Question about Sport & Outdoor - Others
My honda 2hp outboard won't rev fully without half choke.
After warming up the outboard will not rev up without half choke.  I cleaned the jets and I adjusted the mixture but no joy.
  • Anonymous May 22, 2009
    Engine does not run properly unless choke is left half out.
    Problem Solver:
  • 14 Answers
Yep, the carb (only one) needs to be cleaned. Do not dip in acid. The carb has a special coating on the outside that will be damaged if dipped. It should be cleaned in an ultra sonic cleaner. If that is not avaiable, general a non corrosive solvent sprayed through the various passages ( like brake clean) can get you going. Use compressed air when finished (a can a compressed air used to clean computers works good for little carbs)
Posted on Aug 10, 2009
    Problem Solver:
  • 5 Answers
Have the carbs boiled out.. O M C
Posted on Apr 22, 2009
Briggs Stratton 5hp I/C starts ok, runs, but will not rev
My money is on a partial blockage of the main jet or the passageway to it. You're having to force it to run through the idle jet by fully choking the incoming air. There's not enough gas coming in with the choke open to allow it to run.
I'm thiniking total carb disassembly, carb cleaner and an air compressor combined with a ton of patience will take care of the issue.
Mar 31, 2015 | Briggs & Stratton Briggs Stratton...
2001 Shadow Sabre, Won't idle with choke off unless giving it some throttle.
Hi, Rickgilbreat and the usual suspects are:
1. Fuel cap or fuel tank is not venting properly.
2. Fuel filter clogged.
3. Fuel line pinched or kinked.
4. Vacuum line from the petcock to intake manifold cracked.
5. Float needle and seat sticking.
6. Float level too low.
7. Carburetor bowl vent line clogged/blocked/pinched.
8. Idle adjusting screw set too low.
9. Air/fuel mixture screw set too lean.
10. Idle port, transfer ports, slow air jet clogged.
11. Slow fuel jet clogged.
12. Faulty fuel pump.
For more information about your issue and valuable "Free" downloads that you will need please Click on the blue links below. Good luck and have a wonderful day.
Starts but won stay running unless with choke Discussion
Won idle without choke
Honda shadow vt1100 Owners Workshop Manual
http://www.partsfish.com/page/oem-parts-for-honda
Honda VT1100C2 Owner Manual Page 3
Aug 23, 2012 | 2001 Honda VT 1100 C2 Shadow Sabre
1980 Honda CL 175 will not run without the choke on
Hi, Anonymous and the usual suspects are:
For more information about your issue and valuable "Free" downloads that you will need for viewing or printing please click on the blue links below. Good luck and have a wonderful day.
Carb rebuild and still won run without choke
1980 cb650 will not run without choke
http://waynes-cycles.com/MANUALS/125-CB175-CL125-CL175%20Shop%20Manual-1971.pdf
https://www.partsfish.com/page/oem-parts-for-honda
Honda CB Owners Manuals
Jul 01, 2012 | Honda Motorcycles
1996 Honda CBR 900 RR Fireblade will not idle without choke on
cbr600f3 will only start choke gas givin Honda Motorcycles FireBlades org
F3 won idle without choke CBR Forum Enthusiast forums for Honda CBR Owners
Honda CBR900RR Service Manual
Honda CBR900RR FIRE BLADE Owner Manual
Mar 05, 2012 | 1996 Honda CBR 900 RR Fireblade
Honda Shadow VT750 will not idle without choke on
Hi, Epperson2420 and the usual suspects are:
Need Help Bike won run choke in
Honda 1998 VT750C Service Manual
Honda VT750C Owner Manual
May 01, 2011 | Honda VT 750 CD Shadow A.C.E. Deluxe...
I've got a 1985 honda vf500c. It runs perfect when it is moving, but when I come to a stop and pull in the clutch, the engine takes a few seconds before returning to idle speeds and will stall if I don't...
More than likely, the idle (pilot) jet is partially clogged. This is common when it will idle fine with the choke on, but won't idle without it. Sometimes a fuel treatment will clean the carburator, but not usually successful in cleaning the idle jet. Usually it requires removing the carburator bowl and and cleaning with the use of a gauge wire. The idle jet is usually recessed (next to the main jet).
A good video to show a generic carburator rebuild can be found at this link: http://www.youtube.com/watch?v=exa467_eoXw The guy goes through a pretty detailed description while going throught the process. The carburator will not look exactly like yours, but it will be similar internally.
Apr 27, 2011 | Honda VF 500 F Motorcycles
1992 Honda CB 750 Nighthawk will not idle without choke
Hi, Emeraldcp and the usual suspects are:
13. Faulty auto choke or wiring connection.
Bike won Run without Choke
Oakys Garage Carb clean Pilot Jet clogged Won run without Choke Carbs 101
Honda Nighthawk CB 750 1991 Service Manual
Honda CB750F2 Owner Manual
Sep 26, 2010 | 1992 Honda CB 750 Nighthawk
Have Honda CT110cc postie bike starts and runs well however when warmed up and choke auto off will not idle. Checked air filter/plug/fresh petrol/carby is clean jets etc. Also revs excessively without...
Sounds like you have a vacuum leak between the carby and the head. Check the O ring that is between the carb and manifold. Replace if it doesn't sit proud of the locating groove.
Aug 16, 2010 | 2005 Honda CRF 100 F
2002 Honda VT 1100 C2 Shadow Sabre will not idle without the choke being on
Hi, Esw2035 and the usual suspects are:
Apr 21, 2010 | 2002 Honda VT 1100 C2 Shadow Sabre
Honda magna wont stay on
Time for the carburator/s clean up, it seems the main jet/s is/are kinda blocked.
Jul 24, 2009 | 2002 Honda VT 750 DC Shadow Spirit
Sport & Outdoor - Others Logo
955 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
