Question about Amcor AD400E Dehumidifier
AMCOR AD 400E Dehumidifier----humidity display reading "HI"
We've had this machine for about three years now with no trouble. Recently we noticed the digital display is reading "HI", when it normally reads the current humidity in the room. I also don't believe the compressor is shutting off, but running steady. It appears to be doing its job since there is water being pumped out regularly. However I don't believe the humidity is really that high right now, probably about 55%. I'm suspecting that the humidistat may be bad on the machine? I did thoroughly clean the coil and dust around the humidistat. Thanks in advance for your help.
MNTECH
  • 1543 Answers
SOURCE: Dehumidifier problem
First, make sure the rectangular filter on the back side is clean so air can flow over the coils freely. Try to place the dehumidifier on a table or something to get it off the floor. (floor level is cooler than head level) If you still have icing issues, replace sensor. (part # WK23X10011 )
Posted on Sep 01, 2008
  • 117 Answers
SOURCE: AMCOR SD10 Dehumidifier, Need to replace the electric fan motor.
Take it out, and search the part number on line, they are bout $40 with s/h. however my current discovery:
It made no sense to me that despite no visual issues, the fan motor is bad. So, with further research it turns out that the true culprit is the small thermistor/thermal fuse between the orange wire (ground) and motor winding wire. The thermistor is taped underneath the silver aluminium and yellow tape on the fan motor. I heard about this bad (open/no continuity) thermistor makes almost >99% of the fan motor problem regardless of any brand name because this cheap c-fram fan motor is NOT made in USA. I opened the motor, there is a silver (aluminum wrap) around the windings for the motor that needs to be cut. Careful not to cut the motor windings. Inside there is a thermistor or type of temperature sensor connected between the orange wire and a motor winding wire. On my motor this was no longer working.
The part marked "JET 123 NM1 2A 130C" is a thermal fuse. The 130C is the temperature rating. When the motor get hot (130C / 265F) the fuse opens. The circuit is broken and the motor stops.
The motor is still good. The fuse is blown. It must be replaced to get the motor running again. You could bypass the fuse but then you invite a fire hazard.
A replacement fuse is available from Digi-Key. It is a Cantherm SDJ1 DF128S (128C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1133-ND
Part cost 98 cents
You might want to go with the next higher temp (141C):
http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=317-1134-ND
Posted on Jan 05, 2010
  • 117 Answers
SOURCE: I have an lg dehumidifier LHD 45EL. The humidity
Possibly the primary humidity sensor behind right side grill. Unit MUST be unplugged from outlet. Take right side grill out, unplug sensor from wire socket and plug back. If no help, you need new sensor.
SOURCE: DeLonghi DEN500P Dehumidifier Humidistat
I have the delonghi DEN500P and the unit runs but does not condense any moisture? The appropriate buttons have been set to bring the unit humidity setting well below humidity in room
Posted on Apr 24, 2010
  • 1156 Answers
SOURCE: My Haier dehumidifier #HD656E will not start up
Haier is a Chinese home electronics and domestic appliance manufacturer headquartered in the Qingdao district of the city of Shandong. The company makes a range of home dehumidifiers that are designed to reduce the amount of airborne moisture in a room. If you have problems getting your Haier dehumidifier to start, you can run through a few simple troubleshooting steps to try and resolve the problem.
Instructions
1.Verify that the dehumidifier is plugged in and the outlet is getting power. Make sure the dehumidifier is turned on. Plug in a lamp to test the power supply; if it does not light up, make sure the fuse or breaker has not been tripped.
2.Pull the water bucket from the front of the dehumidifier and empty its contents. The dehumidifier will stop working to prevent the bucket from overflowing. Replace the bucket and wait about three minutes before starting the dehumidifier again.
3. Make sure that air can circulate around the dehumidifier and that the filter is clean. Curtains, blinds and furniture can limit the amount of air going into the machine and cause it to stop. Place the dehumidifier away from any obstructions. Pull the filter from the back of the machine and clean it with a vacuum.
4.Unplug the dehumidifier and let it stand for a few minutes. Plug it back in and try switching it on again. This will allow the machine to reset itself.
5.Contact Haier for repairs. If these steps fail to solve the problem, you may need to repair or replace your dehumidifier. You may be entitled to free repair or replacement if your Haier appliance is within its warranty period.
Hope it helped
Posted on Jun 18, 2011
Fedders dehumidifier guage problem
call Chas&Son,s appliance repair at 570-379-0993 and they will come out the same day no less okay
Dec 26, 2011 | Fedders A7DH45B2A Dehumidifier
I acquired used Amcor AHD65 Dehumidifier a couple days ago. I was told that it is just beyond the warranty period. I assume that it is a barely a year old. However, It worked this evening a sort since it...
You may still have some packaging materials left inside the unit. The plastic pan doesn't stay in side the bucket. It's used as a drain pan on the outside. Also, be sure the air intake filter is in place, is clean and there are no packaging materials behind it.
To extract more humidity, after checking all the things mentioned above. Lower the extraction level to 32 to 35%. Lower percentages means extraction of more humidity. (i.e.200% -35% = 5% drop in humidity).
Hope this helps you troubleshoot and solve the problem. Please let me know. Thanks.
Jun 11, 2011 | Amcor AHD65 Dehumidifier
Everything seems to be working although I've set the humidity level at 50 but container still dry and humidity level still remains at 70. I trouble shooted everything per manual by cleaning filter...
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
May 26, 2011 | DeLonghi DE500P Dehumidifier
I have a 50 series w/ digital humidity level readout. Recently unit reads the room at 30% humidity so it shuts off unless preferred setting is set to continuous. Can the sensors go bad that measure the...
If the humidity level is at or lower than 30%, the unit won't turn ON, until the reaches 35 - 40%. It's rare for the sensors to go bad. Just keep in mind, the dehumidifier is reading the humidity near the floor, not up at say, chest level. Humidity levels change every season, so this really would not be that unusual. Make sure that your clean the air intake filter regularly. Cleaning and wiping down the coolant coils would be a good idea, too..
Hope this helped you. Please let me know.
May 16, 2011 | Frigidaire FDF50S Dehumidifier
I have a Amcor MD 250 about 5 years old..Everything appears to be correct but it is not producing water. Can you help
There are many reasons why a dehumidifier will not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier
heatman101
Feb 13, 2011 | Amcor MD250 Dehumidifier
My amcor dehumidifier tc120 has started clicking recently and now its out put is poor the unit is used in a cellar just to keep control of humidity it works 24/7 then has few days off when full untill i...
heatman101
Jan 17, 2011 | Amcor DC930 Dehumidifier
Dehumidifier doesn't draw in water (humidity).
It may be too cool in the basement for it to work. Mine doesn't work if its 67 or below. Take it upstairs and see if it works there, where it is warmer.
Apr 06, 2010 | Frigidaire FDF50S Dehumidifier
The unit is set at 40%...stiill reading hi...over 3 days
reading of hi, is only ambient reading.
you probably have more humidity problem than your dehumidifier can handle. try adding one, or getting larger capacity model
Apr 05, 2010 | LG Goldstar LD65EL Dehumidifier
Amcor AD400E Dehumidifier Logo
89 people viewed this question
Top Amcor Dehumidifiers Experts
Andrew Taylor
Andrew Taylor
Gil Shultz
Are you an Amcor Dehumidifier Expert? Answer questions, earn points and help others
