Question about Maytag Atlantis MAV6451 Top Load Washer
Washer stopped We began to wash a small load of clothe. The machine started working well then it simply stopped. The clothes were still in it, and it would not work.
  • jsweater Nov 27, 2007
    I have a Maytag Atlantis Top loader. The lid switch is malfunctioning. I have been able to run the wash by inserting a bent coat hanger but it is an obvious temp fix. Short of paying a repair man to come fix it, does anyone here have any solutions?
  • linmc Dec 01, 2007
    Same problem, washer filled with water, and just stopped. I looked at the lid switch, and I think it's broken off. Any easy way to repair?
  • 291 Answers
Sounds like might be the lid switch... these washers are  well know for lid switch problems,
Posted on Oct 27, 2007
Starts to spin then stops and sounds like it shuts off
You are probably overloading it. When it stops just open it, take some clothes out and rearrange the clothes in the washer so that they are as evenly spread as possible. Close the lid back. It should cycle on again. If it does not, repeat the same procedure. When the weight/ bulk of the clothes is small enough for the machine to handle it should then complete the cycle/wash.
Apr 04, 2014 | Kenmore 24032\24036 Top Load Washer
Why wont my amana washer start at all?
My washer will notwork it will not let the lid lock are fill with water
Jan 20, 2013 | Amana NTW4501XQ Top Load Washer
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
Small cloths are going between washing drum and
you nead to be aware that when you put clothes in your washer you have to understand that you only put cloth's in that you do not have push down.if yopu over load your washer,the water will come in and the cloth's will rise faster than the water come's in,that will alow cloth's to get into the outer tube and block your water pump.
Oct 09, 2009 | Whirlpool LSR5132PQ Top Load Washer
Rubbing and Clicking Noise in Dryer.
It's noisy Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth
Mar 07, 2009 | Kenmore 98702 Stacked Washer/Dryer
Whirlpool Duet Sport not running it makes clicks and it grinds
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.=======
Dec 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Maytag Atlantis MAV6451 Top Load Washer Logo
151 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
