Question about Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive
Hard drive model: HD103UJ (1000gb/7200RPM/32M) I connected it to the pc..but cannot find it..Do I need drivers or something?
    Problem Solver:
  • 12 Answers
Recuce the 3 Gb/sec (SATA-II) speed to 1.5 Gb/sec (SATA-1) using ESTOOL available on the samsung website.
I found the Samsung HD103UJ unreliable. Read about my findings here:
Unreliable disk - samsung spinpoint F1 HD103UJ
Posted on Aug 29, 2009
  • 272 Answers
If tou can find it in booting time on bios screen, Just goto,,, start>control panel>Administrative Tools>Computer Management>storage>disk management. You should see the new drive. Click on it and try import foreign disk . it should bring the disk. try making new oartitions there.
Posted on Apr 20, 2009
In RAID10 4HDDs samsung HD103UJ 3 HDDs failed at the same time
Sounds about like a TDL4 malware infection, or perhaps the BAD BIOS infection!
Apr 26, 2017 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Error Hard drive reports a read error
Try doing a system restore, if that does not work. Check The cable that connects motherboard to Hard drive, it's a bad cable, or a bad broken Hard drive on your hands.
Apr 25, 2011 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
I had a few trojaans and viruses. This may have affected my external hard drive :driver model: hd103uj Samsung. It worked fine before. Now it says there are no drivers installed for the External...
You want to save your data with out Format all thepartition ,download hiren boot, from the bellow link.
http://www.hiren.info/bootcd-on-usb-disk
Now burn the ISO file, under image burning option,from nero ,in the another pc which is run's well. Restart pc, the cd will start soon, if the hiren boot cd ,willnot run, set bios setup. Now click herefor BIOS SETUP ,restart again and select miniwindows and delete system volume information and RECYCLER from all the partition or drives except "C"drive(Partition C:)
Because "systemvolume information" and "RECYCLER" is the Heart of Castle. If it not removethe virus ,download bootable f secure,click here And write the ISO under image burning option,from nero and boot from CD. Now you can scan for fix.
Insall clean OS, delete partition C: and create C same .
If you do not want install the OS ,download combo fixfrom bellowthe link
http://combofix.net/
Follow all the steps.Rstart the pc >press F8> select save mode usethe down arrow key .copy and paste the combofix and dubble click on it and wait for few minutes. Do not do any thingwhen the combo fix will be running.Let them do .
If you need more information, reply me soon.
Thanks
Feb 22, 2011 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
SIR I AM PURSHES SAMSUNG 1TB INTERNAL HARD DISK MODEL NO: HD103UJ INSTALTED MY SYSTEM(intel945M/B)HDD DETECTING IN BIOS ONLY VOLUME 32MB HOW SOLVE THIS PROBLEM
Take out the hard drive.
At the back of the hard drive you will find a jumper. pull it out and change the location or put it at the end.
connect the hard drive and check.
Dec 02, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Hd103uj has stopped working in my external box so I swapped it with a drive in my computer but it wouldn't boot, I switched it back to the original and it booted no problem. I only used this drive a few...
Check the jumper settings on the new drive drive,it should be set to MASTER otherwise it will not boot. Also check your BIOS settings to insure that the computer is seeing the drive.
Jan 05, 2010 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Bios does not detect samsung hard drive - what can I do?
All I can asume is that you are trying to install this on a slightly older computer. All is not lost though. you need to find out the name and model of your motherboard and go to thge web site to see if there is a bios update. if there is then get it and use it mthods vary but instructions will be on your motherboads web site.
Try that first as the second method is not my prefered one. Next you can try to set the drive up on a newer machine and whilst doing so split the partitions into 4 so that you would end up with what looks like 4 drive of just under 250Gb (You wont get 250Gb becuase of overheads)
Try it in your older computer and if all is good you are away to the races.
If that fails you are looking at using software to fool the bios. This has the advantage in that you can use the whole drive and dont need to creat partiions but quite often has a speed disadvantage becuase software has to do a lot of work.
The software is here but I hope you got it working way before you need this
http://www.samsung.com/ca/support/download/supportDown.do?group=&type=harddiskdrives&subtype=hdd35&model_nm=HD103UJ&disp_nm=HD103UJ&language=&cate_type=all&dType=D&mType=SW&vType=&prd_ia_cd=05040800&model_cd=&menu=download
Aug 11, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Got a 250gigs copied old 80 gig
try re-installing your O/S then delete the partion/s and create a new one it should give you the total capacity after that, post back if you still have questions
Jun 08, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
How do i reformat C drive and keep my files on sata backup
dis connect the sata cable that attaches the sata hard drive to the pci card and then format c and re install with all the drivers you require for the pci card as well as motherboard drivers, network card drivers etc and then re attach the sata cable that way you dont get confused between which drives its showing if it manages to display the sata drive at boot up.
May 16, 2009 | Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334...
Samsung 1TB SATA2 7200RPM 32MB HD103UJ 334 GB SATA Hard Drive Logo
1,252 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
