Question about Electronics - Others
Shark 75160HS 2.1 Multi media speaker system
I have connected the speakes and subwoofer to the computer and although there is clearly power going through, I have no sound coming through the speakers. I had this problem with previous speakers and thought that the fault was with them but these are brand new!!! I have checked the volume settings onthe computer and everything seems to be in order but still no joy! Can you help? Thanks P
    Sergeant:
    Champion:
  • 293 Answers
HEADPHONES AND SPEAKERS Hi There Try this, CONNECTION Check your connections on Rear part of your PC. Lime is for Sound Out usually a speaker, Pink is for Mic, Blue for Audio Input. VOLUME Try Adjusting the vlume on your PC first. Check the volume on the Headphone too if there is one. CLEANING Using a dump clothe. Wipe the plugs and jacks with a twisting motion. WIRELESS\BLUETOOTH Check your battery if it is drained. Try replacing them with a new one or charge them if they are rechargables. If all fails then You may have a Sound Card problem. Using a spare Speaker or Headphone check it if it works. If its not then its Defective and needs replacement. If its working then your Speakers or Headphones are defective. Try fixing them by cleaning or checking the Continuity of its cables using a analog Multi tester. Hope This helps ======================= If you are having trouble with Newly bought items then return them and demand a replacement or a refund! You may have purchased a reconditioned\repaired\factory defect product.
Posted on Sep 21, 2007
My MacBook's audio still on even when harman Kardon speakers are connected to the computer.(Original version with USC connectors).
As I seem to recall the very first version was powered by the computer and as such may not be compatible with your Mac. I may be thinking of Apple's Clear speakers though? Do your HK Soundsticks have a power adapter or AC cord?
Oct 15, 2013 | Harman Kardon HARMAN/KARDON SOUNDSTICKSII...
I have an old Philips Amplifier which I bought 18 years ago. The Amp actually can handle 5 speakers but I only connect 2 speakers (L & R). When I play certain DVD, although the background music sounds...
If you identified the specific products involved we (and you) might be able to look at the documentation and verify the obvious answer. Voice is generally concentrated on the center channel, so, yes, a speaker there would be a good idea.
If you don't have a multi-channel rig you shouldn't feed multichannel audio to it. Maybe use the unidentified DVD player's analog output and make sure it's set to mix the channels down to stereo.
Jul 01, 2011 | Philips Audio Players & Recorders
How do the wires go into the back of the creature?
First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
Hope this helps
Dec 30, 2010 | JBL CREATURE II Computer Speakers
I recently picked up the THC-c60 system without the supporting amplifier. Can I still use the subwoofer and the speakers without the amp? I note that it also came with a DIN cable, is there some way to...
You can use the sub-woofer and the speakers even without a supporting amplifier. The sub-woofer alone is powered with 167w per channel enough to power all the speakers. The DIN cables used to connect the sub-woofer to any source device like a computer, multi-media projector and others.
Dec 02, 2010 | JVC TH-C60 System
I HAVE A 1994 BUICK GRAND SPORT. I WANT TO HOOK A STERIO UP BUT THE STERIO THAT CAME WITH THE BUICK HAS A DOUBLE COMMPONET SET UP . HOW DO I BYPASS THAT AND HOOK UP THE CD PLAYER TO THE SPEAKERS?
1) Understand the basics of all car stereo systems. A car stereo system consists of 4 main components and the wiring that connects them. These are the head unit, the main speakers, optional amplifiers and the subwoofers, which are also optional but generally considered a necessary part of any good system. 2) Know that the core of any car stereo is the head unit, which is the cassette or CD player that goes in the dash. All the other components are connected to the head unit by at least one pair of wires. 3) Know about car speakers. The main speakers are usually 2 in the front and 2 in the back, although with what are known as component speakers, each speaker is broken down into two speakers: one for the highs and one for the bass. Each speaker or speaker set (known as a channel) connects to the head unit via a pair of wires. Generally if you are installing a new head unit you want to install new speakers. 4) Know about amplifiers. Amplifiers provide extra power to your speakers and/or extra channels of power for additional speakers. The most common use for an amplifier (amp) is to power subwoofers. The amp connects to your head unit via an RCA cable and often a "remote on" wire, and also connects directly to your car battery through a fused "hot" wire and to the car's chassis with a short ground wire. This article assumes the use of a single amplifier connected to a pair of subwoofers. If you do not have these components simply ignore the steps specific to the amp, doing so will not affect the rest of your installation. 5) Know about subwoofers. Subwoofers are part of any good stereo system. They provide the deep bass that small speakers cannot achieve. Subwoofers are connected to the amplifier which can usually be mounted right to the subwoofer box. If you do not have subwoofers you can simply ignore the steps specific to them. FOR more help click on this link directly http://www.ehow.com/how_5829_wire-car-stereo.html ------ This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Jan 25, 2010 | Car Audio & Video
My Altec lansing multi media ada 745 just stopped working all of a sudden. It doesn't work for all media ie. ipod, tv, computer. We can hardly hear it. I changed the fuse but it still doesn't work. Wh
unplug the power from the speakers, reseat the all the connections for the satellite speakers, ensure the power switch on both the subwoofer and the Right Front Speaker are in the ON position.
