Question about Kenmore Elite Oasis 27052 Top Load Washer
Stops before spin with error code of LF
I have a Kenmore Oasis Top Load washer that constantly displays an LF error code with every load. How can this be fixed?
  • 15,935 Answers
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
Itshows LF what do i do?
LF code means long fill on the water supply,if it takes too long to fill it will shut down,remove the water fill hoses and check for screens in the hoses and washer water connections and see if they are plugged with sediment
Aug 30, 2012 | Kenmore Elite Oasis 27052 Top Load Washer
F error code "kenmore top load" washer oasis he3
Hi
LF means Long Fill, this error flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged the basket but control does not detect a water level change. Check whether water supply is connected and turned on. Make sure the hose is not blocked and hose screen is clear. If so make sure pressure hose connection to machine/motor control is fine. Also check the continuity of water inlet valve, use a multimeter to check the continuity. Hope this helps... Please post back if you need more information.
Daniel
Feb 16, 2011 | Kenmore Washing Machines
Kenmore Oasis top loader giving us continual LF error code... how to fix?
long fill error code. might wanna clean ur screens. take the hoses off ur washer and clean the screens
Jan 31, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
Our washers keep flashing LF after the wash cyle and stops workin, not spining very fast either.
Hello there :
the Dreaded LF code means
LF Long fill If the water fill time exceeds ten minutes, the water valves are turned off and "LF" is flashed.
Press STOP/CANCEL to clear the display.
check the water controle inlet valves that are attached to the machine for proper operation and replace if found bad
Jan 07, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What do I need to do to fix the Lf code problem on my oasis washer?
Following is the LF troubleshooting response from the Whirlpool Cabrio
Service Manual. The Cabrio is the same as the Kenmore Oasis.
“LF” (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Are both water faucets turned on?
Is the drain hose sticking too far into the
standpipe (siphoning)?
Is the pressure transducer hose kinked or
dislodged?
Press PAUSE/CANCEL to clear display.
It takes a while to load but following is the manual in PDF format.
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/409753510a90c8be852571e90073421b/$FILE/8178583.pdf
Dec 02, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
What does LF means? and what should I do
See the following Whirlpool Service Manual for their Cabrio washer which is basically the same as the Kenmore Oasis.
6-1
DIAGNOSTICS & TROUBLESHOOTING
DISPLAY FAULT / ERROR CODES
DISPLAY
(Saved Code) EXPLANATION AND RECOMMENDED PROCEDURE
(F30)
Long Fill
LF flashes when the water level does not change for a period of time after the valves are turned on OR water has disengaged
• Is water supply connected and turned on?
• Are hose screens plugged?
• Is water entering the tub? If so check pressure hose connection to machine/motor control.
• See TEST #2.
Nov 13, 2009 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis has LF code on and won't reset
The LF code indicates "Long Fill" which means it is taking too long for the water to fill the washer (times out). From the owner's manual:
"LF" (Washer is taking too long to fill)
Press STOP to clear display.
Here's a suggestion I found that worked for me:
Check your drain hose to see it it's stuffed too far down the standpipe. Another poster had this problem and it gave her LF errors. If the drain hose hangs down too far it can siphon water out of the washer, and then the washer thinks it's taking too long too fill. There's supposed to be a U-shaped plastic bracket that sets the length of the drain hose where it goes into the standpipe. Your installer may have tossed it.
Apr 07, 2008 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Oasis HE 2708..LF error code
LF = Long Fill
If the water is on and screens are clean there is a test you can do to check the log valve. There should be a repair manual inside the front panel of the machine. If yo use a screw driver in the front to open the top you should find it on the inside of the front panel. Good Luck
Dec 02, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore oasis he
load full. to much load , be sure the legs are properly level . you can go to sears.com and download , the owners manual directly from their web site
Jun 10, 2007 | Kenmore Oasis HE 27082 Top Load Washer
LF error code
I had the same problem this weekend. Sears said they would have to send someone to fix it. Now I have to wait til Wednesday. It better be fixed then! It's only a month old machine, and I'm livid.
Jan 11, 2007 | Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis 27052 Top Load Washer Logo
551 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
