Question about Dell Inspiron XPS M1710 Notebook
Distorted graphics and low frame rate with new 3d games
I have played many games on my 1710 and never had any issues; however, almost all of the more graphical intense games i play (mostly newer 3d games) i get periodic but regular intervals of about 3fps and random flashes of graphic distortions. the problem will last for about 15-30 sec and then frames will return to normal and distortion will disappear. As i said before it occurs on regular intervals. this machine has never overheated to my knowledge. I plugged in an external monitor and i did not see the glitches but still experienced the fps drop to nothing for regular 15-30 sec intervals. games this has happened on: Vangard Ghost Recon Advanced Warfighter Company of Heroes Two Worlds WoW This doesnt happen on many games, like: DAoC Ghost Recon (original) Fallout Tactics IL2 and expansions Thank you for your help.
  • Toski1978 Sep 21, 2007
    After monitoring gpu temp while gaming, it seem i am over heating the gpu. at 102^ it slows the gpu to reduce temp, at 89^ it starts up and begins to heat up quickly, this explains the regular cycle of preformance drop.
    Now that i know what is happening, what should be my course of action? I am getting a cooling pad/dock thing today but is there other things i can look at? why is my gpu running so hot i wonder.
    The pad only delays the inevitable over-heat. the fans on this machine do not run UNTIL it gets hot, my gpu running hot even idle...isnt there a way to control those fans' on and off temps? i cant find it in the bios or in any other windows accessories. i can hear my fans going full speed only after the gpu has exeeded 95 degrees cel.
    when i am gamin i would rather they run full before it gets too hot lol. thanks for the responses.
  • 150 Answers
Based on that game list it sounds like the problem is related to hardware T&L(transform and lighting) as the games that cause the problem require T&L and the other games don't require it and their fine. It's a start, also have tried both direct3d and opengl modes? Good Luck
Posted on Sep 21, 2007
  • Patrick McGee
    Patrick McGee Sep 21, 2007
    Cooling pads are probably the easiest and most cost effective way of keeping that cool. Although you may also take the notebook apart and remove and replace the GPU heat sink with a larger one if it will fit, don't forget to use new thermal compound to help heat distribution.
SOURCE:
I have problem with my mother board mercury when i download game give me massege that you need grphic 3d to play this game.
You motherboard is not having graphics needed to play the 3D games.
You need to buy a new graphics card.
Thanks for using FixYa.
May 22, 2011 | Mercury P4VM800M7 Motherboard
Tip
How to Run a Graphic Games without having Graphic Card.
Hello!<br />Greetings!<br />in this segment i am going to share a very usefull trick with you, when i was child i am used to spent my 3-4 hours daily on PC, playing games. i had a P4 which does not have any graphic card into my PC. i wonder that how to play those games like Prince of Persia, Tomb Rider, Call of Duty etc.<br />at that time it was not possible for me as i was very little for advance technical issues. but now here you can do the same.<br />go to the Web Site <br />http://www.filestube.com/3/3d+graphic+analyzer<br />download the 3D Analyser from the given link<br /><br />3D Analyzer sort of "Tricks" your system into thinking it has a Nvidia, or even ATI graphics card! Of course, your games and applications will run in the mode they usually will (with the default graphics and such). If you have an Intel like me, you can now play games like "Devil May Cry 3", "The Witcher", "<a href="http://rdhacker.blogspot.com/2008/08/resident-evil-5.html"><b>Resident Evil</b></a> 4" and or any new gen games which earlier demanded of graphics card.I played my Favorites using it and I m thoroughly satisfied with this tool. You can fiddle with various options to mess with it,and get different games to work with. <br />
on Aug 05, 2011 | Computers & Internet
So which video card do i need? i have 845gl motherboard . before installing this video card (rage XL 8mb pci) my pc plays videos and most 3d game very (even gta sanandreas) efficiently but now it is not...
The ATI Rage XL 8MB PCI video card is a very old and low power video card.
PCI graphics cards are not as fast as AGP graphics cards so if your motherboard has an AGP slot (it's the slot closest to the CPU and is usually coloured brown) then that would give you better performance.
These days AGP has been superceded by PCI-Express but since your motherboard does not have a PCI-Express slot then the best graphics card for it would be something like this one:
http://www.play.com/PC/PCs/4-/5416296/Sapphire-ATI-Radeon-HD-3850-512MB-DDR3-AGP-8X-Graphics-Card/Product.html
Hope this helps, please rate my answer :)
Chris
Mar 02, 2011 | ATI Rage XL 8MB PCI Video Card PCI
Cant play 3d games on geforce fx5500
Have you installed the latest driver? Uninstall the old one and install new one after reboot. Don't install the 64bit one at the top asit's beta,good luck John
http://www.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=130&prod_no=719
Aug 02, 2009 | MSI FX5500-TD256 GeForce FX 5500, (256 MB)...
