Due to the power fluctuation my dell laptop 1501 inspron's lan port or network adapter has been burned so whenever i insert network cable in it. it show the message of network cable unplugged
  • Dick
    Dick May 11, 2010
    All you can do is disable the onboard NIC and use a PCMCIA NIC instead. Unless you want to have the motherboard replaced, which is not cost effective.
  • 17 Answers
Most laptop lan ports are onboard so replacement would mean replacement of the entire Motherboard. A very costly option. I suggest buying a USB to NIC adapter from your local PC store and just use that for LAN connections.
(side note: get a good brand, cheap USB to NIC/LAN converters sometimes drop connections randomly so spend a few extra $$$ for a good one)
Posted on Apr 20, 2009
Is there a quick fix to replacing the processor fan on a Dell Inspron 1000
Not a quick fix, but you can buy a cooling base unit for it which plugs into one of your usb ports which supplies power for the built in fan.
Aug 20, 2014 | Dell Inspiron 1000 Notebook
I am using the Dell Latitude D620, When i am connecting this machine on network I am getting 100 MBPS connectivity, but when i am connecting other machine to the same network port I am getting 1GBPS...
Hi Ajay,
The LAN (wired network) connectivity speed/data rate depends upon the networking hardware (Laptop Ethernet Cards, Switch, Router etc.).
To get 1Gbps connectivity you must have 1Gbps ethernet (LAN) card in the laptops. As Dell Latitude D620 has 1Gbps card, the problem could be with the switch or router, which may be having 100Mbps and 1Gbps ports, depending upon the equipment you are using and it is recommended that you check out the its full specification. If you connect laptop to 100Mbps port you can only get 100Mbps speed. To get full speed, it is required to have 1Gbps support at both ends.
Dont forget to rate the solution if it helps!!
CreativeTECH
Dec 03, 2010 | Dell Ethernet Card Network Adapter
Bigpond have sent me my 4 port Wi-Fi modem thompson TG782T Home Network Gateway, now I am sitting here trying to figure out just where everything goes!!! I received a cd rom however I can't get it to work,...
Telephone wall-plate <---- 4-strand telephone-cord ---> telephone-port in modem
AC power from wall-plate to modem.
LAN port #1 <--- Ethernet cable --> network-port on desktop/laptop computer #1.
LAN port #2 <--- Ethernet cable --> network-port on desktop/laptop computer #2.
LAN port #3 <--- Ethernet cable --> network-port on desktop/laptop computer #3.
LAN port #4 <--- Ethernet cable --> network-port on desktop/laptop computer #4.
Configure the router's wireless adapter:
* set a SSID
* set an encryption-level, e.g., 'WPA'
* set a network password
Use the SSID/password to configure your wireless devices (iPod Touch, iPad, XBOX 360, etc.)
Nov 26, 2010 | Gateway Computers & Internet
My computer ideapad lenova,i am not able to connect to internet,one IT specialist told me that my slot for inserting cable is bad what to do i am now in china Ghanzhou city
Do you mean the slot?
Is it the cable that goes into the LAN port?
If so you can use a LAN PCMCIA card and connect the LAN cable into this card.
OR
You can connect to the Internet using a USB 3G adapter which uses the cell phone network with a cell phone provider.
Aug 05, 2010 | Lenovo 3000 Y410 Laptop
Dell Inspiron 1501 10/100 network port not working. I have installed driver and have known good cable in port. Worked until 2 weeks ago. Lights don't blink, onboard LAN turned on in BIOS.
Sounds like a failed NIC.
Things to try:
  1. Flash the BIOS to current version if not already done.
  2. Reset BIOS Defaults
  3. If NIC still doesn't work, try a system restore to a time when it worked.
  4. If that fails, most likely a hardware failure.
http://www.newegg.com/Product/Product.aspx?Item=N82E16839314004
Mar 20, 2010 | Dell Inspiron 1501 Notebook
My dell pc can't activate the connection
try to use a 3com lancard it is the most compatible lancard for dell i hope this will help
Sep 17, 2009 | Dell Ethernet Card Network Adapter
Power management related query
Some system have a BIOS settings like these. There are 2 options affecting the NIC. LAN/WLAN switching and LAN power save. Are both LAN power save and LAN/WLAN switching enabled?
On my laptop, it does the same thing as your computer when its on battery (HP laptop) except when there is an ethernet cable plugged in or loopback. I made a little loopback plug to keep the port active even when it is unplugged.
http://www.juniper.net/techpubs/software/nog/nog-interfaces/html/fe-ge-loopback25.html
May 11, 2009 | Broadcom BCM5704 Network Adapter
Problem with my lan port
did you check the cable that is it working fine???
and the other thing does your network connection shows that the local area is unplugged if it shows then it is definatly problem with the wire or Connector.
Nov 08, 2008 | Dell Ethernet Card Network Adapter
Dell 8100 ethernet will not connect off the port replicator
Let me give it a try ...
There are a few possibilities but i'll cover 2 of them :
1. There is a program that comes with your DELL that will save battery life by turning off your Network Card (LAN) I forgot what is the program name. But usually when you plug the power cable out, there will be notification at bottom right corner of your screen that told you so.
2. I don't know if your port replicator connected to power adapter (is port replicator = docking ?). The fact that your LAN connected when it's on port replicator make my first conclusion more acceptable. Since port replicator got it's own power adapter, it will just turn the LAN on.
Now if you want to check if thats the cause, just plug your notebook to it's power adapter/charger and plug your LAN Cable in. If it works than the problem is the nasty program from DELL.
If you want to disable the program just go to Startup Tab at msconfig and disable (clear the check mark) for that nasty program
Hope it helps
Oct 28, 2008 | Dell Inspiron 8100 Notebook
My laptop cannot connect to my local network (LAN)
Assuming you initially set up the router using the wired lan adapter and lead, enabled DHCP in the settings. First stand right next to your router; Dells wireless is a little tempremental, go to control panel and in there should be Dell wireless monitor, open this up refresh it and see if it finds any wireless networks, if so try to connect. Dissable your wired network lan adapter. Go to the properties of your wireless card and on the TCP/IP line click properties again and ensure that obtain an ip address automatically is selected, press ok and restart the pc.
Sep 20, 2007 | Dell 1470 (W9284) 802.11a/g/b Wireless...
Computers & Internet Logo
David Payne
David Payne
