Question about Kenmore 53552 / 53554 / 53559
Evaporator Defrost System 53552
A description of the operation of the defrost system used on this model refrigerator. Techinical data indicate a standard type of electric defrost system. Though, it was sold on based on a fast hot gas defrost system. I have checked the operation of this unit and it does not fully operate like a electric defrost system. At times it defrosts like a timed electric defrost, till the dripping of the condensate. Other times, it behaves like a hot gas defrost system, where the compresser is on, with condenser fan off. This machine is totally automatic, and works well, most of the time, but it has many short comings as I may indicate later. A request for literature would most likely produca a standard electric defrost system. I may have to dig into this unit and make a sketch of the piping layout, and electronics. Is a hot gas defrost system used on this unit? Where to get a diagram? Regards fmauka
  • fmauka Dec 23, 2007
    Hello! peyton32034,
    Thanks for the input, this brings some clarity on the operation of these model unit. and control board defects makes for a more difficult analysis. I see that a main board is from $160 to $200 and a expensive repair. And, as you say, may be the heart of the problem.
    The operation as such, notes that the evaporator fan operates too much. I can see this going out in a few years. Next time the freezer gets empty like, I will strip out the back panel and take a few pictures. I have pictures of the piping near the compressor, and there is no indication of a hot gas system. I do not think that a double tube system was used.
    Note: to others with operational problem, freezing, or temp control problelm. Initially a factory resolution to the frozen air pass door or broken linkage problem was a substitue heavy duty unit. One was still dependent on a good control board.
    One resolution, to disconnect the by-pass door motor, and set blades at quarter open, and chedk the temp operation..
    This similar to the older method of controling the ref-frez operation. Next is to install a shut-off by pass electric switch, to cut off comp-cond operation. Meaning the switch will control the refri temp, (no freezing) and maintain freezer temp. I have this unit operatin at 0 deg freezer, 40 deg refrigerator.
    A wire diagram schematic is available, in jpeg file, for one to use. I can post it to manual section if it is useful, or can post a picture.
    Thanks again, to peyton32034, for the added info.
    Regards, fmauka, Aloha! a merry Xmas 2007
  • 410 Answers
This unit does not have a hot gas def system but rather a pulsed def where the heater will kick on for a few minutes every so often to see how frosted up the coil is. the draw back is that they are having problems with the control board keeping the compressor and condensor motor on during the def cycle, thus ending up with a solid ice build up in the coil..
Posted on Dec 15, 2007
SOURCE:
What is er dh?
The Er DH error code indicates the temperature sensor on the evaporator coil did not reach 50 degrees within one hour.
This would indicate the control board did put the refrigerator through a defrost cycle.
This problem could be caused by a defective relay on the control board, a defective defrost heater, a broken wire to the heater, or a stopped up drain on the defrost pan causing ice to form on the evaporator coil.
Before replacing the control board, someone should remove the food from the freezer, remove the freezer drawer, and remove the evaporator cover to expose the evaporator coil, heater, and defrost sensor.
The voltage to the defrost heater should be 120 volts ac.
The defrost heater is part of the evaporator coil and is not replaceable as a separate part.
You can test the operation of the defrost system by pressing "Ultra Ice" and "colder freezer temp" for 3 seconds.
The first time you press and hold the buttons the board will test the compressor, fan, and open the damper.
All displays should be on.
The second time you press and hold the buttons the board will test the compressor, fan, and close the damper.
The third time you press and hold the buttons, the board will turn the compressor and fan off and turn the defrost heater on for around 25 minutes. This would let you know if the defrost system is working.
Dec 18, 2010 | Kenmore Refrigerators
Problems for Refrig. Kenmore Elite
http://knol.google.com/k/fixing-the-er-dh-code-on-kenmore-elite-trio#
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 03, 2010 | Kenmore 73502 / 73504 / 73509 Bottom...
I HAVE AN ERROR CODE dH on my Kenmore Elite bottom
Apr 14, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Refrigerator warm, display blank but freezer still works
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.*#$^
Feb 21, 2010 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
My kenmore elite trio has error message. ER DH
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE [email protected]#$
Sep 16, 2009 | Kenmore 73503 Stainless Steel Bottom...
We have a Kenmore Elite Trio that keeps giving us an error message in the electronic window of er dH
Aug 30, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Er dh code error on Kenmore elite trio
Jul 11, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Model number mtb1753ara refrigerator compartment warm. because won't defrost some times.
When it comes to the defrost system it ether works or it doesn't. Since your problem sounds to be intermittent I would look to the evaporator fan motor located in the freezer compartment for your problem. It may be operating intermittently as mine just did a few days ago. I replaced the evaporator fan motor and it solved my problem. I also thought it was in the defrost system.
The defrost timer is located in the refrigerator compartment top center. Turn the screw clockwise very slowly until you hear one audible click and it will be in the defrost mode. In 18-22 minutes the refrigerator should cycle back to cooling.
Jul 31, 2008 | Maytag Refrigerators
Error message (?) on display of Kenmore Elite Bottom Freezer Refrigerator
Jul 03, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore Er dh
Apr 12, 2008 | Kenmore 24.8 cu. ft. TRIO Bottom Freezer...
Kenmore 53552 / 53554 / 53559 Logo
211 people viewed this question
Top Kenmore Refrigerators Experts
Fred Sops
Audrey Messer
Audrey Messer
Jimmy
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
