Question about Black & Decker Garden
GL135 strimmer stopped working but power is on so it is not a fuse etc.Thought it might have overheated but still no action after cooling down
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    hello that number gl 135 is not in the b&d line up do you have a differant number
Ryobi Li-ion strimmer
check that you are using the correct line in the head
if it is too thick , the load will be causing the thermo switch for the motor to stop operation until it cools down
Jun 16, 2017 | Ryobi Drills
Conair hair dryer 1002axa stopped working
The thermal cut-out on hair dryers is usually self-resetting, the device will restore power once the unit cools down... Most of these types of problems are due to lint clogging the air intake and causing overheating, be sure to clean the intake before attempting a repair.
May 23, 2016 | Dryers
New World G90m grill turns off - overheating?
Its a good chance its the thermal control board to the fan (PCB),if faulty it doesnt allow fan to reach correct speed thus overheating.
Hope this helps
Feb 05, 2012 | New World G90m Gas Double Oven
I have a Whirlpool Gold ultimate Care heavy duty Super Capacity Plus. Model: CEQ8858EQO & Serial number: MH1503498. It overheats when it hits the 'cool down' mode, or 'air fluff',...
Hello Gregory,
Their are 2 things that will typically cause that
1) the venting is crushed/blocked/restricted,check the vent from the back of dryer all the way to where it exits outdoors
2) i can not find your exact model number so i dont kow if it has a computer control or simple timer
if computer control the thermister(electronic thermostat) is what i would suspect
if simply timer the cycling thermostat is in question
So ya know the thermal fuse is a non resettable fuse and if were bad the entire dryer would not start so disregard it as beig the trouble uless the dryer doesn't run
Gene
Jul 28, 2011 | Dryers
Our dryer is overheating, after 20 25 minutes then we smell a burnt plasticy smell, then we let it cool down, start again, it goes for awhile, then stops, then again overheating, then the smell again.
Firstly, you need to stop running your dryer before you do any further damage,
As you haven't specified your brand or model of dryer, I can only give general advice. It's likely that your thermostat has failed in the closed (on) position. The thermostat cuts power to the element when your dryer reaches the correct temperataure.
Most dryers also have a thermal fuse to cut all power to the dryer if they overheat. This functions as a backup safety device and this only usually trips when the thermostat fails. Your dryer is stopping because the thermal fuse is cutting power, but as you can smell burnt plastic, it's likely some damage is being done before the thermal fuse trips.
Stop using the dryer, and check/replace your thermostat.
Please rate this solution if you find it helpful. Thanks!
Oct 31, 2010 | Dryers
One by one my gauges(rpm,gas,speedometer,oil) stopped working. Is there a sensor that needs replaced? a fuse? dash? Help?
please keep me posted as well, ALL my gauges are doing the same. First the gas, filled it one day and it fell all the way and light turned on, then my themostat, freaked me out, thought i was overheating,...NO just the guage, NOW my spedometer is stuck on 120, and my RPM's are acting crazy. i have read tons with this same problem, WHY WONT the manufacturer DO SOMTHING??
Aug 25, 2010 | 2004 Isuzu Ascender
My Dodge Carivan with 240000 miles is overheating when stopped in traffic cools back down when running at normal speeds I replaced the thermostate and am afraid it may be the head gasket??? any suggestions
sounds like the cooling fan might not be working..check to see if it is working or not...if not check the power to the fan to make sure it isnt a fuse or bad fan motor
Jul 20, 2010 | 2000 Dodge Caravan
2005 toyota corolla ce is overheating when a/c is and i'm stopped
multiple corrections.. possible thermostat,fan, coolant. waterpump etc
Jul 18, 2009 | 2003 Toyota Corolla
Passenger side radiator cooling fan stopped working
I found that for some reason if you start your car and then remove and reinstall the hi and low relays that the fans work. I have done this numerous times on my 1995 lhs. I thought that my fans were defective until by chance checked the relays which engine was running.
Jun 26, 2009 | 1999 Chrysler 300M
LED Light is on, but no sound from sub at all.. Have double backed on all wires but still nothing! HELP!!
I just brought mine to the shop for the same reason. I thought it was something big but it was just a bad fuse. It wasn't blown so when i checked it, I didn't think anything of. If you're using an AGU fuse, try and remove the fuse and touch the two ends of your power wire together and if it's the fuse it should cut on
Mar 18, 2008 | Kenwood KAC-8103D Car Audio Amplifier
Garden Logo
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
