Question about E-Machines eMachines Desktop PC
DISK IS TRYING TO EJECT BUT DOOR WILL NOT OPEN
  • Thomas F. Schneider May 11, 2010
    Using a straightened paper clip with the unit off press the pin straight into the hole on face of the disk player which will manually open the disk door and remoce the disk. Usually after that it will again start working corectly.
  • 272 Answers
Look, there is a hole on the Front. Push something through the hole. Not somthing, that could break and block that. By pushing, You should be able to remove the tray .
Thanks
Rate me if it helped.
Posted on Apr 20, 2009
  • 89 Answers
To open the door there will be a little hole in the front of the disk tray poke a paper clip in that hole noting else and if that doesnt work now take the side of the computer and undo the bolts and open it with a screwdriver
please rate my help to you
Disk drive door wont open. LED light comes on an hums, but tray wont eject to open. Where is manual eject hole located?
Below the drive tray there is a tiny hole, straighten a paper clip and gently insert the paper clip into this hole. Push the paper clip and the tray will release and pop out, then pull the tray out to the fully open position.
Mar 02, 2012 | Computers & Internet
I have a deskstop computer by Acer model AX5900. I am trying to eject a disk but it is stuck and won't eject. Help! What do I do? Thanks
eject cd drive door manually
there are small hole at the cd door, use small thing like paper clip that can in to the hole, push at the hole until the door open, if the door was open you can take thi deisk inside
i hope this helpful
thank you for using fixya
Feb 07, 2011 | Acer Computers & Internet
I have a Samsung DVD R160 recorder. A few days ago the recorder was not on and it was making a noise like it was trying to read a disk. This went on for quite a while. I then turned it on and it would...
Try this, look for a small hole on the front of the unit.Use a pin and press in to see if it opens,ejects the disk .If no hole try seeing if you can press ,lift,pull at the door/slot while pressing the open door/eject either on the unit or with the remote control.It sounds like you may have a bad CD/DVD (copy) that the unit is trying to read/load but can't. keep trying to eject CD/DVD if this doesn't work unplug unit for 5 minutes,try open door again do press and hold open repeatedly I know it's frustrating but it just may eject.Don't use this recorder for playback of DVD buy a $30 DVD player the cheaper the better they play anything.GOOD LUCK
Jan 04, 2011 | Samsung DVD-R160 DVD Recorder
Can't open disk drive door
try this. go to computer, select the drive and select eject this disk.
try restarting your pc if the disk still doesn't pop out
if you have a paper clip there is a hole that you stick and press it and it might come out
Dec 26, 2009 | Gateway Computers & Internet
My Disk drive door won't open up to allow my to install my disk. It makes the clicking noise like it wants to open it up - how do I get it to open?
try to see if the cd/dvd drive would eject if you are outside of Windows. you can try it in the bios screen. to go there, restart your computer, then on the DELL logo, continuously tap on F2 key. once inside the bios screen, press the eject button of the cd/dvd drive.
Oct 10, 2009 | Dell Dimension 1100 PC Desktop
The disk door couldnot open
On the front of most DVD players there is a button with EJECT printed under it.
The same button is normally on remotes.
Try pressing this button.
May 04, 2009 | Televison & Video
DVD DOOR AND VCR DOOR WILL NOT OPEN, DOES NOT EJECT TAPES OR DISK
I have had some luck in unplugging the machine for five or ten and then trying again. I have spent five to ten minutes trying to get the darn thing to spit out the disk and it refuses. Unplugging either gives me time to cool off or it helps the machine :)
Apr 30, 2009 | Panasonic PV-D4745S DVD Player/VCR
DVD Eject tray stuck
I took a stake knife from the kitchen and pried open the tray door as I hit the eject button this got it to open, I then cycled eject and close, eject close a few times and this did the trick, I even played a DVD and that worked fine also. I had the problem with the tray not opening, and the display would read OPEN when I hit eject and I could hear it trying to open. So I wanted to make sure the tray wasn't just stuck or wedged before I took the system apart and looked for sripped out plastic gears or the belt being broken. GoodLuck rayruiz10@yahoo.com
Aug 24, 2008 | Zenith XBS344 System
Disk player door
You would need to disassemble the unit to take out both the CDs. Trying to force the disk out without opening the unit might damage it. If you are not comfortable with open it, please get someone who can actually do it for you. please revert back with the results.
Mar 22, 2007 | Bose (321GS) System
E-Machines eMachines Desktop PC Logo
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
