Question about Sanyo EasyStreet NVM-4370 Car GPS Receiver
White screen numbers 1.0.3.9 displayed
When i turn on my navi system, the menu doesn't come up. A blank screen with the numbers 1.0.3.9 are displayed on the screen
Posted on May 02, 2009
  • 20 Answers
Try to hard reset it. Use bottom switch, turn off and on or hold down the reset while turn on the power (top Power/Menu button).
Posted on Apr 23, 2009
I hooked my PS3 to my HDMI cable to get a better visual screen display for my HD movies and games, but display screen went blank and I cant get the commands menu screen, how can I get the menu commands...
You must reset your PS3 in order to accept the new TV configuration.
  • If the video output settings on the PLAYSTATION3 do not match those of the cable or TV in use, there may be no picture. If the screen goes blank, turn off the system.
  • Then, with only the PLAYSTATION3 and the TV connected, touch the system's power button for more than 5 seconds to turn the system back on. The video output settings will automatically be reset to the standard resolution.
  • Hope this helps please remember to rate my response, thanks!
    OpenSource13
    Jun 16, 2012 | Video Game Consoles & Games
    Black screen for HDTV channels -- but TV menu and DVDs display normally
    Try hard reset, Please unplug the tv cables and power cables for 30 min and redo the cable and check its working ....
    Good luck...
    Aug 01, 2008 | Hitachi 42HDS69 42 in. Plasma Television
    Tip
    ERROR CODE AND POWER SUPPLY CIRCUIT
    Viewing the Self Check Diagnostic List
    1. TV must be in standby mode. (Power off).
    2. Press the following buttons on the Remote Commander within a second of each other:DISPLAY > Channel 5 > Volume - > TV POWER .
    Results for all of the following diagnostic items are displayed on screen. No error has occurred if the screen displays a "0".
    NOTE: If the Service Menu display text is not completely visible, press the Menu HOME button on the Remote Commander to refresh the display.
    3. To exit Self Check display, turn the power off. Press [Menu] Exit.
    Clearing the Self Check Diagnostic List
    1. In Service Mode, press the Channel 8 Channel 0 .
    RESETTING TO FACTORY DEFAULTSUse the following instructions to restore the User Controls and
    Channel Memory settings to the preset factory conditions.1. While holding down the UP ARROW on the Remote Commander, press the POWER button on the right side of the set.The set restarts and displays the initial setup screen. This may take several minutes.
    White Balance adjustment
    1. Allow approximately 30 minutes for the set to warm up before proceeding with the white balance adjustment.
    2. Connect the signal source to the 3 terminals of the Component In input (Y/Pb/Pr).
    3. Set the Picture Mode to "VIVID" in the user menu.
    4. Select the Component In input.
    5. Open the Factory Service Menu (see section 3-1.) and select "Service Alignments Menu".
    6. Set "White Point Red", "White Point Green", "White Point Blue" and "Black Level Offset Red", "Black Level Offset
    Green", "Black Level Offset Blue" to average values .
    "Cool " White Balance Adjustment
    1. Select "COOL" from Color Tone in Service Alignments Menu.
    2. Input 70IRE full white pattern signal into Component In.
    3. Adjust "White Point Red", "White Point Green", "White Point Blue" in Service Alignments Menu if needed.
    4. Input 25IRE full white pattern signal into Component In.
    5. Adjust "Black Level Offset Red", "Black Level Offset Green", "Black Level Offset Blue" in Service Alignments Menu if needed.
    6. Repeat steps 2 to 5 to achieve desired White Balance.
    FOR MORE DETAILS CHECK THE FOLLOWING LINK
    www.electro-medical.blogspot.com
    google.com/+AjinGopakumar
    USE SEARCH TAB TO FIND MODELS OR USE THE DROP DOWN MENU
    on Jun 30, 2015 | Sony Bravia L-series Kdl-32l5000 32-inch...
    Dell Latitude D830 running Windows 7. Also running laptop screen plus additional monitor. I was watching a visor from cnbc.com when the addt'l monitor went blank and the laptop screen went a broken...
