Question about AudioBahn A8000T Car Audio Amplifier
Amp keeps cutting off
I have an audiobahn A8000T amp that displays the volts on the top the amp drops below 12v and keeps going down till it cuts off and goes into protection mode but if you tap it on the left side near the red light it comes right back on at 13 to 14 volts
    Genius:
  • 1,039 Answers
Do you have heavy enough gauge wire supplying B+ to amp.Big amps draw a lot of current and require very heavy gauge wire. The longer the run the heavier the gauge needed.
Posted on Apr 25, 2009
I have an a8000t amp with the protection light on, is the amp broke?
Disconnect the speaker wires then the power and ground completly. Then power up the amp and if the protection light turn on the you have an interanl problem if not then you ohm is problably to low and causing the amp to go into protections.
-david
Nov 09, 2010 | AudioBahn A8000T Car Audio Amplifier
My A8000t amps red protection light is on checked
When ever the amp stays in RED protection mode with out any speakers hooked up to it, YOUR amp has internal damage some where. Can't tell you how much to fix, Could be cheap or not worth it. Talk to your local electronic repair, would be a good start.
May 14, 2010 | AudioBahn A8000T Car Audio Amplifier
AMP.... question
12vDC
CFM is negotiable - as the higher RPMs the more air it moves. (also louder).
Audiobahn is out of business - and unless someone is willing to tear theirs apart for your info - get whatever they have in stock :)
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Dec 29, 2009 | AudioBahn A8000T Car Audio Amplifier
Where can I find a cooling fan for a Audiobahn a8000t amp?
Hello fornda,
The fan looks very similar to a 3" muffin fan. The fans from most computer cases would probably fit. You may have to modify how it mounts, and perhaps the connector, but the voltage is the same.
Here's an online retailer. I'd look for the highest CFM at the lowest fan speed to keep the noise down.
Hope this helps.
Aug 07, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn A8000T has power but is not hitting
Check your cap, it prob went bad. That could be restricting the power flow now. Try it with out the cap. that just might be the prob.
Jan 15, 2009 | AudioBahn A8000T Car Audio Amplifier
Audiobahn a8000t problem
If the protect LED is lit, the amp probably has shortedoutput transistors. To eliminate other possible causes, read throughthe following page:
Amp in Protect Mode - Troubleshooting
Let me know if you have any other questions.
Nov 23, 2008 | AudioBahn A8000T Car Audio Amplifier
Amp has power, but nothing going to subs
did you check on the 'remote' terminal? It should have a +12 vdc to let the amp work. You can check this with a voltmeter. Or might be in 'protection mode' (speaker cut-off relay).
hope this helps
Oct 16, 2008 | AudioBahn A8000T Car Audio Amplifier
Amp protection light comes on when raising volume...
It sounds like you either have too low of an ohm load or the voltage is dropping at the amplifier's power terminal.
With your multimeter set to DC volts, the black meter lead on the ground terminal of the amp and the head unit on (so the amp will have remote voltage applied), touch the red lead alternately to the B+ and remote terminals of the amp. If the voltage is below ~11 volts, you need to check the wiring feeding whichever line is too low.
If the voltage remains near or above 12v, disconnect one speaker and see if it shuts down. If it doesn't, disconnect that speaker and connect the other speaker. If it only shuts down with both speakers connected and the voltage is staying above 12v, the ohm load is probably too low and you'll need to rewire the speakers.
Dec 31, 2007 | DB Drive A460 Car Audio Amplifier
Amp cuts out and back on 30 or so seconds!! Volume has no impact
You need to check the B+ and remote voltage on the amp when it cuts off (assuming that you can recreate the fault).
With your multimeter set to DC volts and the black meter lead on the ground terminal of the amp, touch the red lead alternately to the B+ and remote terminals as the amp shuts down. If the voltage drops below ~11 volts, you need to check the wiring feeding whichever line is dropping too low.
Nov 29, 2007 | Kenwood KAC-7202 Car Audio Amplifier
Solution
Sounds like you have shorted output transistors or IC'S There is one test is to disconnect all the speakers and see if they still blow. If they do then you need to have the amp fixed or replaced. If they dont blow try connecting up each speaker till the unit blows the fuse asjust maybe you blew out a crossover or a speaker or two?? If you have an active type crossover then I would check that device as well. Good Luck
Apr 22, 2006 | AudioBahn A8000T Car Audio Amplifier
AudioBahn A8000T Car Audio Amplifier Logo
145 people viewed this question
Top AudioBahn Car Audio & Video Experts
Professor_V
Professor_V
xxxxxx xxx
Jeff Turcotte
Jeff Turcotte
Are you an AudioBahn Car Audio and Video Expert? Answer questions, earn points and help others
