Question about Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind
Leviton Programmable Timer 6124H-W installation problem
I just installed a new Leviton Programmable Timer (6124H-W) and the light fixture will not turn on. The LCD/display & LED on the timer works fine, but when the light is supposed to be on, it doesn't work. I've got all the wires connected as they should be... maybe the switch is faulty? Hence why the display works but the light doesn't? Any suggestions would be appreciated! Thanks.
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Posted on Jul 09, 2011
Programing instructions
you can look here http://www.leviton.com/OA_HTML/ProductDetail.jsp?partnumber=6124H-I&section=44955&minisite=10251 and click the adobe manual for programming instructions.
May 05, 2012 | Leviton 6124H 24 Hour LCD Programmable...
Hi I have decora 24 hour programmable timer 6124h. Its display seems to be working just fine and I can change the settings on this. But its not turning the load on. Any idea? Much appreciate the help on...
I don't have repair for defective timer.
Check wire nut connection going to load.
Confirm that load is operable and turned on.
See if timer is producing output on blue wire.
Try timer in place of a different switch to see if problem is load or wire going to load, or if timer is defective.
Make sure there are both ON and OFF times programmed.
Check wiring:
Timer blue wire to load.
Timer black wire to hot.
Timer white wire to neutral.
Green to ground.
http://waterheatertimer.org/Leviton-timers-and-manuals.html
Aug 07, 2011 | Leviton 6124H 24 Hour LCD Programmable...
HOW TO RESET TIME
6124 is 24-hour timer single-pole timer
Open following link for images, instruction manual, ez set instructions, and wiring instructions
http://waterheatertimer.org/Leviton-timers.html
Apr 18, 2011 | Leviton 6124H 24 Hour LCD Programmable...
The previous owner installed a Leviton 6124H for driveway lights. I cannot figure out how to set the timer so that they go on at 6 PM and off at 12 midnight. I can see there is AM and PM at the top and...
Open following page to download manual, and see wiring instructions for your records:
Programming is simple, but words to explain are longer than space allowed for free answer.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Mar 09, 2011 | Leviton 6124H 24 Hour LCD Programmable...
Lights go on and off not adhering to timer schedule
You posted under Leviton 6124 timer.
I have tested this timer.
If timer worked correctly before and then started blinking, the timer might be bad.
Turn off power to timer and see if timer resets.
If this is new installation and lights are blinking on-off, then white and red wires are probably connected together.
Re-connect wires.
Open link below to read ez-wiring steps, and to access on-line manual.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on timer or any do-it-yourself project.
Feb 13, 2011 | Leviton 6124H 24 Hour LCD Programmable...
Need instructions to set my timer. Where can I find these?
If this is not your timer, add a comment.
Also see Leviton timers at:
Leviton 6124 manual
http://waterheatertimer.org/images/6124-manual.pdf
Wiring for 6124 timer:
Add a comment if you need help wiring this timer
Nov 30, 2010 | Leviton 24-Hour LCD Programmable Timer,...
I have a black and white wire to hook to. leviton has black, blue and white. green also but thats a ground. what do i do with the blue wire? this is a single switch to a gfci then to outside lighting....
The blue wire is the switched hot wire coming from the leviton.
So:
black hot/source to black leviton -- blue leviton to black for light fixture or black "line" on GFI -- all whites connected together.
Charlie
P.S. If the GFI is only powering a light fixture, it is not needed.
Sep 23, 2009 | Leviton 6124H-A 6124H-A Decora LCD Timer...
What do i do with the third wire
You do need a neutral for a timer switch, that is the white wire coming off the timer. The black wire is for the hot wire coming into the box, and the blue wire is the wire going to the light.
Jan 15, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Leviton 6124H 24 Hour LCD Programmable Decora Electronic Incandescent / Ind Logo
677 people viewed this question
Top Leviton Hardware & Accessories Experts
Hippy_dd
Gene Haynes
Are you a Leviton Hardware and Accessory Expert? Answer questions, earn points and help others
