Question about Sylvania 6842PF 42 in. EDTV-Ready Plasma Television
Sylvania 6842PF M screen turning dark red
I have a 42" Sylvania plasma 1.5 years old. Periodically, the picture will turn a dark red color. I have tried to adjust the cables, etc, but it does not change anything. After 1-2 min. the picture returns to normal. This has started to happen within the last month. Any Ideas?
  • Anonymous May 15, 2008
    I HAVE A FUNAI 42 INCH PLASMA MADE BY SYLVANIAA AND A FEW WEEKS AGO IS JUST START GETTING THIS BLURRY SCREEN WHEN I TURN ON THE TV @ FIRTS IS WAS ONLY A FEW SECONDS BUT NOW IS ALMOST A MINUTE BEFORE U CAN GET A CLEAR PICTURE DOES ANY BODY HAS THIS KIND OF PROBLEM AND IF Y GOT IT FIX
  • Candis4 May 21, 2008
    When my 42" Plasma (Sylvania ) is turned on it is very blurry and green. There are also black spots all over it. after a while the green was going way and the black spots faded to (after it was on for about an hour) but now it is permanently blurry and green with black areas and it doesnt get any clearer. what needs to be fixed and how much should it cost me? PLEASE HELP DESPARATE WITH 3 SMALL KIDS THAT NEED TV
    Genius:
  • 1,139 Answers
This sounds like the color processor IC is not working properly. If this is the case you will have to have this checked by a qualified technician.
Posted on Sep 21, 2007
SOURCE:
Plasma TV Picture Periodically Blurry/Color is Distorted
This sound more like a cable issue. Also check the leads going from your cable box to the set/ If you are using component cables one of them may be loose.
Apr 28, 2010 | Panasonic Viera TH-42PX80U Plasma TV
My 42" Samsung Flat screen
IS HE SCREEN TOTALLY RED !! if yes check power supply all voltages if normal replace x board
Apr 26, 2010 | Samsung SPN4235 42 in. Plasma HDTV
Red colour picture on plasma TV
It might need the color to reclibrated, if that does not work, a gamma electronic board need to be replaced
Jan 06, 2010 | Samsung PS42C91HDX 42 in. Plasma TV
I have a Sylvania 42 inch Plasma HD TV. It is 3
Hello
Before taking this to a local repair person, I suggest you check with your cable provider. See if they are having trouble with their HD transmission and then have them test your lines. Out here in Arizona with have constant problems with HD due to heat, rodents and poor installations. Your DVR only recorded the problems that were on your set. If these prove fruitless then take the TV to a reputable repair person.
Good Luck
Sep 24, 2009 | Sylvania SRPD442 42 in. EDTV-Ready Plasma...
Screen only partial and only shows in red and black
sir/mam the problem of your plasma t.v is the panel,weak panel. i have already encountered that kind of problem.
Aug 01, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Hi i have a 42'' 42'' sylvania pla model 6842 pf m and have a bli
if stand-by voltages are good, you probably have bad inverter board. could be one or two depending on unit
Mar 09, 2009 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Toshiba 42hp83 plasma power supply problem?
I had the same problem. It turned out that one of the cooling fans get dusty and does not work. I opened the back of the Toshiba plasma TV and cleaned the failed fan, and it worked like a champ.
Nov 05, 2007 | Toshiba 42HP83 42 in. HD-Ready Plasma...
Plasma 6842PF
Guess what you may have hit the nail on the head. Plasma TV used a balast type power system for the backlighting and that is what you are hearing. I would suggest getting this set looked at to see if the plasma excitor needs to be replaced (it may have another name in this brand of set).
Sep 18, 2007 | Sylvania 6842PF 42 in. EDTV-Ready Plasma...
Sylvania 6842PF 42 in. EDTV-Ready Plasma Television Logo
618 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
