Question about D-Link Xtreme N DIR-655 Wireless Router
Can you run WEP and WPA simultaniously?
I have a DIR655 router and the laptop equivelent adaptor but i have a linksys WMB54G that will only do WEP, anyway around this to get the N speed and still have my WMB54G?
  • williebignut Apr 20, 2009
    I think i might have been confusing in my question. The WMB54G is a wireless music bridge device not a switch or router. It will only handle WEP. If i have WPA or higher on my Dlink router, do all devices connected to it have to be able to use WPA as well? Or if i turn security off on the WMB54G will it work just fine?
  • 371 Answers
If you did do both simultaneously, and you can on the separate systems, you would experience a severe denigration of your service in terms of speed and the real possibility of a lot of down time.
Yes, you can, but should you is the real question. If the linksys only does WEP and you want the N speed, then switch off the encryption of the lynksys.
Posted on Apr 20, 2009
  • Maurice B Thomas
    Maurice B Thomas Apr 20, 2009
    WEP is very slow.....WPA is faster .. Wifi is Slow...Cat 5 is faster.
    The fact that your wireless link has WEP ONLY and has to send its signals in both directions through a combination of dissimilar encryption routines just promises that you will be somewhat disappointed with the performance of your wireless link.
    It also suggests that the particular wireless device you have chosen is a mismatch to your network.
    You will, on occasion, get totally garbled results with such a network configuration as you have described.
    Carefully shop for a wireless device that will allow you to use WPA and a standard key, therefore for your entire network, or you will be back asking why your network is bogged down with unreconcilable packets of data.
I can't find my Linksys information in my computer
Theencryption key secures your data from unauthorized access. The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, configure the router'swireless settings ie SSID, plus the WPAor WPA2 encryption key and then configure wireless cards in the laptops and orcomputers with these router's wireless settings. Then the laptops and desktopcomputers can communicate with your wireless router.
Apr 22, 2011 | Linksys Wireless-N WRT150N Router
Where can I find the WPA or WPA 2 Key on my Cisco N?
The router's password is a Passphrase or the WEP or WPA orWPA2 encryption key. The Passphrase generates the WEP or WPA or WPA2 encryptionkey and this is in the router's wireless settings. To connect to your wireless router, it needs the router'swireless settings configured ie SSID, WPA or WPA2 encryption key and also thewireless cards in all the laptops and or computers needs to be configured withthese router's wireless settings. Then the laptops and desktop computers cancommunicate with your wireless router.
Mar 19, 2011 | Cisco Linksys Wireless N Home Router...
I have the wireless -G music bridge (model WMB54G) - I had forgotten the password so I reset it - Now, my computer will not recognize it - any suggestions?
The Linksys Wireless-G Music Bridge (WMB54G) has a web-based setup page that allows the user to customize settings and set up advanced properties.
Step 1:
Open a web browser.
Step 2:
Go to the Address bar and enter your router's IP Address, then press [Enter].
NOTE: The default IP Address of a WMB54G is 192.168.1.210.
NOTE: If the IP address of the WMB54G has been changed, type the WMB54G's new IP address in the Address bar instead.
The WMB54G's IP address can be changed by:
    • Running the WMB54G's setup CD.
    • Changing it on the WMB54G's web-based setup page.
If you forgot the WMB54G's IP address you can:
  • Press the Reset button underneath the antenna for 30 seconds.
NOTE: This procedure will reset the WMB54G to factory defaults. Any settings on the Music Bridge will be erased. The Music Bridge's IP address will be 192.168.1.210and the password will be "admin" after resetting.
Step 3:
A new window will prompt for a User name and Password. Leave the User name field blank, type "admin" in the Password field, then click OK.
NOTE: If the password of the WMB54G has been changed, type the Music Bridge's new password in the Password field instead.
Feb 28, 2011 | Linksys Wireless-G Music Bridge (WMB54G)
What is a WEP key for a Linksys WRT400N wireless router?
