Question about HP Photosmart C7280 Laser Printer
Can not figure out how to print on any custom size paper
I can not figure out how to print a 5-1/2 x 8-1/2 size sheet (or for that matter any custom size sheet) on a HP C7280 printer.
  • 1 more comment
  • cwussow Apr 20, 2009
    Sorry, but I am not seeing those screens.
    1. Control Panel
    2. Printer
    3. Properties
    4. Advanced
    5. Not seeing Paper Sizes or Size List
    5a. I can see a long list on Device Settings, but Custom is not a choice.
    or
    1. Control Panel
    2. Printer
    3. Print Preferences
    4. Advanced
    5. Again, not seing Paper Sizes or Size List
    5a. If I go to Features, Resizing Options, I see a Custom, but when I click on that it gives me the message "The custom paper size you have just defined will not become available for selection until you have exited and re-entered the Print Preferences/Properties."
    Thanks.
  • cwussow Apr 21, 2009
    Redownloaded the software from HP and I am still not seeing the "custom sizes" you mention.
    Thanks.
    I've tried Word, Quark, and InDesign.
    And when I finally do see an opportunity to select "Custom" for size of paper, this message comes up.
  • 385 Answers
If you go to your printer properties, preferences or advanced, on the Main menu, is paper sizes,
click the little tab, look at the sizes list,
scroll to the bottom, and you will see.
Custom sizes by User, create your User Defined cusom size.
check your paper tray is setup correctly.
should be good now.
Regards
Richard.
Posted on Apr 20, 2009
  • 2 more comments
  • Richard Finney
    Richard Finney Apr 20, 2009
    Hi, sounds like you have a software problem there then,
    Try to re-enter like it says, if you cannot enter it.this is a fault.
    You have a software glitch, the programme is not functioning as it should do,
    If you can update the software, update it, if not
    Re-install it.
    Ric.
  • Richard Finney
    Richard Finney Apr 21, 2009
    What Application are you trying to print from please ?
    Thanks
    Richard.
  • Richard Finney
    I am at a loss why it is not letting you use this setting,
    Could you try Word please.
    There are sizes for you to set in here too.
    Try changing the settings in word
    Richard.
  • Richard Finney
How to put the paper in the printer?
Loading Paper
1 Adjust the guides to the position for the paper size you are using.
2 Fan the paper well.
Push down the paper lever. Load the paper (with the lever down). Make sure the print side is toward the fax machine and the paper level is stacked below the paper mark. The feeder can hold up to 200 sheets of paper, or up to 10
envelopes.
Acceptable Paper
The FAX/MFC can handle paper that has the following specifications.
But please note that you can receive fax messages only on Letter, Legal and A4 paper. If you use legal or A4, change the Paper Size setting: (Menu/Set, 1, 1.)
Paper Type Paper Size
Cut sheet Letter, A4, Legal, B5, A5, Executive,
Custom size 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Envelopes DL, C5, COM-10, Monarch
Post Card 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Organizer Day-Timer® J, K, L, M 2.75-8.5 × 5-11 inches (70-216 × 127-279 mm)
Labels and Transparencies 2.75-8.5 × 5-14 inches (70-216 × 127-356 mm)
Dec 20, 2010 | Brother IntelliFAX 3800 Plain Paper Laser...
How to print a custom size paper on HP Laserjet 2550 I used to be able to print pretty much any size of the paper with this printer, but now, I can not even find the ''Custom'' for the paper size in the...
USe the Page Setup in the word processor. It is how the word processor uses the printer that matters. There you will find Custom and you can specify the page size.
Nov 17, 2009 | Office Equipment & Supplies
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Printing a custom size card with a C7280,
There is a workaround for this problem by tricking the printer.
The paper sensor, on my printer model hp4500 seems to only sense the paper at the beggining of the print job.
What I did to trick the printer to print on odd size paper is slide the paper adjuster to 8.5 and put a regular white sheet in. Then put your odd size paper under it. When you print your document set the number of copies to 2 and print. The printer is going to sense that the paper is correct, and start the job.
Here is the tricky part... once the first 8.5x11 sheet is almost all the way through quickly slide the paper adjuster over to match the size of your odd width paper. The printer should pick up the odd paper and print the second copy. Fool you printa! You should be able to do batches of odd paper size under the first 8.5X11. I hope this helps.
Deny
Jun 05, 2009 | HP Photosmart C5180 All-In-One InkJet...
I need to print on 5 x7
Go into the print settings and change the size of the document there. The printer may be set to 5x7 but the document you are printing isn't.
Jan 10, 2018 | HP PSC 1315xi All-in-One Printer
Canon mx850, paper jams when reloading for two sided copies. once the 1st side is printed the paper is released, recaptured and starts to feed back into the prt. 1/3 into the feed it jams, paper is...
Mel, this is what I found in the online manual:
Set the Ink Drying Wait Time longer.
Doing so gives the time enough to dry the printed surface so that paper curling and ink blots are prevented.
