 1510 Laptop
  4. Click Add .
Jun 02, 2009 | HP DC170B Keyboard
When I type a letter I i get 5 or 6 not the letter??
You've probably got number lock activated / deactivated. This is especially common if you're using a laptop computer. Look for the "Num Lock" button on your keyboard and try pressing it. If you're using a laptop and the Num Lock button is a different color, you might need to hold another key "Fn", Shift, Cntrl, etc while pressing "Num Lock".
Jan 31, 2009 | Acer Aspire 5630 Notebook
Keyboard Stuck in Function (Fn) Mode
To unlock number lock (numlk):
Depend on comp, but try pressing (at same time)
fn + f11
or
fn + Scroll/numlk (next to f12)
or
f12 + Scroll
or
f12 + Scroll + fn
or
ctrl + Shift + Scroll
or in BIOS there is a numlk option
Aug 12, 2008 | Gateway MX6124 Notebook
HP DC170B Keyboard Logo
2,992 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
