Question about Hoover Floormate H3000 Upright Wet/Dry Vacuum
Floormate will not **** dirty water.
Scrub brushes work and solution comes out; floormate will NOT **** up water.
    Problem Solver:
  • 7 Answers
Check the hose coming out of the floor assembly. It tends to split, keeping it from picking up the water
Posted on Aug 05, 2009
How do you change the scrub heads on a Floormate SpinScrub 500?
Hey there! To change out your brush heads simply follow the instructions below.
1. Remove the nozzle by pulling the two nozzle release buttons.
2. Tilt cleaner back so handle rests on floor.
3. Push two brush release buttons and remove the brush assembly.
4. To replace brushes align post on brush block with hole on bottom of cleaner. Turn brushes slightly until post fits easily into hole. Press brush assembly firmly to snap into place.
Hope this helps!
Jul 05, 2014 | Hoover H3030 FloorMate SpinScrub 500...
The scrubbing brushes do not turn
I would take off the brushes and make sure they are clean. You should be able to mmanually turn them.
Nov 15, 2011 | Hoover Floormate H3000 Upright Wet/Dry...
My steam vac deluxe does not have enough suction to pick up water
For the brushes:
The power wire may have slipped off. take apart the unit at the top (Behind the cleaning fluid container) Inside there is a wire coming up from the motor at the bottom of the unit. This can come unlpugged no longer powering the scrub brushes. Simply slip the wire back on the plug.
To open: remove all visible screws from top half of machine. Remove the rubber mode dial by pulling off, and remove screw behind that. Pull the front off, and the power plugs are located right on the inside of the machine by the mode dial.
for the suction, check the intake hose the comes out from behind the floor assembly. it tends to split over time
Aug 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Brushes won't spin on FloorMate
you need to replace the belt or make sure the brushes are locked into place.
Jun 18, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Brushes not spinning in Wash mode
May 04, 2009 | Hoover Floormate H3000 Upright Wet/Dry...
Dirty water comes out when I stop scrubbing. Floors remain wet.
Try one thing... the filter cover must be clicked into place. I thought it just sat on top, but it has to be pushed into place.
FWIW
Mar 22, 2009 | Hoover H3030 FloorMate SpinScrub 500...
Hoover floormate.
Can't do it. The machine vacuums in both scrub and pick-up. Sorry.
Kirk Thompson
San Juan,PR
Sep 01, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
I cannot figure out how to use my cleaner floor mate
At the risk of giving a simplistic answer, let me go through the steps I go through every time I use mine:
1) Plug it into the wall
2) Take out the upper "hopper" and fill it up to the fill line with hot water
3) Put in the capful of cleaning solution (about 2 oz.)
4) Gently swish it back and forth, then put back into upper unit until it clicks into place
5) For best results, set the vacuum on Dry and vacuum the house first, then clean the lower "hopper"
6) Set the vacuum to Wet, put the scrub brushes on, depress the trigger and do overlapping strokes, a section at a time I depress the trigger on the push stroke, then release it for the pull stroke. I clean a section, then turn off the scrub brushes and go over it again without the scrub brush or touching the trigger (trying to pick up as much water as possible).
On average, when refilling the water/cleaner solution for the top hopper, empty and clean the lower hopper. When the floors are finished, completely clean that lower hopper or it will smell!
Hope this helps...
Jul 18, 2008 | Hoover Floormate H3000 Upright Wet/Dry...
Spin Scrub Brushes won't turn
If the brushes quit spinning, either the brush block shaft that goes into the turbine broke off, or the turbine is bad. This unit is tricky to take apart and then put back together again. But pull the brush asm off, then start taking out screws. But if after you pull off the brush block, look up where you will see a small square hole, turn unit on and if not turning, usually the turbine is the cause and will have to be replaced.
Jan 13, 2008 | Hoover H3030 FloorMate SpinScrub 500...
Hoover Floormate H3000 Upright Wet/Dry Vacuum Logo
266 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
