Question about Craftsman Garden
I have a 7hp briggs and straton craftsman self propelled push mower. It's a few years old but runs great, the only thing wrong is the self propelled part won't engage. I took it apart down to the axle but still can't find a problem.?
  • 15 Answers
Could be a stretched out/broken belt, a worn out transmission or the drive teeth on the inside of the wheels could be worn out. I would start by looking at that. Remove the drive wheels and check for damaged or missing teeth.
Posted on Apr 23, 2009
How do I change the belt on a Briggs and Stratton Self Propelled 7.25ex lawn mower
unbolt top cover 5/16, unbolt bottom cover 3/8 unbolt blade 9/16 or 5/8 remove old belt, install new one, install covers and blade
Oct 01, 2014 | Briggs & Stratton Garden
What is the spark plug gap seting fot Champion RJ19LMC?
.30 is the standard for most lawn mower engines...you might check the "engine specifications" in your owner's manual to be sure.
Aug 22, 2014 | Troy Bilt 5.5hp Self Propelled Mower
What kind of battery does it take
Mowers don't typically take batteries. Possibly riding mowers might, but not push/self propelled mowers. They run off a spark plug and gas and that's it.
Jun 13, 2012 | Craftsman 675 Series 190cc 22" Briggs ...
My mower stops right after I prime the engine like its not getting any fuel. I have cleaned the flywheel, gapped the armature to .013 about the size of a business card. New plug, filter ect. I took the...
Make sure all the small holes that are in the brass bolt that holds the float bowl on the carburetor are clean and clear. Use no metal objects to clean it. You should find holes in the bottom of the bolt and along the top on the non-threaded part. This bolt is also the main jet of the carburetor.
Apr 23, 2011 | Craftsman 675 Series 190cc 22" Briggs ...
7Hp OHV Briggs & Straton Craftsman Front Propelled Smokes
Sounds like it is the valve seats. However normally it will stop smoking after is runs for a while if that is the problem. Does it run good? Because if it isn't the valve seats then it is the rings. Or a big scratch in the cylinder wall. Then most of the time it will loose compression. If it isn't smoking real bad then you can get an additive to put with your oil that will make it stop, maybe? It is about ten dollars and you can get is at most autoparts stores. It will just take a couple ounces of it. Follow the directions for how many qts of oil you have. After you change the oil in the motor take a magnet and run it through the oil and see if there is pieces of the rings in it.
Jul 12, 2010 | Briggs & Stratton Garden
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Garden Logo
353 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
