Question about Master Appliance 750-1000D F PRODUCTION MASTER HEAT GUNS
Don't know how to replace insulation in nozzel
I have a Master Appliance 751b heatgun. The blower stopped working. I was going to take it apart to see if I could see an obvious cause. I took the tin off the nozzle. It had some cellophane-like material, several sheets, as insulation. I didn't note how the insulation was placed within the tin nozzle, and now I don't know how to put it back together.
In the meantime, I have found someone who knows how to work on the heat gun (he says the problem is likely the motor or a capacitor) but I doubt if he knows how to replace the cellophane-like sheets.
Hope you can help!
Brian
  • 530 Answers
The heat resistant mica sheets simply wrap around the heating element separating it from the inner nozzle.
Below is a link to a diagram that is pretty much the same as yours.
http://images.google.com/imgres?imgurl=http://www.howardelectronics.com/MasterAppliance/Image/explo_mhg.gif&imgrefurl=http://www.howardelectronics.com/MasterAppliance/hgreplacementparts.html&usg=__7eMZnaHCciQBDezdWd5n_NOLy_0=&h=309&w=600&sz=16&hl=en&start=19&sig2=BF0jaBHxYQfJyuxn7P4eig&um=1&tbnid=lWkvIGGrzK4WTM:&tbnh=70&tbnw=135&prev=/images%3Fq%3Dheat%2Bgun%2Bparts%26hl%3Den%26sa%3DN%26um%3D1&ei=w-plSrWnNY74NdK-hZEB
Posted on Jul 21, 2009
Kenmore elite dryer model number 110.67062600 blower wheel does not spin.
Dear David,
I should like for you to take the whole machine apart and see the trouble.
I had the same problem with my daughter's machine.
I discovered the blower wheel was not spinning with the drive shaft because the insides of the machine were plugged with lint.
Take that thing apart, and you should find that lint is the problem, I discovered the at machines made nowadays are made by robots, and have air leakages internally, so that lint collects where it should not.
God bless your efforts, Dave
Mar 17, 2017 | Kenmore Dryers
Front blower stopped working, where is the resister?
A resister would only cause it not to work on 1or2 speeds, Not all of them, The Blower motor is shot (Probally) They don,t last for ever, There is allso a relay for them in the fuse block in the engine compartment, That might be defective,
Dec 01, 2012 | 2005 Dodge Grand Caravan
Blower motor sounds like it is going to stop. how hard is it to replace?
here are the instructions for fan blower removal. remove lower right dash insulator panel from under glove box. slide the body control module aside for access to the blower motor.( bcm ). remove the 3 screws that hold it in. pull the blower motor and fan straight down and dis connect electrical connector. if replacing blower motor, remove fan to put on new motor. 99 olds cutlass, have a good day !! just take your time and it is not that hard.
Jan 22, 2011 | 1999 Oldsmobile Cutlass
How to replace the blower motor fan assembly in a 2000 GMC Yukon XL K1500 4X4
Blower Motor Removal & Installation Delphi
Blower Motor Replacement (Delphi)
To Remove:
  1. Remove the instrument panel sound insulator panel (if equipped).
  2. Disconnect the electrical connector from the blower motor.
  3. Remove the blower motor insulating cover screws.
  4. Remove the blower motor insulating cover.
  5. Pull the retaining tab down and rotate blower motor counterclockwise to remove.
To Install:
  1. Position the blower motor and turn assembly clockwise until tab locks in place.
  2. Install the blower motor insulating cover.
  3. Connect the electrical connector to the blower motor.
  4. Install the instrument panel sound insulator panel (if equipped).
Visteon
Blower Motor Replacement (Visteon)
To Remove:
  3. Remove the blower motor screws.
  4. Remove the blower motor from the HVAC module.
To Install:
  1. Position the blower motor and install mounting screws.
  2. Connect the electrical connector to the blower motor.
  3. Install the instrument panel sound insulator panel (if equipped).
Oct 02, 2009 | 2000 GMC Yukon XL
Blower fan does not work
to stop the guessing ,replace blower motor and blower resister/if motor is bad it can make the resister go out,u may have a blower relay also thats bad replace if the control speed switch has not got a burned spot on the back where the wires plug up then this should repair ur car/it sounds like a lot to replace and maybe u think unnessasary but these componts work all together and affect one another
Jun 29, 2009 | 2002 Chevrolet Impala
The blower motor stopped working. I would like to know where it is located, and how to change it. Thanks
Right hand side under the dash, remove:
  1. Battery ground negative cable.
  2. Right side instrument panel insulator.
  3. Blower motor cooling hose.
  4. Blower motor electrical connectors.
  5. Blower motor mounting screws.
  6. Blower motor.
May 07, 2009 | 1998 Buick Century
Need to replace the blower motor on my 2002 silverado
2002 silverado as follows :
1. if equipped , remove the sound insulator panel , remove the blower motor insulating cover screws , disconnect the electrical connector from the blower motor , remover the blower motor insulating cover , pull the retaining tab down while turning the blower motor counter clockwise in order to disengage the blower motor from the HVAC module , remove the blower motor .
2. to install blower motor , reverse the steps .
thanks for voting.
Dec 28, 2008 | 2001 Chevrolet Suburban
Master Appliance 750-1000D F PRODUCTION MASTER HEAT GUNS Logo
83 people viewed this question
Top Master Appliance Tools & Hardware - Others Experts
J.D. Browning
J.D. Browning
Are you a Master Appliance Tool and Hardware - Other Expert? Answer questions, earn points and help others
