Question about Mitsubishi VS-5075 50" Rear Projection Television
Pip the screen is white with a small picture at left center. If I push pip on remote it goes dark, push it again, it goes back to pip.
  • nimrod Sep 24, 2007
    pip problem tv is a mitsubishi VS-5075
    The pip problem tv is a Mitsubishi VS-5075
    Thanks, Nimrod
    President:
  • 2,961 Answers
Have you got the other input set up correctly as picture in picture allows you to watch more than one input eg watch cable and show analogue tv in pip mode so if one or the other is not set as the input pip picture it won't work.
Posted on Sep 26, 2007
  • 790 Answers
Ok nimrod they have many types of settings about pip viewer,will you please give the brand and model?
Posted on Sep 24, 2007
SOURCE:
Only getting a small picture in left hand corner of screen
It sounds like you might be in the PIP mode. check your remote for the PIP (Picture in Picture) and go hit it several times the picture should move around on the screen one of them should be the OFF.
Sep 22, 2014 | Televison & Video
My vizio flat screen has screen stuck in top right
Your TV is in Picture in Picture (PiP) mode. The small picture is the previous live input. The bigger dark area is the current input where there's no live source.
Find the PiP button on the TV remote or via the TV's menus. Press PiP a number of times to cycle through the options. Stop when the picture is the size you want.
Have a read of your TV manual. Stuff like this is detailed in there.
Sep 02, 2014 | Televison & Video
Sony tv troubleshooting
Hi, Please try to push or move the frame of your tv set on the dark side of the picture. If the picture becomes normal it is the loose connection. Otherwise it may be panel failure. Please consult some qualified technician or the service center.
May 04, 2014 | Televison & Video
Has small picture at corner cannot get full picture
do you have picture in picture on that tv, pip on the remote. if so try pushing that button
Mar 10, 2013 | Televison & Video
White box on tv screen
This sounds like your picture in picture feature is enabled or turned on. There is a button on the .ca remote that says pip or you may find it under the menus
Nov 23, 2012 | RCA HD52W59 HDTV Projection Television
Black box in upper left of screen
Thats the PIP (picture in picture), which lets you watch two pictures at once.  Push the PIP remote or go into the settings to turn the box off.
Nov 16, 2009 | LG 42LC2D 42 in. LCD HDTV
Picture inside a picture on my TV screen
The PIP (picture-in-picture) setting can easily be reversed if you look on your tv for the PIP button or for the same button on your remote. If neither of these works then you may want to check your TV's operation manual for the PIP setting .
Nov 26, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Pip only on screen
Try hard reset first==Unplug ac cord overnight, then try again.Possible signal board trouble-- Practice visual acuity technique==look for CRT coolant leak on circuit board. Also suspect PIP PCB==can be by-passed by a knowledgible tech.
Sep 26, 2007 | Mitsubishi VS-5075 50" Rear Projection...
Televison & Video Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
