Question about Optiquest Q 71 17" CRT Monitor
COMPUTER MONITOR BLUE COLOR APPEAR ON THE SCREEN
Please open ur monitor & then see the picture tube back side 2 nobe please use screw driver for turning nobe nad u will solve this problem.... thanks regards prashant kulthe solution world Nashik m:9372990849
Posted on Sep 21, 2007
Small rectangle in the middle of the screen with the letter i in the left corner, the buttons are lockeder la hello 17
If the picture disappears from the screen and the
1 (power) indicator is green
Turn off the 1 (power) switch and disconnect the
video signal cables from the monitor.
Turn the monitor on by pressing the 1 (power)
switch.
If all four color bars appear (white, red, green, blue), the monitor
is working properly. Reconnect the video signal cables and check
the condition of your computer(s).
If the color bars do not appear, there is a potential monitor failure.
Inform your authorized Sony dealer of the monitor's condition.
Be sure to note the model name and serial number of your
monitor. Also note the make and model of your computer and
graphics board.
Mar 18, 2014 | Sony SDM-HS75 17" LCD Monitor
When I turn on computer all I get is a totally green screen blinking gray. Cannot get on the computer
The monitor might be faulty ....do a monitor self test ...disconnect the datat cable from the monitor and turn it on ....there would be a color code , if the color code is ...
RED....GREEN....BLUE which might appear as RGB or the colors itself......then the monitor is ...if the color code is different then the monitor has to be replaced
Mar 14, 2013 | Acer America Acer Aspire AME600-UR368...
Lg flatron w1943tb color fades in and out to a blue green
Follow the following solutions, this should fix up your trouble
1. Turn yourmonitor on. It should be on for at least 20 minutes before you continue.
2.Press the"Auto/Select" button on the front of your computer's monitor. Thescreen will be wavy while the adjustment happens. When the screen stops beingwavy, the faded colors should no longer be visible.
Follow steps 1 and 2 if you do not have a disk for the monitor.
Nov 24, 2011 | LG Computers & Internet
What does it mean by dead cells?
I assume this is related to your LCD monitor.
I think you mean dead pixels. The LCD monitor has tiny pixel elements, one for each red, blue, green color and each one of these colored pixels are turnes on by a transistor. When a transistor fails then the colored pixel it controls does not light up. This is a dead pixel and it shows up as a tiny black dot.
If the screen displays a blue screen, a dead blue pixel will appear as a tiny black dot in the blue screen.
You normally would not notice a few dead pixels unless they are grouped together.
Sep 20, 2010 | Hanns.G Corporation HW191D 19" LCD Monitor
Grainy colors
i have had the same problem with the Gateway LCD Monitor and have found a solution, First go to your control panel Secong there will be a program appearance and theme there you will find something that says screen resolution click it and adjust the color scheme to 1152 by 864 pxels.
May 17, 2010 | Gateway FPD2275W LCD Monitor
Color noise suddenly appeared on screen, blacks show blue noise lighter colors yellow noise
You may have a poor connection with your LVDS cable which connects from the internal main board to the screen. This will either need to bre-seated or replaced.
Sep 23, 2009 | Samsung SyncMaster 245BW Monitor
Screen got yellowish color
Sounds like overstressed video cable, at least that wire for BLUE signal, 'cause when image is yellow - the BLUE color is missing.
Open the monitor and ring coaxial wire in blue insulation.
Sep 11, 2009 | AOC CT720G 17" CRT Monitor
Acer AL1716 monitor
First of all check your monitor's color configurations using the buttons in the monitor. Then, if colors are set to default, go to your GPU's control panel, usually found by right clicking your desktop and finding an option that says ie. Nvidia control panel. Go to video control settings and/or desktop color settings and either restore defaults or configure them yourself if you know what you are doing. Hope that helps.
Jun 11, 2009 | Acer AL1716 F Monitor
Monitor is blueish
If the Blueish problem appears try play around with the VGA cord and see if the Colors comes back, if not, try hiting the monitor to see if the lines and color problem comes bcak to normal. If not your monitor's circuit board needs some dry solder, it could be the cold solder problem. Cheers.
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
The color of the screen is not correctly appearing.
if your monitor has color controls try them,if your monitor has auto adjust try that too.if you can test the monitor on another computer try that as well to verify the monitor is causing the problem.if none of this works its safe to assume that the color control circuitry in the monitor has failed and with todays monitor prices it is cheaper to replace than to repair.
Dec 26, 2007 | Chi Mei Corporation 221D-NBC Monitor
Optiquest Q 71 17" CRT Monitor Logo
64 people viewed this question
Top Optiquest Computers & Internet Experts
Alun Cox
Vladimir Frolov
Tom Chichester
Are you an Optiquest Computer and Internet Expert? Answer questions, earn points and help others
