Question about Remington Polesaw Wizard
Fingers on pole adjusting/tightning mechanism broke and now I can't tighten or use pole saw.
  • ricoban1 Apr 27, 2009
    have the same problem with the Pole change saw number 106821A. No information or parts available.Which is a shame as otherwise it is a great tool.
  • Anonymous May 12, 2009
    Same problem. use a little duct tape each time.  Any idea where I can get a new part without replacing the entire pole
  • 188 Answers
It depends on what pole you have if the part is available. You may have to get a whole new pole. I suggest you contact Master Parts at 800-446-1446 or you can find them on-line at www.masterparts.net. They should be able to help you.
Posted on Jun 09, 2009
Part of the chain came off track
if it is a pole chain saw , and the chain came off, it is installed the same as any chain saw
undo the cover over the drive end , remove the blade and chain, loosen of the screw that adjusts the blade length
put the chain back on the blade , put the blade and chain back on the machine , replace the cover and do the nut up till it just touches the cover
adjust the screw until the chain is at a position where if you pull the chain off the bar the inside guide teeth are about halfway out of the bar guide
tighten up the cover nut
Aug 13, 2016 | Poulan pro pp338pt pole pruner - trimmer...
Need manual for remington electric chain saw 1,5 hp 14in blade like to know how to tighten loose blade.
There is a slide bolt on the side of all chain saws that allow tightning of the chain. You loosen this bolt and slide the chain bar forward until you can just slide a dime under the chain and the bar. It may take a couple of adjustments as the chain stretches a little after it gets warmed up by the friction of the bar.
Apr 04, 2011 | Remington Electric Chain Saw
Echo pole saw boggs aand wont reach high rpm. I need to reapeatedly manipulate the choke lever for it to stay running. New plug,clean air filter including pick up tube in tank. New fuel lines and primer...
If you must choke it for it to run it is lean. Have you attempted a carburetor adjustment? Start with "H" and "L" at 1.5 CCW from lightly seated. Then try this:
Carburetor Adjustment by Madsens.com
http://www.madsens1.com/saw%20carb%20tune.htm
CW is leaner; to lean will destroy the saw. If over tightened closed (CW) the adjustment screw faces are easily marred; marred adjustments are difficult to impossible to set properly.
Clean the air filter; adjusting with a dirty filter can cause a run lean condition once cleaned and the saw run.
There are 2 wav (sound - idle & full – not highlighted) files that I find most helpful, I think you will too.
An air leak where the carburetor bolts to the engine or the intake manifold can also cause this. If an adjustment does not or has not fixed this I suggest you try your friendly neighborhood Stihl shop. Explain everything you have done to a mechanic there. Good saw shops pressure test the crankcase, fuel lines, and intakes. They have test equipment homeowners do not. Explain what you have already done and ask for a repair estimate. I think you will be pleasantly surprised. Not all small engine mechanics are created equal... why I recommend Stihl. The odds of finding a good mechanic at a certified Stihl shop are in your favor. If not already using 50:1 fuel mix, please ask the Stihl shop what they recommend. Echo on their site has a statement equivalent to "regardless of what your manual says use 50:1". HTH
Lou
Jan 02, 2010 | Garden
Putting chain back on remmington chain saw . Can not dowload manual
Lay chain over sprockets and adjust arm to tighten chain.
Sep 11, 2009 | Remington Electric Pole Saw
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
The chain on my chain saw is slack.
The adjusting screw is usually found on the right side of the saw close to the bar, near the bottom. You will need to loosen the two nuts on the side that hold the bar tight. Loosen them until the bar lifts up and down (about 1/2") with your finger.
There should be a combination spark plug wrench and screwdriver that came with your saw. If not, use a slot screwdriverto tighten the chain while you hold the bar up with two fingers.
When adjusted properly, there should be no hanging slack in the chain when it is warm. It should rest just against the bar so that you can grasp it with gloves on and pull it toward you.
When it is tightened thusly, tighten the two side nuts while holding the bar up with two fingers. If you don't tighten the two nuts enough, it will loosen and the chain will have slack again shortly.
Remember that the hotter the chain gets, the looser it will be. Make sure your chains is getting plenty of bar oil. Never use regular motor oil.
Jun 08, 2009 | Homelite ZR10926 16 Chain Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
Remington Polesaw Wizard Logo
139 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Remington Garden Expert? Answer questions, earn points and help others
