Dahon Mariner D7 Logo
Fred Villoso Posted on Sep 30, 2013
I have dahon mariner I want to know how to remove the rear tire so I can fix the flat tire.
Colin Milne
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Oct 05, 2013
Colin Milne
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
667
Points
15
How to reset tire low light on 2010 Mercury mariner
THe light will reset it self the computer will reset but all the tires have to have 32 psi then drive it about 5 miles it will reset if not you have a bad tire sensor usually if you had a tire flat fix that the one that will be bad becusa when the remove it they alway Berkeley the sensor good lucl
1helpful
How do I change to a 56T chainring on my 2012 mariner?
If I remember correctly, those chainrings aren't the replaceable kind. you will have to order a crankset with the appropriate chainring tooth count you are seeking.
Rear tire repair
take one brake pad off
Rear flat
An in depth video about how to easily change the rear tube on your bike
Cannot pump up tires
It looks like you have problem with either tire or pump, but I believe you have problem with steel nipple on the tire.
3helpful
2answers
I dont know how to lower the handlebars on the Mariner
Take the spacers out and cut steerer tube.
How do you undo a wheel on a dahon speed 7?
Hello, I have a Dahon XP which is similar to yours and to undo a wheel is very simple, because the wheels have a quick release lever on the right side of the axle going through the center of each wheel hub. Simply grab the lever and pull it open to take the wheel out, for example if you want to change a flat tire.
Top Dahon Cycling Experts
ADMIN Andrew
ADMIN Andrew
Kardoc
Tony Parsons
Tony Parsons
Are you a Dahon Cycling Expert? Answer questions, earn points and help others