The WEP encryption key (network key) is in your wireless router, without this key the wireless router won't allow the computer or laptop to connect to this wireless router.
I recommend you use WPA or WPA2 encryption, it is much stronger than WEP.
The WEP, WPA, WPA2 encryption key is in your router's wireless settings. Log into your router and got to the wireless settings, you will need to get the SSID and the encryption key. Then go to your computer or laptop's wireless card and configure it with the router's SSID and encryption key, so it will then connect to the wireless router and the Internet.
To secure your wireless network from unauthorized access,please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 01, 2011 | Linksys WRT400N Router
How do i set up the wireless bridge without a
You need to configure your router.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on WAN settings and set those settings as your internet service provider settings.
Enable DHCP if you want to get ip from router.
Clickon wireless settings enable wireless then enable WEP Security then add WEP code .It isyour password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Let me know if you need further assistance.
Thanks for using FixYa.
Jan 30, 2010 | Linksys Wireless-G Music Bridge (WMB54G)
The linksys utility always sends signal to PC speakers, even when wmb54g unit shows connected. The wmb54g and router are up-to-date and run WEP 128 security encoding. The wmb54g flashes faster when...
I can disable the sound card, set the music bridge as the default sound output device and it works just fine (after rebooting). But if I enable the sound card again, even when keeping the music bridge as the default, the sound goes exclusively to the PC speakers, no matter what device the connection is switched to on the Linksys utility. (By the way the music bridge shows correctly to be connected or disconnected....with no effect on the sound output.) The major hassle is that any usable change of output device requires a reboot. Still testing. Not a single answer from the community. Also I never required the promised temporary password.
Dec 25, 2009 | Linksys WRLS BRIDGE |WMB54G MUSIC R
I hooked up the DIR655 to my computer. I am trying to access the router with my other laptop. I pick up the signal and enter my password, but it will not connect. What do I need to do to connect?
You need to be a bit more specific. I presume the password you are entering is the WEP or WPA one. First thing is to check that you are entering the precise type of password WEP WPA TKIP etc. If you can then connect to the wifi you then need to connect to the network check the TCP/IP settings in the Network configuration settings for the Wireless Network Adaptor - easiest way is choose a number in the same range as your router but a lot higher say 192.168.1.100 and try DNS as 4.2.2.3 and 4.2.2.4
Jul 02, 2009 | D-Link Xtreme N DIR-655 Wireless Router
HP laptop not recognizing Linksys Wireless B Security Key..
The WEP encryption is consist of 10 characters for 64 bit hex, 128 bit hex is 24 characters and WPA is 8 to 63 characters. So it seems that you have a vista computer? The compatible encryption for vista is WPA, sometime using WEP it is not working properly. So I might advise you to access the configuration of your router (192.168.1.1) and change the wireless settings of your router to WPA-Personal.
Mar 09, 2009 | Linksys BEFW11S4 Wireless-B Broadband...
Cannot setup WPA2 on WUSB54G & WPC11 adaptors
This is because those wireless adapters that you mentioned do not support for WPA2. Linksys will not release drivers for those adapters that will make it work with WPA2 because they are already discontinued. So the only other option is to stick with WPA or WEP
Jan 19, 2009 | Linksys Wireless-G WUSB54G 802.11g/b
Connecting issues with wireless mode on WRT54G2
  1. Try to disable WEP in the router and check if the wireless computer will be able to connect to the router and Internet.
  2. Then enable WEP again. If the same problem happens, upgrade the firmware of your router.
  3. Click on the link for the lastest firmware available for your router.
http://www.linksys.com/servlet/Satellite?c=L_CASupport_C2&childpagename=US%2FLayout&cid=1175242897803&pagename=Linksys%2FCommon%2FVisitorWrapper&displaypage=nodata#versiondetail
Hope this helps!
Nov 10, 2008 | Linksys Wireless-G WRT54GS Router...
D-Link Xtreme N  DIR-655 Wireless Router Logo
521 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
