Question about Samsung HCM4215W 42" Rear Projection Television
Cannot not line up the red and blue lines on my samsung projection tv. it is a 2002 samsung tv
  • maztec May 18, 2009
    what is code for samsung convergence amps + resisisters
  • 41 Answers
Needs new convergence amps and possibly a few low ohm resistors.
Those Samsung amps usually run hot to the touch and sometimes only last 4 to 5 years depending on usage.
Posted on May 01, 2009
Samsung SP47W3HFX tv blue flickering curved line..
If the lines are slightly curved and stationary on about 2/3 of the screen its either the Blue CRT or the Blue CRT drive board which is having the problem.
Dec 19, 2009 | Televison & Video
Mitsubishi rear projection tv
replace vertical IC and shadows/ghosting the problem is either electrolytic capcitor or video IC or convergence adjustment
Aug 18, 2008 | Mitsubishi WS-65809 65" Rear Projection...
The power went out and now the tv wont turn on
Comment by msamshelton, posted on Aug 31, 2008Red and blue color on the tv don't line up. Can the remote line them up? And if not permanently, how much does it usually cost to have repaired.
Aug 08, 2008 | Samsung HCL5515W 55" Rear Projection...
Fine tuning grid on my Samsung HDTV with remote.(BP59-00048)
To adjust manual convergence on your projection TV, follow theses steps:
  1. Turn your TV on.
  2. Let it warm up for 30 minutes.
  3. Press the Menu button on your remote. The Main menu appears.
  4. Use your remote to select Function, and then press the joystick.
  5. Select Convergence, and then press the joystick. The Manual Convergence screen appears.
  6. Select Red, and then press the joystick. A series of crosshairs appears on the screen.
  7. Select one of the outside crosshairs by moving the joystick up/down/right/left or by pressing the 2 (up), 4 (left), 6 (right), or 8 (down) buttons on your remote. The method you use depends on the model of remote you have. Note: You must do the outside crosshairs first.
  1. In the crosshair you selected, if you can see a horizontal red line, use the CH up or CH down buttons to move the line so that it is superimposed on the horizontal center line of the crosshair. Note: Make the single horizontal line as white as possible.
  1. In the crosshair you selected, if you can see a vertical red line, use the Vol + or Vol - buttons to move the line so that it is superimposed on the vertical center line of the crosshair. Note: Make the single vertical line as white as possible.
  1. Repeat for all outside crosshairs, and then for the inside crosshair.
  2. Return to the Manual Convergence Screen, and select Blue, and then press the joystick.
  3. Repeat Steps 7 through 10 for Blue.
  4. Press the Menu button on your remote to exit.
Important: The directions above work for most Samsung Rear Projection TVs. Yours may be different. For exact directions to perform manual convergence, see your user's manual. If you don't have your user's manual on hand, click HERE to view your manual on line.
If you cannot get your Projection TV to converge, it may need to be serviced. To arrange a service appointment, call Samsung Customer Care at 1-800-Samsung (1-800-726-7864). Have your TV's model number and serial number on hand when you call.
Jan 05, 2008 | Samsung BP59-00016A Remote Control
Out of Focus
· Samsung parts for convergance problem
· http://www.partstore.com/Part/Samsung/Samsung/BP9500142E/New.aspx
Nov 24, 2007 | Samsung HCN4226W 42" Rear Projection...
Blue and red lines..
alignment of the covergence board ,you must enter the servicemode to adjust.set on psess mute 1-8-3 .press enter to save your settings.
Aug 18, 2007 | Samsung PCN5425R 54" Rear Projection...
Samsung HCM5525W TV red blue outlines on images
The Samsung has bad convergence IC's most likly. This should be repair ONLY by a trained technician as a TV set is not a place to experiment or tinker with because of the extremly high voltage inside. This repair should cost you in the range of 250 to 400 bucks . Good Luck
Jul 31, 2006 | Samsung HCM5525W 55" Rear Projection...
Samsung HCM4215W 42" Rear Projection Television Logo
215 people viewed this question
Jerry Greenberg
Jerry Greenberg