(1) Make sure that the machine is turned on.
(2) Open the printer properties dialog box.
See Opening the Printer Properties Dialog Box Directly from the Control Panel.
(3) Click the Maintenance tab and then Custom Settings.
(4) Drag the Ink Drying Wait Time slide bar to set the wait time, and then click Send.
(5) Confirm the message and click OK.
Make sure that the actual size of the paper is suitable for automatic duplex printing.
The sizes of media suitable for automatic duplex printing are A4, Letter, A5, B5, and 5" x 7".
Load paper of suitable size and then press the OK button.
Make sure that the Page Size or Paper size setting matches the actual size of the paper with a size suitable for automatic duplex printing.
First, check the Page Size or Paper size setting in the application software you are printing from.
Then, check the Page Size setting on the Page Setup sheet in the printer properties dialog box (Windows) or the Paper size setting on the Page Setup dialog box (Macintosh).
Note
Depending on the version of the application program, the automatic duplex printing may not be supported.
Make sure that the type of loaded paper is suitable for automatic duplex printing on the Main sheet (Windows) or the Quality & Media sheet on the Print dialog box (Macintosh).
Note
To switch to manual duplex printing, follow the procedure below.
Open the printer properties dialog box, clear the Automatic check box on the Page Setup sheet, and reprint.
When performing manual duplex printing, note the following.
If you are printing three or more pages of a document with manual duplex printing, one side of all sheets of paper will be printed first. Turn over the paper and reload the paper in the machine, and then the reverse side of all sheets of paper will be printed. Be careful not to change the order of paper in the stack.
The procedure for reversing the paper varies depending on the staple side and printing orientation. Follow the on-screen instructions.
MX850 series On-screen Manual for Windows:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=DownloadDetailTabAct&fcategoryid=334&modelid=16279
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Mar 11, 2009 | Canon PIXMA MX850 multifunction InkJet...
Problem Printing Sheet Paper with the Epson 9800
On the machines control panel set to sheet fed (pressing the left button will change from Sheet, roll and roll with cut). In the print settings select your paper profile. On the page setup choose sheet. In the pull down menu you should only have basic paper sizes, no custom size. choose 20x30 and try again.
let me know if this helps
Feb 02, 2009 | Epson Stylus Pro 9800 InkJet Printer
How to change paper size on axerox phaser 8500
From a Windows Operating System:
  1. From the computer, open the document to be printed within an application program.
  2. Click on [File] on the toolbar, and then click [Print]. The Print window will be displayed.
  3. Click on the [Properties] button, or the [Printing Preferences] button. The Properties or Printing Preferences window will be displayed.
  4. Click on the [Paper / Quality] tab.
    NOTE: Most applications will automatically provide the page size information to the driver. If not, steps 8 - 10 describe how to create a custom page size.
  5. Select the required paper size from the Document Size pull down menu, if available.
  6. If the required custom paper size is not available click on the [My Customer Sizes…] button.
  7. To create a new custom paper size setting click on the [New] button.
  8. In the Name field enter the name to be given to the custom paper size. For example 127 mm x 394 mm (5 in. x 10 in.)
  9. In the Width field enter the width of the custom paper size.
    NOTE: The width should always be the short edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the width must be set to 127 mm (5 inches) regardless of the orientation of the document or the feed method on the printer.
  10. In the Height field enter the height of the custom paper size.
    NOTE: The height should always be the long edge of the paper. For example, if the custom size is 127 mm by 394 mm (5 inches by 10 inches), the height must be set to 394 mm (10 inches) regardless of the orientation of the document or the feed method on the printer.
  11. Click on [Save]
  12. Click on [Close].
  13. Select the required paper size from the Document Size pull down menu.
  14. Click on [OK] twice to print
From a Mac OSx:
  1. Click on [File] on the application toolbar, and then click on [Page Setup]. The Page Setup window will be displayed.
  2. From the Printer Description pull-down menu, select the correct PPD file for your printer.
  3. Select the custom paper size for your document from the Paper Size pull-down menu.
  4. If the required custom paper size is not available click on the [Manage Custom Sizes…]. The Custom Page Sizes window will be displayed
  5. To create a new custom paper size setting click on the [+] button.
  6. Double click on [Untitled] and enter the name to be given to the custom paper size.
  7. At the Page Size field enter the width and height of the custom paper size.
  8. Click on [OK] twice.
Apr 22, 2008 | Office Equipment & Supplies
Epson Stylus Pro 2200 printer help
I have the same problem with custom sizes. Also, some sizes are unavailable. I did get a custom size working by setting the margins to .25,.25,.25,.45,
Apr 13, 2008 | Office Equipment & Supplies
Paper size problem
hi there, your problem is in page setup. make a custom size and it will print inside your paper sheet. ty
Dec 24, 2007 | Epson LX-300 Matrix Printer
HP Photosmart C7280 Laser Printer Logo
983 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
