Question about Lexmark Inkjet Z517 Photo Printer
Lexmark Z517 wont print black ink
Hey, i recently installed my friends old 517 onto my compter (only 6-7 months old)and trying to print off a test page noticed that there was no black ink, and anything i printed afterwards would have no black ink whatsoever (a microsoft word document for example comes out blank instead of with text), the ink cartridges are only 4 months old, is it possible that this is just a case of dried up ink or something else (im doubting its dried up ink because i was the first person to use the 4 months old ink cartridge), please help
  • rmccain Jan 05, 2008
    I have a Z517 and the ink level shows 3/4 way full.It wont print nothing, tried test page and everything, its been about 8 months since I used it.I took the cartridge out and looked it over,some ink got on my fingers, and there is no black cartridge,I hate to buy ink cartridge, cost more than I paid for the printer new! What should I Do! Thanks!
    Scholar:
  • 68 Answers
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Posted on Sep 21, 2007
Lexmark driver 517 for windows 7
Use the Vista driver in Windows 7. First, check if your system is running on 32-bit or 64-bit operating system. Go to Start menu > right-click on Computer > click on Properties. Take note of the System Type.
Use the link below to download the corresponding printer driver for your operating system:- Lexmark Z517 Driver for Vista/Windows 7 32-bit- Lexmark Z517 Driver for Vista/Windows 7 64-bit
Simply follow the instructions on your computer screen to complete the installation.
Feb 22, 2012 | Lexmark Z51 Color JetPrinter InkJet Photo
Lexmark x1270 wont print color even though the cartridge is full.
A technique to improve print quality is to try and clean the cartridge nozzles. You may clean the cartridge by following the steps given below:
1. Go to the "Lexmark solution center." This can be done by clicking on "Start," go to "Programs" and Lexmark printer group. Click on the "Lexmark Solution center." Next click on the "Maintenance" Tab.
2. Select "Clean and Fix Horizontal streaks." Click on "Print". This will produce a printed page.
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzle" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
1. Please open the "Solution center" again and go to the "Maintenance" Tab.
2. Select "Install color/black cartridge" and remove the cartridge or cartridges from the printer.
3. Get a damp paper towel.
4. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
5. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
6. Next dab the cartridge on the towel to make sure that the ink is flowing.
7. Snap the cartridges back into the printer.
8. On your computer, select "Old Cartridge install."
9. Repeat the "Clean Nozzle Page" one more time. If this fails to address the problem the entire procedure may need repeating.
Next, try this printer self-test by following the steps given below:
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know.
Oct 19, 2009 | Lexmark X1270 All-In-One InkJet Printer
Lexmark z517 paper in keep saying load paper when printing wont feed through please help
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle with one rubber roller on each side. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Locate the pick roller and clean the rubber wheels on the left and right with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust or ink build up, reload the paper and plug the power cord back in. The paper should then feed normally.
Next, I'd like you to attempt this printer self-test by following the steps given below:
1. Disconnect the power cord from the back of the printer.
2. Press and hold the button on the printer panel.
3. Reconnect the power cord and keep holding the button on the printer panel until the printer starts to pull paper.
4. The printer should now print a test page. Please note that the test is continuous. To stop the test, disconnect the power cord.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only the color cartridge installed. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 18, 2009 | Lexmark Inkjet Z517 Photo Printer
Lexmark 2500 printer won't print after replacing black cartridge
Unfortunately the printer wont print unless there is ink in both cartridges
Jan 01, 2009 | Lexmark All-in-One Printer with PictBridge
Black ink not printing, color prints fine!
Threw it in the garbage and ordered another, just saved the ink cartridges.
Oct 04, 2008 | Lexmark Inkjet Z517 Photo Printer
Lexmark x1270
screen shows ink but many of the times if the cartridges are dried up it will print blank pages.clean the cartridge head clogging manually and then try.otherwise replace the cartridges
Aug 28, 2008 | Lexmark Inkjet Z517 Photo Printer
COLOR NOT VIVID
The DeskJet 940c is not really the highest quality printer out there on the market. However, having said that, the printer is still capable of producing decent quality printouts. You might play with your printer settings for print intensity, lightness, ink volume.
May 10, 2008 | HP DeskJet 940c InkJet Printer
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
The black cartbridge is not printing and won't align
Dies this model have a separate print head? Or is the head part of the cartridge? If it is the latter then it seems to be a data transfer problem- which means possibly the contacts in the machine that mate with the contacts on the cartridge are dirty or damaged. In the first instance try gentle rubbing with a moist tissue the in machine contacts then try. Also try the Lexmark website Tech Support Team.
May 20, 2007 | Lexmark X6170 All-In-One InkJet Printer
Lexmark Inkjet Z517 Photo Printer Logo
219 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
