Verify that that the Print
spooler service, and all the services that it depends on, are correctly installed and running.
- Open the Services Management Console (click Start, Run and enter services.msc).
- Double-click the Print spooler service to open its Properties window.
- On the General tab, check that Startup type is Automatic.
- Select the Dependencies tab.
- Note all of the dependent services listed, then close the Print spooler Properties window.
- Repeat the above steps for the dependent services noted.
If any of the dependent services are missing or cannot be started, try
un- installing all installed printer drivers and then reinstalling them.
If this method cannot be completed or does not resolve the problem, try Method 2.
Method 2
Remove all Print
spooler service dependencies other than the Remote Procedure Call service.
- Click Start, Run and enter sc config spooler depend= RPCSS (there must be a space after "=" but not before it.)
By removing the other dependencies the Print
spooler service should be able to run, but the printer functionality may be affected, and it may be necessary to reinstall the printer drivers.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at
https://www.6ya.com/expert/joe_8b8c2cd6ce148309