Refresh rates on flat crt moniter
The refresh rate (most commonly the "vertical refresh rate", "vertical scan rate" for CRTs) is the number of times in a second that display hardware draws the data it is being given. This is distinct from the measure of frame rate in that the refresh rate includes the repeated drawing of identical frames, while frame rate measures how a video source can feed an entire frame of new data to a display.
For example, most movie projectors advance from one frame to the next one 24 times each second. But each frame is illuminated two or three times before the next frame is projected using a shutter in front of its lamp. As a result, the movie projector runs at 24 frames per second, but has a 48 or 72 Hz refresh rate.
On CRT displays, increasing the refresh rate decreases flickering, thereby reducing eye strain. However, if a refresh rate is specified that is beyond what is recommended for the display, damage to the display can occur.
Frame rates are considered important in video games. The frame rate can make the difference between a game that is playable and one that is not. The first 3D first-person adventure game for a personal computer, 3D Monster Maze, had a frame rate of approximately 6 frame/s, and was still a success. In modern action-oriented games where players must visually track animated objects and react quickly, frame rates of between 30 to 60 frame/s are considered minimally acceptable by some, though this can vary significantly from game to game. Most modern action games, including popular first person shooters such as Halo 3, run around 30 frames a second, while others, such as Unreal Tournament 3, run at 60 frames a second. The framerate within games, particularly PC games, typically varies with the hardware configuraton, and depending upon what is currently happening in the game at a given moment. When the production of a frame makes large demands on the CPU and / or GPU, the framerate falls.
A culture of competition has arisen among game enthusiasts with regards to frame rates, with players striving to obtain the highest frame/s count possible. Indeed, many benchmarks (such as 3DMark) released by the marketing departments of hardware manufacturers and published in hardware reviews focus on the frame/s measurement. Modern video cards, often featuring NVIDIA or ATI chipsets, can perform at over 160 frame/s on graphics intensive games such as F.E.A.R. One single GeForce 8800 GTX has been reported to play F.E.A.R. at up to 386 frame/s (at a low resolution).[citation needed] This does not apply to all games: some games apply a limit on the frame rate. For example, in the Grand Theft Auto series, Grand Theft Auto III and Grand Theft Auto: Vice City have a standard 30 frame/s (Grand Theft Auto: San Andreas runs at 25 frame/s) and this limit can only be removed at the cost of graphical and gameplay stability. It is also doubtful whether striving for such high frame rates is worthwhile. A regular CRT monitor (somewhat outdated now) runs at up to 85 hertz, meaning that any performance reached by the game over 85 frame/s is discarded. For that reason it is not uncommon to limit the frame rate to the refresh rate of the monitor in a process called vertical synchronization. However, many players feel that not synchronizing every frame produces sufficiently better game execution to justify some "tearing" of the images.
In conclusion: If you want better experience in games you must upgrade your videocard.
Jul 29, 2009 | Microsoft Windows Vista Home Premium...
My HIS Radeon x1650XT hangs after playing 3D Games.
change your graphics card or you may upgrade your card.
Jun 03, 2009 | ATI RADEON X1650 Xt, (256 MB) Graphic...
In-game graphic breakdown
Sounds like an issue with the graphics card in the system. Call up Xbox 360 Support, or return it for a new one.
Apr 15, 2009 | Microsoft Xbox 360 Console
My Asus A9250 hangs when I play 3D games
Install the latest driver for A9250 from here. Install DirectX 9 from here
Jan 16, 2009 | ASUS A9250/GE/TD RADEON 9250, Graphic Card
About graphic card
most top-end cards will work with your computer and boost performance a bit but... your CPU and the (these days) very low amount of RAM (for e.g. this little laptop I'm using has 3 GIG of ram) would NOT enable you to play the (latest) games... if you got them to run at all they would be mind-numbingly slow.
Biggest performance boost you could give your computer and help towards playing latest games would be more RAM.. as much as you can fit in. More RAM is the best upgrade you can give a computer
Oct 10, 2008 | Pine Technology PINE 3D Phantom 32M PCI...
Games
Dude it is more than enough , i m running on 512 ram and 256 graphics card ATI radeon and P4 processor also i m running NFS Carbon smoothly. There's no issue.
Happy Gaming
Sep 18, 2008 | Video Game Consoles & Games
Dell Inspiron XPS M1710 Notebook Logo
183 people viewed this question
Ekse
Clive
Clive