If that doesn't resolve the issue, then you are most likely going to need to replace the speakers, as the fuse is the only serviceable componet.
May 20, 2009 | Dell Computers & Internet
No sound out of subwoofer
Connection from receiver subwoofer output jack RCA plug male go into your powered subwoofer low level input with other end of cable, then you need to select Subwoofer YES/NO on the JVC receiver speaker setup menu option, select YES if this is a powered subwoofer you are using, should power up the subwoofer, may have to adjust a test tone balance for multi speaker output also, try trimming up on the subwoofer channel to initiate the signal on if the sub has an auto-on feature.
Feb 07, 2009 | JVC RX-5020VBK Receiver
Can't get sound JBL Media 100 speakers/ subwoofer with mac
I am not sure what the extra lead is for. The instruction book should make it plain how it should be connected. If you have no instructions perhaps they can be downloaded from the manufacturer's website.
My 5:1 speaker system is prewired and has only one audio in lead and a socket for the power supply. The audio lead of such speaker systems is generally equipped with a 3.5mm stereo jack plug intended to be used in the headphone socket of computers, tv's, radios and anything with a headphone socket, even phones.
Once you are certain the speakers are properly connected they should work if there is audio present at the headphone socket of the Mac. A known pair of headphones can be used to test this and conversely the speakers could be tested by plugging them into any other known good audio source.
The presence of an RCA or phono plug/lead is confusing as these aren't usually associated with active speaker systems for computer and general use but rather for more serious audio such as connections between an amplifier and peripherals or cinema surround sound. Such a system probably wouldn't be suitable for use with a computer...
Apr 01, 2017 | JBL Media 100 Computer Speakers
Volume very low won't go up
After I posted my problem, I browsed a bit further through the other posts and solutions, until I came across the solution of TrickyTrev34 and gave it a try. However, I did not slice the cable, but did it as follows: 1. Switch off power of the sound system on the subwoofer box. Disconnect the Front Right (FR) speaker box (the one with the volume control) from the subwoofer box.
2. Remove the silver coloured metal oval on which the speaker box stands. Now you'll see a small screw at the bottom of the speaker box. remove it. 3. Carefully remove the silver coloured metal protection plate (with all the little holes) from the front of the FR speaker box by wedging it from the top with a flathead screwdriver or other thin blunt object. Now you'll see the speaker and 4 holes with screws inside. Remove screws and speaker box opens up. 4. Inside you should see six wires (Red, Blue, Yellow, White, Green & Black). Carefully cut the GREEN wire only.
Insulate the both ends of the GREEN wire with electrical tape or heatshrink or similar.
5. Put the FR speaker box back together in reversed order. 6. Connect FR speaker back to the subwoofer box. Make sure the volume setting on your PC is very low, because when you switch back on the power of the subwoofer, you should be blasting again. As TrickyTrev34 already mentioned, the only downside of this procedure is that it will disable the volume control on the FR speaker, but who cares, your sound system works again, and you can still control the volume via the PC playback control panel and/or the multi-media keyboard if you have one.
Aug 08, 2008 | Altec Lansing Multimedia Computer Speakers
Electronics - Others Logo
140 people viewed this question
Top Electronics - Others Experts
Marvin
Marvin
Are you an Electronics - Other Expert? Answer questions, earn points and help others
