Question about Sylvania SRT2232S 32" TV
Sylvania tv clicks but won't turn on, any help
  • 1 more comment
  • RWSR Nov 18, 2007
    Sylvania Model SRT2332S just clicks ?
  • bon_6464 Mar 21, 2008
    it wont do anything when you try to turn it on manually or with remote..thank you..
  • dtoys99 Dec 26, 2008
    whre can I find an oscillation circuit?
  • 790 Answers
You have fault oscillation you have defective parts inside. at the oscillation circuit.
Posted on Sep 21, 2007
SOURCE:
I have a 27inch Philips flat TV that when its pluged in the light is solid red and TV won 't turn on
Common TV Repair for Emerson, Sylvania, Philips, Magnavox
? 5:35
www.youtube.com/watch?v=nQHWrJJg4Mc
Oct 11, 2013 - Uploaded by Tampatec
Top most common LCD TV repairs for Emerson, Sylvania,Philips, ... my tv wont turn on neither the led ...
Nov 01, 2015 | Philips Televison & Video
Sylvania HDTV Model LC370SS8 won't turn on.
u should check std-by volt .when u press power on , the power on volt must not b drop
Oct 09, 2012 | Sylvania LC320SS8 32 in. LCD Television
Have a sylvania lc26oss1 tv it won't turn on what is the problem
Check its main power regulator board. Check fuse. Check and repalce damaged component/s.
Oct 01, 2012 | Sylvania Televison & Video
Have a Sylvania 6727DF TV and it won't turn on tried different outlet different remote checked the transistors I can't find what's wrong even the ohm's r weak on the cord
Contact any experienced service technician. Its main power regulator section has the fault. The work is a skilled one, and not a user repairable fault.
Aug 26, 2012 | Sylvania 6727DF TV
My tv won't turn on
For more details type in this site name "Electro-help" either to Google or Yahoo search box [not in the address bar of your browser], and click search or press Enter. It is an electronic equipments service help site.
Note the position of hyphen in between words in site name. The site will appear as it is in web; subtitled as Service help to electronic home entertainment equipments.
Pull up older posts.
You can locate this site name, either at the bottom part of first search page, or at the top of second page.
Detailed descriptions are there to help you.
Sometimes, clicking on advertisements by the side and bottom of each post might help you to get details about the availability of spare parts; price and more.
Jun 04, 2012 | Sylvania Televison & Video
I have a Sylvania TV, Model #SRT2232S that won't turn on but havee clicking sound in back
Hello
The LOT [Line Output Transformer] of your TV. It should be replace with same type and number. Actually this is a skilled work. You have to unsoder this component out from the circuit board, and to resolder the new one in place. Have to adjust the perfect screen and focus voltage. Screen and focus voltage controls can be seen on it. This component can be bought from most of the electronic spare part shops at your tow. The number printed on it is important and should be noted. The sample picture of that component is attached here. This component also known as Flyback transformer. OK.
Oct 01, 2011 | Sylvania SRT2232S 32" TV
My Sylvania 32" Tv Model #SRT2232S won't turn
Hello
There is a fuse inside the power supply bard of your sylvania TV. Check whether it has blown out. If bllown out, replace it with same type bothe in size and amperage. If the newly inserted fuse also blow up as soon as you switch on the set, make sure that the power supply section has some short circuit in it, and should be cheked well. OK.
Sep 28, 2011 | Sylvania SRT2232S 32" TV
I have a 32" CRT Sylvania Tv that won't turn
Hello
If the TV doesn't turn ON ata all, it is surely due to some fault with its power supply regulator section. You haven't given any otehr details of your tV, than it is only a 32 inch CRT Sylvanial Tv. No model number; so I only can provide you a solution in general.
Check the ON-OFF switch for its contact. Normally, TVs uses DPST type switches [Double Pole Single Throw]. If any one contact amoung them have any problem with its internal contacts, the set won't switch ON. If the switch is OK, come towards the power regulator section circuit board, and check whether the fuse has blown out or not. If it has blown out, replace it with same type and ampere rating. Never use higher ampere rating than specified. The ampere rating will be maiked either on the rims of the fuse, or at the printed circuit board, just under the fuse. After repalcing the fuse, switch ON the TV and see whether it works well or the replaced fuse blows up as soon as you switch ON the set. If the repalced switch burns out as soon as you switch ON the set, the power supply section has damaged [shorted components in it]; and should be replaced.
Normally for LCD TVs it will be good to replace the power supply as card basis. This power regulator card can be bought from most of the electronic spare part shops at your town, orby the authorised service center for Sylvania at your town. If you may have given its model number, I could send you the picture of the power card of your TV. OK.
Sep 28, 2011 | Sylvania 32 in. Diagonal LCD HDTV
My 32" won't turn on
Hello
Without its remote control, you can't unlock this TV. Get into this link from where you can buy it.
www.emtcompany.com/sylvania-srt2232s-remote/rc64.html
The price quoted is $19.95 [Shipping free]
OK.
My sylvania lc320sl1 won't turn on, the power light is red, blinks in green, but does not turn on. What should I do?
I followed what Bob Newell posted and it worked. i had the same problem with the TV not wanting to turn on. after i installed the update it works fine and turns on every try.
to install the update you have to turn the TV on so keep trying till it does. took me about 20 tries pushing the front panel power button, once it powers on the install will auto start and just let it do its thing.
Jan 07, 2011 | Sylvania Televison & Video
Sylvania SRT2232S 32" TV Logo
125 people viewed this question
Top Sylvania Televison & Video Experts
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
