Question about Canon PIXMA iP3500 Printer
Just would not run with vista! - Canon PIXMA iP3500 Printer
  • 2 more comments
  • sleepwalker5 Apr 20, 2009
    yes,
    just a dialog box showing "error"
    and force to cancel the print job
    it seems that the laptop can't communicate with the printer
    cause when i started a print job
    from the task bar as usual showing the print que
    and it always stuck at the stage before printing when it's trying to collect the printer's status
    i'd tried the latest drivers downloaded from canon
    still no luck
    however it still works with my old laptop running win xp
    life if getting frustrated
    after i reset my laptop back to factory default....
    still no luck at all....
    even the feeding paper sound would makes me happier
    but no it just stay still, would budge! :(
  • sleepwalker5 Apr 21, 2009
    i found the spooler services stopped it and restarts it
    still doesn't work
    for info:
    btw the header of the dialog box "error"
    = Canon iP3500 series - USB001
    i've tried changing the ports, doesn't help
    changing different usb ports physically also doesn't help
    i've tried to install it on VM workstaton
    but the virtual machine (WinXP)
    can't detect that the printer is connected...
    i'd change usb cable too.....
  • Karunesh Kumar
    Karunesh Kumar May 11, 2010
    do u get any error msg..
    Sergeant:
  • 239 Answers
Go to run.. and type services.msc
A window will pop up...check der for printer and spooner services...if both the services r running or paused.....stop them and again start them....
Posted on Apr 20, 2009
Can you run vista on this motherboard
Go to the website of the motherboard. Find your info.
Sep 01, 2009 | Foxconn (945G7MA-8KS2) Motherboard
Vista RAM usage ?
The minimum recommended ram for Vista is 1 GB, generally accepted practical minimum is 2 GB. A 1 GB system will be kinda laggy. Maximum RAM for 32 bit Vista is 4 GB.
Vista Home Premium is roughly equivalent to Windows XP Media Center Edition (Has Media Center, cann't be put on a DOMAIN type network)
Vista Business is roughly equivalent to Windows XP Professional (Can Join a Domain, Doesn't have Media Center)
Vista Ultimate has all available freatures of Vista, you can do any windows function with Ultimate
Apr 26, 2009 | Dell Dimension 3100 PC Desktop
My Type Artist won't run on 64bit Vista
most will have to be run in compatibility mode. movies on cd & dvd probably won't burn to cd (or run at all). they're too old for the manufacturer to post patches for vista support.
http://www.howtogeek.com/howto/windows-vista/using-windows-vista-compatibility-mode/
if the software is already installed on a pc, run the upgrade advisor to get more info on compatibility.
http://www.microsoft.com/windows/products/windowsvista/buyorupgrade/upgradeadvisor.mspx?wt_svl=20409a&mg_id=20409b
Feb 22, 2009 | Clickaction My Type Artist (2085346)
Cannot upgrade windows vista home premium from disc
Check the programs that vista says it can not update. They may be incompatible with Vista. You can find this out by running the Windows Vista upgrade advisor available for free at microsoft.com. If you really want Vista & can do without the offending programs you can uninstall them & then run the upgrade. Hope this helps & please remember to rate my answer. Thanks.
Jan 23, 2009 | Microsoft Windows Vista Home Premium with...
I cannot run yahoo messenger on my vista ultimate. It always stopped working.I cannot run yahoo messenger 9 on my vista ultimate. It always stopped working.
it might just not be compatible with vista..alot of things are like that i wold search on yahoo.com for a vista version
Oct 27, 2008 | Yahoo Messenger
Running Windows Vista
Yes it will.
The Microsoft Office Suites are designed to run on Vista. Many of the new improvements in the Suites are only available on Vista.
The problem is that Vista has not been proven yet as an operating system. But Microsoft has made it clear that it is going to stop supporting XP at some point in the future and is focusing all of the company's attention on improving Vista.
Good luck with your new laptop!
Jul 15, 2008 | Computers & Internet
I have a Memorex U48 Flat Bed Scanner and have bought a new compouter with Vista. I need a driver download to work with Windows Vista. Thanks jreowens@aol.com
get the winXP driver MEMu1.50 (still available), there are no Vista drivers. Run the installation using WinXP emulation in Vista. You must run the installation as if you are in XP, not necessary when using the scanner subsequently. Now the Memorex 48u works on a Dell Dimension, running Windows Vista Home Premium. Hope this helps. I got the scannner for $14 after rebates at Staples years ago, it won't die.
May 05, 2008 | Memorex MEM48U Flatbed Scanner
VISTA UPGRADE FAILURE
Hi ZJIM, download & run windows vista adviser fro microsoft.
This program will check your system & even your printer if its connected & turned on. After its runs the testing it will advise you what will & will not run with vista. It will also show you where to get updates for your system so you can run vista.
http://search.microsoft.com/results.aspx?mkt=en-US&setlang=en-US&q=vista+adviser
Good Luck!
Mike
Mar 25, 2008 | Mach Speed P4M800 (890552603480)...
Vist Home & Proffessional
partition your hard drive thats how you can run 2 operating systems on your computer im running xp pro and vista ultimate
i recomend you use vista ultimate it has it all
Jan 03, 2008 | Microsoft Windows 98 for PC
Canon PIXMA iP3500 Printer Logo
77 people viewed this question
old marine
old marine
