Question about Tecnik TKC1285 Dual Fuel (Electric and Gas) Kitchen Range
I HAVE A 1989 CHEVY S10 BLAZER WITH A 4.3. I REPLACED THE FUEL PUMP, IT WILL FIRE AND RUN FOR A FEW SECONDS THEN QUIT. IT WILL START AND RUN LIKE THIS EVERY TIME I START IT. IT WILL CONTINUE TO RUN IF I PUMP THE GAS PEDDLE. WHAT COULD THE PROBLEM BE?
  • kcag Apr 20, 2009
    The fuel filter was also changed when I changed the pump.
  • emizell69 May 09, 2009
    I have a 1989 chevy blazer s10
    I replaced the fuel pump, fuel filter,inline fuel filter and the fuel relay nothing seems to work, I can only get my truck to run if I pour fuel directly into the tbi.
    Scholar:
  • 126 Answers
First impression to tell you is inline fuel filter probably clogged,the location of it varies but should be drivers side about middle of inner frame,to know for shure you can contact parts place and they will varify
Posted on Apr 20, 2009
I have a 96 Chevy Blazer 4 door I've change the ignition switch starter all that good old stuff if I turn the key and jumper by the starter it will run I have liked it just no crank no start
1989 Chevy blazer 4.3 won't start..I have ... - CarGurus
www.cargurus.com > Questions > Chevrolet > BlazerCarGurusJan 30, 2013 - 96 Chevy S10 Blazer with 4.3 L engine vortex will turn over but won'tstart. ... i a 93 k5 blazer 5.7tbi in cold weather it will not start, if i hook jumper ... was told it just needed a Fuel pump, I replaced the Fuel pump, and the Filter, ...
Oct 12, 2015 | Cars & Trucks
1997 chevy blazer what could it be
I had a 1997 s10 4*4 with the 2.8 v6.
mine do that I had to pull the gas tank replace fuel filter plus had to take undo the line from the intake and blow air thru it. Make sure all u're filter are replaced and y u have the tank down replace the fuel pump. I hope this helps u
Jun 23, 2014 | 1997 Chevrolet Blazer
I have a chevy blazer 94 S10 still quit on the road.
How is it running before it quits onyou. This could be the culprit of an egr valve. How many miles on thevehicle. The egr seems to die on a certain mileage pattern. Also youcould start by cleaning the egr valve before replacing it. This couldvery well help the situation, but this is just a guess. Hope thishelps!!
Apr 30, 2009 | 1994 Chevrolet S-10 Blazer
86 Chevy wont start
check for spark by removing a sparkplug
Dec 31, 2008 | 1986 Chevrolet S-10 Blazer
1991 chevy s10 blazer
Check the fuse under the dash. Did you replace the inline fuel filter? If not, you could loosen the line going into the filter then turn the key to the on position. The pump should run for about 2 seconds then the relay should kick off. Turn off the key for approx. 5 seconds then cycle key back on and the pump should cycle again. If you get a 2 second burst of fuel each time then the pump is cycling. Install a new fuel filter and check the grounded wire by the tank. Hope this helps. :)
Nov 03, 2008 | 1993 Chevrolet S-10 Blazer
Kitchen Ranges Logo
309 people viewed this question
Top Tecnik Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Tecnik Kitchen Range Expert? Answer questions, earn points and help others
