Question about HP PSC 1210 All-In-One InkJet Printer
Get refilled ink cart. to work
When putting in a new refilled cart.in my HP 1210 it does'nt want to print black. Is there a way to get the ink started flowing.
    Director Badge:
    Uploaded 100 video answers.
  • 1,751 Answers
Probably one of your cartridge is no good
check the contacts ..try clean them with
a wet towel
Posted on Apr 26, 2010
New HP 56 cartridge prints green
hello, are you sure its green, since this is a black in cart, only thing i can think of is machine not printing black , and the color ink cartridge is contaminated, this would be due to the docking area for the cartridge, on the left side of machine, there are 2 black rubber cups that the ink cartridges move over to seal. sometimes these cups have residual ink, which will contaminate the new inks. clean these black cups, and replace inks
Sep 24, 2010 | HP PSC 1210 All-In-One InkJet Printer
Had printer cartridge refilled but when i put it back in the messege says incompatible ink cartridge-black
I would never use refilled ink. This is a lesson. You can still print, yet the cartridge needs a new "chip" they should have given you when they refilled it. You can try: remove the cart. turn off printer, unplug it, then put old cart back in. Do this three or four times and the memory of the printer can only remember three or four resets and then put refilled cart in. Hope this works for you. I was told this for an HP 7130 (similar, yet older version).
Brock
Sep 16, 2010 | HP 8500 Premier All-In-One InkJet Printer
I refilled my tri-color cartridge at Costco and my printer wouldn't print the alignment page. I bought a new cart and it worked fine. Then I re-installed the refilled cart to verify the fix, and it still...
a refilled cartridge IN NO WAY can lead to printer failure
the ink is the last thing on printer and has no effect to mechanical failures.
check here how you can refill your cartridge
http://www.youtube.com/watch?v=II9gpIXs_lE
Jul 02, 2010 | HP PSC 2210 All-In-One InkJet Printer
Problem with hp deskjet 640c printer
i have an hp and find that they (color carts) cannot be refilled- the clever b*st*rds!! they stepped the ink reservoirs so, if you don't insert the re-fill needle 'just right', it bleeds into the others and you end up with a 'muddy' print-out! you need to buy a new hp cart, or shop around for a generic cart (cheaper) google your product & cart #. you may find a source for a cheaper cart.
the black carts. can be re-filled!
good luck!
Oct 08, 2009 | HP DeskJet 882c InkJet Printer
Printer not printing in black. Print Color only.
Hi
Thanks for using FixYa. First of all please try the refill cartridge on some other printer. If it’s working fine on the other printer then check the settings of the printer which are by default 960 dpi (dots per inch) but due to some reason this size has been reduced. Now you have to change this setting to more than 960, around 1200 dpi and then check out that if your printer works fine.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 28, 2009 | HP PSC 1210 All-In-One InkJet Printer
Check print cartridge error
Try pushing it gently using some pressure. I had the same problem and it got solved using a little push.
Aug 27, 2008 | HP PSC 1210 All-In-One InkJet Printer
HP officejet 6210.
Put the printer in the mode for changing the carts. Take out the Black ink car and clean off the heads on it. Looks like brown in color it's on the cart at the bottom To clean use paper towel with cold water never use warm or hot. Clean the area where the in rest in the printer also if you can reach it. The noise you hear is that the cart didn't go back in the right position. You have to be cart not to force these carts out as everything in this printer is made of plastic.
Jul 23, 2008 | HP OfficeJet 6210 All-In-One InkJet...
Refilling lexmark cartridges x2500
Hey....I solved the lexmark out of ink problem!!!HA!!! what you have to do if you want to refill these is "pop" off the top of the cartridge. It is not easy as it is glued down...using a small screwdriver preferably a small flat jewelers screw driver you can peel back the plastic that seperates the "lid" of the ink cartridge. you have to use a little force but you can get it off. Once you do this the cartridge will always read full!!!!!! just tape it or super glue it back on. You never have to take it off again! although I recomend cleaning the ink sponges inside every 3 refills. but this works great.....ha ha lexmark.....I got ya!!!!
Jun 03, 2008 | Lexmark X2500 All-In-One Printer
Color prints too dark
1. Took out the color ink cart and clean the copper contacts of the ink cart with cotton swab, make sure that you do not touch the silver nozzle .
2. Try new ink color ink carts as someime this issue came up when the ink carts are about to finish up.
3. Replace the ink carts and do not us a refill ink.
Dec 26, 2007 | HP OfficeJet D135 All-In-One InkJet...
HP 20 ink refill problem
Did you try a new ink cart? Most print problems with inkjet machines are refilled carts.
Nov 18, 2007 | Brother IntelliFax-2820 Laser Fax
HP PSC 1210 All-In-One InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