    Hallo there
    I hope you have got your screen beack, if not try to restart your computer in safe mode.
    The restarting can be done in the following way:
    1. Click START, click TURN OFF COMPUTER, and then click RESTART
    2. While the computer is starting, press and hold down the F8 key until the Startup Menu appears
    3 Use the UP ARROW and DOWN ARROW to select Safe Mode, press ENTER.
    Now to the display settings
    1 Open Display Properties in Control Panel
    2 Click the Settings tab
    3 If for some reason you are not in safe mode go through following:
    In Colour quality, clock to alower settiing
    Move Screen Resolution slider to the left if you want to reducethe size of the desktop
    To Refresh frequency click Advanced and check the Adapter and Monitor.
    4 After you have made your changes click OK
    restart the computer if you are told to do so. But do not do it in safe mode..
    Good luck
    Kobrun
    Feb 29, 2012 | Dell Computers & Internet
    How do I set my speed dial numbers?
    Which ones? System speed is programmed from station 10 or 11 and goes in the 6xx's, depending on your version of software. The start is FEATURE 00 FEAT 6xx and dial the number You can continue programming more numbers by pressing FEAT 6xx or Feat 00 to exit.
    Personal speed dial numbers are programmed similarly, except they are in locations 80-99 on each phone and can be programmed from the phone if it's a system phone.
    Auto Dial buttons use blank buttons on your set. Feature 00 pressing the button and dialing the outside number store those. Again, Feature another button will let you program another button, or Feature 00 ends programming.
    Carl
    Jul 12, 2011 | Lucent PARTNER18 Corded Phone
    Display Becoming White
    First, to verify if it is your display adapter, connect an external monitor to your laptop and see if it displays fine. If it is fine on the monitor, then we know that it is from your laptop screen(in this case, it is either you first check from a technician if it is the colour that has to be refilled or if you need to purchase a new screen). If not then it is from your display adapter(could be from corrupt display drivers). In this case, you would have to re-install new drivers for your display adapter(you can download it from your system manufacturer's website if you don't already have it).
    Thanks
    Dec 01, 2008 | Computers & Internet
    Display problem!!
    Hi there polarized.
    All you need to do is this.
    1. Switch your mobile phone off then switch it on again.
    2. Click the MENU button which is the top left keypad (the silver colored one)
    3.Scroll down once, then to the right once.
    4. Click the MENU button again.
    5. Scroll down twice. Click MENU button.
    6.Scroll down once or twice and click MENU button again.
    This should either reset your theme to the default themes.
    Nov 09, 2008 | Sony Ericsson T280i Mobile Phone Silver on...
    Blank White Screen - No Menu Showing
    My Sansa has a similar problem. Sometimes when the Sansa turns on (after the Sandisk logo) the screen will either turn black, blue, or black and white stripes. The player still works, but it is hard to navigate without the screen, obviously. What I end up doing is letting the backlight turn off and then pressing any button. Sometimes when the screen comes back, the display is allright again. But sometimes it takes more than a few tries. Turning it off and on again seems to work a little better, but it is more time consuming.
    Apr 01, 2007 | SanDisk Sansa e250 MP3 Player
    Check signal message when data cable unplugged. blank screen when data cable plugged
    This problem is most likely to be caused by a bent or broken pin on the CRT video cable at the VGA connector, OR, this could also be caused by a damaged VGA connector on the back of the laptop. If neither VGA connector is at fault, the problem could be caused a damaged (kinked) CRT data cable, or internal damage to the VGA connector on the back of the laptop, though I suspect the problem is more likely to be external, and you probably won't have to disassemble the laptop to locate the culprit...
    Feb 05, 2007 | IBM E74 17" CRT Monitor
    Sanyo EasyStreet NVM-4370 Car GPS Receiver Logo
    286 people viewed this question
    Top Sanyo GPS Experts
    perdue40
    Are you a Sanyo GPS Expert? Answer questions, earn points and help others
