Question about Refrigerators
Water in bottom of frodge
Water in bottom of fridge top freezer
  • 1,169 Answers
Sounds like the drain for defrost not draining. probably has got a piece of food or a piece a paper over the hole. depending model you would remove cover for the evaporator to find the drain.
Posted on Apr 20, 2009
  • 3 Answers
Join staws together and blow down drain hole.
Posted on May 04, 2009
Amana refrigerator A4TXNWFWWO1 >top freezer, bottom fridge it's only 10 months old refrigerator won't get colder than 55 degrees freezer is working
There is something plugging the drain line in the freezer which carries water from the defrost cycle to your evap drain tray in the bottom of your fridge. The water has built up and froze plugging the flow of air from freezer to fridge.... find the line and unplug it and let fridge sit and thaw overnight and then some more.
Jul 19, 2011 | Amana A4TXNWFWW Top Freezer Refrigerator
Water on the inside floor of the refridgerator,
remove back panel from freezer and unglog hole where it collects water. its glogged
Feb 11, 2010 | Maytag MSD2756G Side by Side Refrigerator
There is water building up in the bottom of the fridge ( under the crisper drawers). If I leave it there it will freeze. What is causing the water? The fridge is 18 years old.
drain hose is plugged... the freezer it need to drain water when if goes into defrost .the drain from the bottom freezer down to the bottom of the fridge... there is a pan under the fridge that holds the water until it evaporates
Sep 19, 2009 | Kenmore 20.6 cu. ft. Top Freezer...
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
General Electric Fridge/Freezer, dripping water in fridge
Refrigerator/freezers often have a de-icing cycle. Moisture condenses on the evaporator coils and freezes. The deice cycle melts and the water is supposed to flow through a tube to either a pan at the bottom of the fridge or a cup attached to the top of the compressor. Sounds to me there may be a plug or obstruction causing the water to back up. Test with water to see flow through the tube.
Another possibility is the seals around the doors and the insulation in the walls could be compromised. The seals are replaceable. Accessing the insulation is a major pain. I recommend finding another fridge to avoid such pain.
Oct 12, 2017 | GE Refrigerators
GE Side By Side top portion of fridge and freezer not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jan 28, 2009 | GE Hotpoint Top-Freezer Refrigerator
Kenmore bottom freezer keep freezing up.
just called in a sears technician 150 dollar bill that was an easy fix. he says my bottom freezer kenmore fridge with warm fridge problem was due to the pathway being blocked by ice and garbage which is common with these fridges. he took off cover from the fridge bottom and poured boiling water down to the freezer. try that before you replace any parts or call in a tech. next time im getting a top freezer because the blower is on the top not in the middle with the bottom freezers and thus more problem prone.
Aug 13, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Sears Kenmore bottom freezer/refrig #68142model
Jul 20, 2008 | Kenmore 73502 / 73504 / 73509 Bottom...
Fridge and freezer not working right
remove and refix the regulator inside the fridge....
Jan 04, 2008 | Fisher and Paykel Active Smart E522B...
Refrigerators Logo
161 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
