Question about Leapster Learning System
Leapster2 comes on but won't allow me to sign on. The pen does not respond to the pen
  • Anonymous May 04, 2009
    I am now searching for the answer to fix this as well.  It boots up to the sign on screen and then doesn't respond to name selection with the pen.
Turn leapster2 off. Press and hold question mark button, then turn on leapster2. Keep holding the question mark button until you get a screen that says "touch calibration" on the right. Once you get this screen, let go of question mark button. Press the "A" button to select touch calibration. A small "+" will appear in one corner -- touch it with the pen. Repeat this for all four corners and then the middle. You have re-calibrated the pen. You can then turn the leapster2 off and then on again to play.
If you have tried this and the pen still doesn't work, change the batteries and repeat steps above.
Posted on Jun 16, 2009
We have a Leapster 2 which the screen no longer registers when touched by the pen. Can this be fixed or replaced? i bought it only 2 months ago hope you can help Emma
I posted a solution to this problem a couple months ago. We have the Cars edition of the Leapster2. I'm guessing it was the same problem that we were having. When the pen touched the screen there was no response and the unit had barely been used. Try this!! I found it on www.ehow.com.
Callibration
  • If you touch your stylus pen to the screen of your Leapster2 and it does not respond, your unit needs to be calibrated. To do this, make sure no game cartridge is in the unit. Turn the unit on while you are holding down the "Hint" or "?" button. Keep holding the button down until the Leapster2 menu appears. You will need to turn off the unit and repeat these steps if you do not see the menu. When the menu comes onto the screen, press the "A" button and use the stylus pen to touch each of the crosshairs as they appear. When you are done, your unit should be properly calibrated.
    Read more: Best Way - Leapster 2 Troubleshooting ' eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
  • Feb 02, 2011 | Leapster Learning System
    The screen is not responding
    You can try calibrating the stylus pen. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
    If your Leapster2 does not respond to the stylus pen, it needs to be calibrated. Calibrating the Leapster2 is easy:
    1) Ensure that a game cartridge is not inserted in the Leapster2
    2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER2 menu appears. Remember that you need to hold the "Hint" button down the whole time while you are pressing the power button, and releasing it.
    3) The LEAPSTER2 menu will show the options Base Info, Cart1 Info, Cart2 Info, Cart3 Info, and Touch Calib. If you do not see this menu after powering on the Leapster2, turn the Leapster2 off and repeat steps 1 & 2 until you see the menu.
    4) When the LEAPSTER2 menu screen appears, press the A button on your handheld.
    5) Using the stylus pen, touch each of the crosshairs that appear
    6) Restart unit
    Feb 01, 2011 | Leapster 2
    When you press the screen it dosen't work. Batterys are in a good place i don't know what to do is a brand new toy
    6) Restart unit
    Jan 25, 2011 | Toys
    The stylus pen does not work
    6) Restart unit
    Jan 20, 2011 | LeapFrog Enterprises Leapster2 Learning...
    My leapster 2 won't let me write my name in the screen?
    6) Restart unit
    Jan 15, 2011 | LeapFrog Leapster 2 Learning System
    After charging our green Leapster 2. We turned it on and it won't allow me to get past name selection. It wont select the specified name. Its like the pen isn't working anymore. Can this be replaced?...
    You can try calibrating the stylus pen before trying to replace it. Hope this works :) Here are step by step instructions straight from the Leapster2 website:
    6) Restart unit
    Jan 13, 2011 | Leapster 2
    When I turn the leapster2 on in comes on fine. When it asks me to type in a name the touch screen pen isn't working. Nothing happens!
    we have had this problem with our Leapster2 for a while. Found this solution this morning and it now works great! www.ehow.com
    Callibration
  • Read more: Best Way - Leapster 2 Troubleshooting | eHow.com http://www.ehow.com/way_5868621_leapster-troubleshooting.html#ixzz0wVJdZzs5
    Aug 12, 2010 | Toys
    Cant sign in
    1) Ensure that a cartridge is not inserted 2) Hold down the Hint (?) button while turning the unit on. Continue to hold the Hint button down until the LEAPSTER menu appears. 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
    Jul 02, 2009 | LeapFrog Leapster Learning Game System
    Problems entering name/signing in
    1) Ensure that a cartridge is not inserted 2) Hold down the Hint button while turning the unit on 3) When the LEAPSTER menu screen appears, press the A button 4) Touch each of the crosshairs that appear with the stylus 5) Restart unit
    Dec 28, 2008 | Nintendo Game Boy Advance Console
    Leapster Learning System Logo
    700 people viewed this question
    Top Leapster Toys Experts
    thegtw
    Michael Vincent Cruz
    Dennis Crouse
    Are you a Leapster Toy Expert? Answer questions, earn points and help others
