Question about Olympus FE-280 Digital Camera
Lens stuck open will not retreat battery fully charged when it is turned on lens moves in and out but will not fully close
Olympus fe-280 8.0 megapixel camera, lens is stuck wont retreat.
  • 1 more comment
  • jsms3 May 14, 2009
    i had the same problem after my girlfriend dropped it about 2 months ago. the lens was stuck out and sort of cocked sideways. when i turned it on it made like a loud clicking or popping sound i think three times and shut off wouldnt do any thing else.so i was mad one day and grab it and turned it on while pushing it in harder and harder till it snapped back in place and has worked all functions fine ever since. just understand i am only saying what i did and it worked. i do not take any responsability for someone further breaking and blaming me
  • Anonymous May 23, 2009
    have same problem with mine is a sanyo digital camara
  • Anonymous Mar 18, 2014
    lens wont close when turned off
    President:
  • 919 Answers
The problem you are describing is a problem with something in the lens assembly of the camera. It seems to have failed and needs to be replaced. Following are the instructions to send your camera to Olympus for service.
http://olympusamerica.com/cpg_section/cpg_servicerepair.asp
Olympus will charge a flat rate repair fee for this product if beyond the one year factory warranty or the warranty is voided. The cost is $66.85 plus your local sales tax. This covers parts and labor, factory cleaning and diagnostic check, 6 month warranty and the cost of shipping the product back to you is all included in that price.
Posted on Apr 21, 2009
SOURCE:
I dropped my Olympus FE-340 digital camera. It will not open when I turn it on. The lens stays closed and inside the front of the camera.
Sounds as if an internal linkage has become misaligned. Not user serviceable, unless you are an expert - scamper down to your local friendly camera dealer or repair facility and see how much they would charge. May be cheaper to replace the camera, unfortunately.
Dec 26, 2015 | Olympus Cameras
My olympus FE-280 will not turn on. I put in a fully charged battery and when I press the power button the light on the back blinks red and the lens opens and closes about four times before completely...
There are many sides to the fault but it seems that you have a serious one. The camera needs to be opend to confirm the fault and so it needs experienced hands. The possible fault could be failure of the electronics, maybe the shuter drive, the lens drive or maybe the flash section. Assuming that your battery is good the fault can be related to a shorting or power related malfunctioning. Disconnection of one of the sectionmay be needed to confirm but an access to the camera electronics is a very sensitive job . so take help and hope the fault is economical. Good day
Aug 10, 2010 | Olympus FE-280 Digital Camera
LENS COVER STUCK ON CAMERA OLYMPUS FE 280
Well lens errors are very common in these digital cameras. Usually it's sand or grit interfering with the lens extension mechanism.
Check the below link to do a try to correct it -
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
If further you have the same problem it means there is a gear-motor alignment of the lens which moves in and out with the help of motor. This part is replaceable at an authorized Sanyo Service Center. Aprox repair cost is $120.
Good Luck!!
Thanks for using FixYa
Apr 21, 2010 | Olympus FE-280 Digital Camera
When I turn my FE-230 on it opens and closes the lens multiple times before it stops.Looking in the window the images are blured.I use the auto settings and take pictures of machines.The batteries are...
This is a well known problem with these lens. They have very small focus gears and they get stuck quite easily by sand and dust. The lens unit has to be taken apart and the gears should be cleaned under a microscope. I repair these every day. I would suggest you contact a local camera repair center and let them clean it.
Tom
Mar 03, 2010 | Olympus FE-230 Digital Camera
Focus problem olympus fe 34o
Not focusing at every distance - close to far ?? That seems like a lens problem to me and how the lens is focused, once its fully extended, varies between camera brands. .
Have you dropped this camera or knocked the lens when it has been open ?? Or have you dropped it at the beach and got sand or grit in the lens ??. If it is a lens problem it will have to go back to the service agent for repairs - ther is nothing you can adjust inside unless you are a camera technician
Nov 07, 2009 | Olympus FE-340 Digital Camera
Same exact thing......My mom thinks it needs a new battery.
Hi!
It sounds like your camera lens focus is stuck - could be sand or something in the focus gears - that's the weak spot of these lens. If you can't open the lens and check your lens focus gears yourself, you should contact your local Olympus service center or other camera service center. You can contact me too at toms.safranovs@gmail.com and I can give you a good price.
Hope this helps!
Tom
Jul 29, 2009 | Olympus FE-280 Digital Camera
FE-280 Lens Blurry Photos and no zoom turns off
You have a bad lens. Unless the camera is in warranty the cost of repairing the lens is higher than the value of your camera. The strange noise you hear is the lens motor trying to move the lens. One solution is to blow compressed air around the lens. Sometimes dust and dirt may jam the lens.
Jul 02, 2009 | Olympus FE-280 Digital Camera
Zooming
The exactttt same thing happened to me. I think i still have a warranty on it, and every body has been trying to help me, but it seems the camera is just retarded- and just needs to be replaced
Jan 03, 2008 | Olympus FE-280 Digital Camera
FE-280 Wont Focus and Shust Off
I have the same problem, but my display doesn't show anything. It is just black.
Dec 10, 2007 | Olympus FE-280 Digital Camera
Olympus FE-280 Digital Camera Logo
530 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Steve Allison
Steve Allison
Are you an Olympus Camera Expert? Answer questions, earn points and help others
