I have distortion of playing tapes.
I have had a Tandberg 3000x deck since it was new in 1972. I recently started playing my tapes again, and found some (or all) tapes produced distortion. I replaced the drive belt with a new one, but still have some distortion. What could cause this other than the drive belt? Thanks.
  • Charles Zink
    Charles Zink Apr 20, 2009
    It is not dirty or fuzzy, but the "wow" sound, as if the tape were being intermittenly impeded in playing. Thanks for your help. I'll try your solutions.
    Novelist:
  • 153 Answers
Degraded tape, dirty heads (clean with acetone and Q tip but don't get on plastic), dry coupling capacitors.This assumes that the distortion that you refer to is dirty or fuzzy sounding audio.
If a new tape, recorded and played back, sounds ok then your electronics are in good shape. That means your tapes are junk. If cleaning heads takes care of it, well that's pretty obvious. If your capacitors are dried out you will need to bring it in to a repair shop.
Posted on Apr 20, 2009
  • rjivaro Apr 20, 2009
    A wow sound is because the tape is being pulled at an inconsistent speed across the playback head. Replacing the belt was a good guess. Other possible causes are:
    Faulty capstan drive motor, inadequate pinch roller tension on the tape, inadequate lubrication on the drive motor and/or capstan shaft.
    The first thing to do is clean the capstan shaft and pinch roller (with acetone). Pull the plastic washer on the capstan shaft away from the bearing. Install a small drop of 3 in 1 oil on the shaft and push the washer back where it was. If you can get to it also put a drop on the drive motor shaft. It will take a minute or two to work in, but that should do it.
    Testing the tension of the pinch roller, well, approximately, involves removing the cassette door, holding the switches that detect tape presence in the active position (there might not be any on a deck of that age), put it in play and see if you can easily stop the pinch roller from spinning. If you can, typically this will be because of a worn cam, a dry (unlubricated) mechanism or a completely dried and shrunk pinch roller (replace).
Why will the Pioneer RT 707 not work in playback mode?
No it is the same motor for both functions. Just check does the record/play switch operate or move when you operate the record function? I have a hunch that is the problem it may also be that the switch contacts are dirty or worn.Try to play a recording you made on another machine if it does sound and play on the other machine then the problem can only be this switch. Some more upstairs decks do have separate amplifiers for play and record .Nakamichi. Studer Revox Tandberg Uher and the such comes to mind These are those machines offering "Off tape" recording monitor. Then it will sport three heads and not only two I hope this gives clues where to start looking for problems
Sep 01, 2014 | Audio Players & Recorders
I have a Tandberg 6000x r to r deck in grat shape except the rubber pinch roller has flat spot in it. I've found someone who can re-work the rubber wheel, but I cant figure out how to remove it from the...
It might not be a type that is meant to be fixed by that method. These type of pinch rollers are often held in place by horseshoe clips. Once that is removed the Roller assembly will often drop out. However to get the worn roller out, might require it being bendered out of shape to remove the wheel.
Jun 02, 2014 | Audio Players & Recorders
Music playing backwards
Well, not being there to try some diagnostics, there can be a number of reason that the tape plays backwards at times. One reason is that the tapes are 4 channel discrete tape requiring a 4 track 4 channel deck- this would mean track 2,4 are recorded in the forward direction. A Stereo (2 channel 4 track deck) play tracks 2,4 in the opposite direction. That is why you turn the tape over on some decks. Other possibilities could be tape path skew, that reverse relay is NOT changing the head that "listens: to the tape and that is just the start of what it could be. When a new person starts to use a deck of such age- it can be correct to assume that the deck is not working in some respect. A Tape deck Technician such as myself would know how to determine if the deck was working correct or not and know and have parts to correct it. I worked in the Factory Service in Chicago for Teac and actually have one coming into my shop in the near future. After 40 years of working on these I am still at it. I am sorry there may not be an easy answer to this.
Aug 01, 2012 | Teac Audio Players & Recorders
What is the bias control's function?
The Bias control is used during recording. If you turn down the bias, you will get more highs, but the distortion will increase, and then start to increase dramatically if you back off the bias more.
As far as playing tapes from different decks goes.......
1..Does the tape that you recorded on your deck sound OK on your deck ?
2..Does the tape that you recorded on your deck sound OK on other decks ?
If 1 and 2 are true, then your deck is OK.
If the tapes recorded on a specific deck sound bar on yours, but 1 and 2 are true, then the other deck is faulty.
When a deck leaves the factory, the head is aligned to a " standard " tape. By standard tape I mean a very special tape recorded in such a way, that a tech can tell if the head is out of align and "tweek " the physical alignment of the tape head..
All decks are aligned just a little differently, but fairly close to each other.
first do the mechanicals....is the head of your deck spotlessly clean ?. Use 99% pure isopropanol alcohol and a cotton swab. Never use anything metal to clean the tape head. If you scratch the head, its toast.
If your deck is clean, plays its own recordings well, and those recordings play well on other decks, then your deck is not the problem.
Hope this helps,
Rob
Mar 24, 2012 | Audio Players & Recorders
I have a Tandberg A-20 Tape Deck with a fault in the tape advance. I think it's in a microprocessor. Other than this is OK. Does anybody know how to fix it?. Thank you.
The speed of the wheels is indeed controlled by the processor. But the only way to properly diagnose that is to have it in front of you. Since i don't have it all i can do is guess: the speed is determined by the comparison of the frequencies given by a local oscillator and a sensor on the wheels; in your case the local oscillator is out of tune ( the frequency is off) because the components have aged and their value has shifted. To fix it you must retune it.
You will find the repair manual here
http://www.hifiengine.com/manuals/tandberg/td-20-a.shtml
May 16, 2011 | Audio Players & Recorders
I have a Tanberg 6000x. Rarely used, in seemingly mint condition. Only problem is that the two tape reels seem to move in opposing directions. I don't have a clue.
The old Tandberg's are good reel to reel recorders. Unfortunately, that joystick drive mechanism is very complex under the hood. It pushes different levers and such to apply the right combination for whatever mode you select. If you're somewhat mechanically inclined, try sliding the deck out of its case. Move the joystick to see what's being pushed where. That may show you something slipped out or broken. If not, you may have to power it up and watch the difference between play and fast forward. Both should make the takeup spool (right side) rotate CCW. You may be able to see the difference and move or tighten something up. If its not that obvious or you are not so inclined, you may have to search out a person to repair it who knows the Tandberg. They are somewhat unusual beasts (the deck not the techs) so you need someone who knows that joystick mechanism - Tandberg used it a lot but they were about the only one.
Oct 26, 2010 | Audio Players & Recorders
I have just purchased a tandberg 15.22 its in v good cond, no apparent head wear, I've replaced the belt (slow rewind) capstan is fine, there is distortion on the amp, I've cleane the record/amp/playback...
Resistors are good at causing distortion, you might spot one that has burned or broken. If the distortion is in both channels, which by what you say it is, then you might be looking for something common to both channels. Perhaps an IC.
Jan 21, 2010 | Audio Players & Recorders
Denon DRM 740 tape does not play
Just bought a unit from a thrift store. Found same problem; FF & RW OK, but play engages then stops. Also noticed buzzing noise when power turned on. Opened unit, found broken capstan drive belt. FF & RW driven from different motor. Buzz was drive motor running freely with no load - when power is on, capstan is driven all the time for fast play/record start. Replaced with rubber band, and it works --- now looking for replacement belt.
Apr 12, 2007 | Denon DRM-740 Single Dual Cassette Deck
166 people viewed this question
 Grubhead
Grubhead
